C_Wilson009 Posted February 17, 2016 Share Posted February 17, 2016 Hey guys, if I go to sync box art and cart art. How do I know what folder they need to be in to work? Link to comment Share on other sites More sharing options...
JoyStickKilla Posted February 17, 2016 Share Posted February 17, 2016 By whatever the theme dictates. Link to comment Share on other sites More sharing options...
C_Wilson009 Posted February 17, 2016 Author Share Posted February 17, 2016 By whatever the theme dictates. oh okay, how can you find that out? Link to comment Share on other sites More sharing options...
JoyStickKilla Posted February 17, 2016 Share Posted February 17, 2016 opening the themes ini file Link to comment Share on other sites More sharing options...
C_Wilson009 Posted February 17, 2016 Author Share Posted February 17, 2016 opening the themes ini file inside the default.zip file? All I see is .png and .xml Link to comment Share on other sites More sharing options...
JoyStickKilla Posted February 17, 2016 Share Posted February 17, 2016 xml Link to comment Share on other sites More sharing options...
C_Wilson009 Posted February 17, 2016 Author Share Posted February 17, 2016 okay <?xml version="1.0" encoding="utf-8"?><Theme> <video w="475" h="380" x="265" y="397" r="5" time="1" bcolor="0x000000" bcolor2="0x000000" bcolor3="0x000000" bsize="0" bsize2="0" bsize3="0" bshape="square" type="fade" start="none" forceaspect="both" below="false" /> <artwork1 x="270" y="397" r="0" time="1" type="fade" start="none" rest="none" /> <artwork2 x="512" y="384" r="0" time="1" type="fade" start="none" rest="none" /> <artwork3 x="765" y="384" r="0" time="1" type="ease" start="right" rest="none" /> <artwork4 x="512" y="384" r="0" time="3" type="ease" start="right" rest="none" /></Theme> what part tells me which is for cart, and which is for box? Link to comment Share on other sites More sharing options...
Metalzoic Posted February 17, 2016 Share Posted February 17, 2016 What is the name of the .png files in the zip. That XML shows instructions for Artwork1, 2, 3 & 4 Whichever of those don't have a matching .png in the zip is probably the one. My guess is Artwork3 & Artwork4. However I never, ever use cart or box art themes so I can't say for sure. Link to comment Share on other sites More sharing options...
C_Wilson009 Posted February 17, 2016 Author Share Posted February 17, 2016 What is the name of the .png files in the zip. That XML shows instructions for Artwork1, 2, 3 & 4 Whichever of those don't have a matching .png in the zip is probably the one. My guess is Artwork3 & Artwork4. However I never, ever use cart or box art themes so I can't say for sure. there is a png called artwork 1, 2, 4 and background Link to comment Share on other sites More sharing options...
Avar Posted February 17, 2016 Share Posted February 17, 2016 As said already, it depends on the theme. You can also manually move them to another folder later or add a default artwork slot to w/e theme you're using via HyperTheme. Artwork3 and 4 is common for box and cart art, respectively. Link to comment Share on other sites More sharing options...
Avar Posted February 17, 2016 Share Posted February 17, 2016 there is a png called artwork 1, 2, 4 and background Then the theme will load artwork for artwork 3 directly from the Artwork3 folder. You can change this behaviour in HyperTheme if desired. Link to comment Share on other sites More sharing options...
ChrisFourie Posted April 17, 2016 Share Posted April 17, 2016 Why does everything i try to download on this page tell me that i can't? Link to comment Share on other sites More sharing options...
