Criei esse tópico para postar o módulo moficado por mim para o Project64 v1.6.1 criado por djvj v2.0...
Esse emulador dá problema na abertura de roms em sistemas Windows do Brasil, como também dá problema pra quem usa o Esc para sair do emulador/HyperLaunch.
Nesse módulo a seguir se resolve estes dois problemas. É só copiar o código no arquivo Project64 (v1.6.1 djvj 2.0).ahk que está na pasta HyperLaunch\Modules\Project64.
(Lembrando que é sempre recomendável fazer um backup dos seus arquivos antes de serem modificados!)
MEmu = Project64
MEmuV = v1.6.1
MURL = http://www.pj64-emu.com/
MAuthor = djvj
MVersion = 2.0
MCRC = 71C1EEDA
iCRC = 93F5376F
MID = 635038268917505226
MSystem := "Nintendo 64"
; Notes:
; Make sure you apply the 1.6.1 patch found here: http://www.jabosoft.com/index.php?articleid=114
; It applies many of the v1.7 updates but keeps the stability of the v1.6 emu
; CLI loading doesn't work, script opens roms manually
; Set SelectGameMode if you have any problems with the emu opening the game
; Run the emu manually and hit Ctrl+T to enter Settings. On the Options tab, check "On loading a ROM, go to full screen"
; Also enable CPU
; If roms don't start automatically, enabled advanced settings, reopen Settings window, go to the Advanced tab and check "Start Emulation when rom is opened?"
; I like to turn off the Rom Browser by going to Settings->Rom Selection and uncheck "Use Rom Browser" (advanced settings needs to be on to see this tab)
; If you use Esc as you/r exit key, it seems to crash the emu because it also takes the emu out of fullscree,n and it need to be closed in Task Manager. It doesn't happen if you leave fullscreen first
; Project64 stores its config in the registry @ HKEY_CURRENT_USER\Software\JaboSoft\Project64 DLL
; and also @ HKEY_CURRENT_USER\Software\N64 Emulation
StartModule()
FadeInStart()
Fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1) ; Controls if emu launches fullscreen or windowed
FullscreenMethod := IniReadCheck(settingsFile, "Settings", "FullscreenMethod","reg",,1) ; reg = registry, hotkey = alt+enter. Windows 8 does not seem to work with the registry method as the key is not even there to change, Use hotkey if reg doesn't set fullscreen for you.
HideLoading := IniReadCheck(settingsFile, "Settings", "HideLoading","false",,1) ; This speeds up loading roms but can cause some PCs to get stuck at the Open Rom window or cause HS to flicker through. Disable it if you have this issue
SelectGameMode := IniReadCheck(settingsFile, "Settings", "SelectGameMode","1",,1) ; 1 = Uses a loop to detect the Edit Box has the romname and path in it. This doesn't work on all PCs, so if you get stuck at the open rom window, use mode 2. 2 = Uses a simple Ctrl+v to paste the romname and path, then press Enter to load the game.
ControlDelay := IniReadCheck(settingsFile, "Settings", "ControlDelay","20",,1) ; Raise this if the module is getting stuck somewhere
KeyDelay := IniReadCheck(settingsFile, "Settings", "KeyDelay","-1",,1) ; Raise this if the module is getting stuck using SelectGameMode 2
MDebug := IniReadCheck(settingsFile, "Settings", "MDebug","false",,1) ; Set to true to get some MDebug tooltips to help with debugging problems with loading
SetControlDelay, %ControlDelay%
SetKeyDelay, %KeyDelay%
; Setting Fullscreen setting in registry if it doesn't match what user wants above
currentFullScreen := ReadReg("On open rom go full screen")
If ( Fullscreen != "true" And currentFullScreen = 1 )
WriteReg("On open rom go full screen", 0)
Else If ( Fullscreen = "true" And currentFullScreen = 0 )
WriteReg("On open rom go full screen", 1)
Run(executable, emuPath) ;, Hide
;This fully ensures dialogs are completely hidden even faster than winwait
If HideLoading = true
SetTimer, WaitForDialogEmu, 2
If MDebug = true
ToolTip, Waiting for "ahk_class Project64 Version 1.6" to appear
WinWait("ahk_class Project64 Version 1.6")
If MDebug = true
ToolTip, Waiting for "ahk_class Project64 Version 1.6" to become active
WinWaitActive("ahk_class Project64 Version 1.6")
Send, ^o ; Open Rom
SetTimer, WaitForDialog, 2
If MDebug = true
ToolTip, Waiting for "Abrir ahk_class #32770" to appear
WinWait("Abrir ahk_class #32770")
If MDebug = true
ToolTip, Waiting for "Abrir ahk_class #32770" to become active
WinWaitActive("Abrir ahk_class #32770")
If ( SelectGameMode = 1 ) {
Loop {
ControlGetText, edit1Text, Edit1, Abrir ahk_class #32770
If ( edit1Text = romPath . "\" . romName . romExtension )
Break
If MDebug = true
WinGetActiveTitle, currentActiveWin
ToolTip, Active Window: %currentActiveWin%`nCurrent Edit1 Text: %edit1Text%
Sleep, 100
ControlSetText, Edit1, %romPath%\%romName%%romExtension%, Abrir ahk_class #32770
ControlSend, Button1, {Enter}, Abrir ahk_class #32770 ; Select Open
} Else If ( SelectGameMode = 2 ) {
Clipboard := romPath . "\" . romName . romExtension
Send, ^v{Enter}
} Else
ScriptError("You did not choose a valid SelectGameMode.`nOpen the module and set the mode at the top.")
If MDebug = true
ToolTip, Waiting for "ahk_class Project64 Version 1.6" to become active again after loading rom
; Sleep, 4000 ; giving time for emu to load rom so Hyperspin doesn't pop into view
ControlGetPos, x, y, w, h, msctls_statusbar321, ahk_class Project64 Version 1.6
Loop {
Sleep, 200
If Fullscreen = true ; looping until 1964 is done loading rom and it goes fullscreen. The x position will change then, which is when this loop will break.
ControlGetPos, x2, y2, w2, h2, msctls_statusbar321, ahk_class Project64 Version 1.6
Else { ; looping until Project64 is done loading rom and it starts showing frames if in windowed mode, then this loop will break.
StatusBarGetText, cText, 2, ahk_class Project64 Version 1.6 ; get text of statusbar which shows emulation stats
StringSplit, cTextAr, cText, .: ; split text to find the FPS which will update constantly as emulation is active
If cTextAr2 > 0 ; Break out when FPS is greater then 0
Break
If MDebug = true
ToolTip, Waiting for "Project64 Version 1.6" to go fullscreen or to start showing frames if using windowed mode after loading rom`nWhen x does not equal x2 (in windowed mode)`, script will continue:`nx=%x%`nx2=%x2%`ny=%y%`ny2=%y2%`nw=%w%`nw2=%w2%`nh=%h%`nh2=%h2%`nStatus Bar Text: %cText%`nLoop #: %A_Index%`nVideo `%: %cTextAr2%
If ( x != x2 or A_Index >= 30) { ; x changes when emu goes fullscreen, so we will break here and destroy the GUI. Break out if loop goes on too long, something is wrong then.
If A_Index >= 30
Log(MEmu . " had a problem detecting when it was done loading the rom. Please try different options inside the module to find what is compatible with your system.")
Break
SetTimer, WaitForDialogEmu, Off
SetTimer, WaitForDialog, Off
Gosub, RestoreWindow
If (Fullscreen = "true" && FullscreenMethod = "hotkey") {
Sleep, 2000 ; required otherwise keys get sent too early
Send, !{Enter}
If MDebug = true
ToolTip ; turn off tooltips
FadeInExit()
7zCleanUp()
FadeOutExit()
ExitModule()
ReadReg(var1) {
RegRead, regValue, HKEY_CURRENT_USER, Software\N64 Emulation\Project64 Version 1.6, %var1%
Return %regValue%
WriteReg(var1, var2) {
RegWrite, REG_DWORD, HKEY_CURRENT_USER, Software\N64 Emulation\Project64 Version 1.6, %var1%, %var2%
WaitForDialogEmu:
IfWinNotExist, ahk_class Project64 Version 1.6
Return
Else
WinSet, Transparent, 0, ahk_class Project64 Version 1.6
Return
WaitForDialog:
IfWinNotExist, Abrir ahk_class #32770
Return
Else
WinSet, Transparent, 0, Abrir ahk_class #32770
Return
RestoreWindow:
IfWinNotExist, Project64
Return
Else
WinSet, Transparent, Off, Project64
Return
HaltEmu:
ControlSend, ,{Esc}, ahk_class %EmulatorClass%
Return
RestoreEmu:
Winrestore, ahk_class %EmulatorClass%
Send, !{Enter}
Sleep, 500
Return
CloseProcess:
FadeOutStart()
IfInString, exitEmulatorKey, Esc
Send, !{Enter}
Sleep, 500
WinClose("ahk_class Project64 Version 1.6")
Return
Question
NEODAN
E aí pessoal?
MEmu = Project64 MEmuV = v1.6.1 MURL = http://www.pj64-emu.com/ MAuthor = djvj MVersion = 2.0 MCRC = 71C1EEDA iCRC = 93F5376F MID = 635038268917505226 MSystem := "Nintendo 64" ;---------------------------------------------------------------------------- ; Notes: ; Make sure you apply the 1.6.1 patch found here: http://www.jabosoft.com/index.php?articleid=114 ; It applies many of the v1.7 updates but keeps the stability of the v1.6 emu ; CLI loading doesn't work, script opens roms manually ; Set SelectGameMode if you have any problems with the emu opening the game ; Run the emu manually and hit Ctrl+T to enter Settings. On the Options tab, check "On loading a ROM, go to full screen" ; Also enable CPU ; If roms don't start automatically, enabled advanced settings, reopen Settings window, go to the Advanced tab and check "Start Emulation when rom is opened?" ; I like to turn off the Rom Browser by going to Settings->Rom Selection and uncheck "Use Rom Browser" (advanced settings needs to be on to see this tab) ; If you use Esc as you/r exit key, it seems to crash the emu because it also takes the emu out of fullscree,n and it need to be closed in Task Manager. It doesn't happen if you leave fullscreen first ; ; Project64 stores its config in the registry @ HKEY_CURRENT_USER\Software\JaboSoft\Project64 DLL ; and also @ HKEY_CURRENT_USER\Software\N64 Emulation ;---------------------------------------------------------------------------- StartModule() FadeInStart() settingsFile := modulePath . "\" . moduleName . ".ini" Fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1) ; Controls if emu launches fullscreen or windowed FullscreenMethod := IniReadCheck(settingsFile, "Settings", "FullscreenMethod","reg",,1) ; reg = registry, hotkey = alt+enter. Windows 8 does not seem to work with the registry method as the key is not even there to change, Use hotkey if reg doesn't set fullscreen for you. HideLoading := IniReadCheck(settingsFile, "Settings", "HideLoading","false",,1) ; This speeds up loading roms but can cause some PCs to get stuck at the Open Rom window or cause HS to flicker through. Disable it if you have this issue SelectGameMode := IniReadCheck(settingsFile, "Settings", "SelectGameMode","1",,1) ; 1 = Uses a loop to detect the Edit Box has the romname and path in it. This doesn't work on all PCs, so if you get stuck at the open rom window, use mode 2. 2 = Uses a simple Ctrl+v to paste the romname and path, then press Enter to load the game. ControlDelay := IniReadCheck(settingsFile, "Settings", "ControlDelay","20",,1) ; Raise this if the module is getting stuck somewhere KeyDelay := IniReadCheck(settingsFile, "Settings", "KeyDelay","-1",,1) ; Raise this if the module is getting stuck using SelectGameMode 2 MDebug := IniReadCheck(settingsFile, "Settings", "MDebug","false",,1) ; Set to true to get some MDebug tooltips to help with debugging problems with loading SetControlDelay, %ControlDelay% SetKeyDelay, %KeyDelay% 7z(romPath, romName, romExtension, 7zExtractPath) ; Setting Fullscreen setting in registry if it doesn't match what user wants above currentFullScreen := ReadReg("On open rom go full screen") If ( Fullscreen != "true" And currentFullScreen = 1 ) WriteReg("On open rom go full screen", 0) Else If ( Fullscreen = "true" And currentFullScreen = 0 ) WriteReg("On open rom go full screen", 1) Run(executable, emuPath) ;, Hide ;This fully ensures dialogs are completely hidden even faster than winwait If HideLoading = true SetTimer, WaitForDialogEmu, 2 If MDebug = true ToolTip, Waiting for "ahk_class Project64 Version 1.6" to appear WinWait("ahk_class Project64 Version 1.6") If MDebug = true ToolTip, Waiting for "ahk_class Project64 Version 1.6" to become active WinWaitActive("ahk_class Project64 Version 1.6") Send, ^o ; Open Rom ;This fully ensures dialogs are completely hidden even faster than winwait If HideLoading = true SetTimer, WaitForDialog, 2 If MDebug = true ToolTip, Waiting for "Abrir ahk_class #32770" to appear WinWait("Abrir ahk_class #32770") If MDebug = true ToolTip, Waiting for "Abrir ahk_class #32770" to become active WinWaitActive("Abrir ahk_class #32770") If ( SelectGameMode = 1 ) { Loop { ControlGetText, edit1Text, Edit1, Abrir ahk_class #32770 If ( edit1Text = romPath . "\" . romName . romExtension ) Break If MDebug = true { WinGetActiveTitle, currentActiveWin ToolTip, Active Window: %currentActiveWin%`nCurrent Edit1 Text: %edit1Text% } Sleep, 100 ControlSetText, Edit1, %romPath%\%romName%%romExtension%, Abrir ahk_class #32770 } ControlSend, Button1, {Enter}, Abrir ahk_class #32770 ; Select Open } Else If ( SelectGameMode = 2 ) { Clipboard := romPath . "\" . romName . romExtension Send, ^v{Enter} } Else ScriptError("You did not choose a valid SelectGameMode.`nOpen the module and set the mode at the top.") If MDebug = true ToolTip, Waiting for "ahk_class Project64 Version 1.6" to become active again after loading rom WinWaitActive("ahk_class Project64 Version 1.6") ; Sleep, 4000 ; giving time for emu to load rom so Hyperspin doesn't pop into view ControlGetPos, x, y, w, h, msctls_statusbar321, ahk_class Project64 Version 1.6 Loop { Sleep, 200 If Fullscreen = true ; looping until 1964 is done loading rom and it goes fullscreen. The x position will change then, which is when this loop will break. ControlGetPos, x2, y2, w2, h2, msctls_statusbar321, ahk_class Project64 Version 1.6 Else { ; looping until Project64 is done loading rom and it starts showing frames if in windowed mode, then this loop will break. StatusBarGetText, cText, 2, ahk_class Project64 Version 1.6 ; get text of statusbar which shows emulation stats StringSplit, cTextAr, cText, .: ; split text to find the FPS which will update constantly as emulation is active If cTextAr2 > 0 ; Break out when FPS is greater then 0 Break } If MDebug = true ToolTip, Waiting for "Project64 Version 1.6" to go fullscreen or to start showing frames if using windowed mode after loading rom`nWhen x does not equal x2 (in windowed mode)`, script will continue:`nx=%x%`nx2=%x2%`ny=%y%`ny2=%y2%`nw=%w%`nw2=%w2%`nh=%h%`nh2=%h2%`nStatus Bar Text: %cText%`nLoop #: %A_Index%`nVideo `%: %cTextAr2% If ( x != x2 or A_Index >= 30) { ; x changes when emu goes fullscreen, so we will break here and destroy the GUI. Break out if loop goes on too long, something is wrong then. If A_Index >= 30 Log(MEmu . " had a problem detecting when it was done loading the rom. Please try different options inside the module to find what is compatible with your system.") Break } } If HideLoading = true { SetTimer, WaitForDialogEmu, Off SetTimer, WaitForDialog, Off Gosub, RestoreWindow } If (Fullscreen = "true" && FullscreenMethod = "hotkey") { Sleep, 2000 ; required otherwise keys get sent too early Send, !{Enter} } If MDebug = true ToolTip ; turn off tooltips FadeInExit() Process("WaitClose", executable) 7zCleanUp() FadeOutExit() ExitModule() ReadReg(var1) { RegRead, regValue, HKEY_CURRENT_USER, Software\N64 Emulation\Project64 Version 1.6, %var1% Return %regValue% } WriteReg(var1, var2) { RegWrite, REG_DWORD, HKEY_CURRENT_USER, Software\N64 Emulation\Project64 Version 1.6, %var1%, %var2% } WaitForDialogEmu: IfWinNotExist, ahk_class Project64 Version 1.6 Return Else WinSet, Transparent, 0, ahk_class Project64 Version 1.6 Return WaitForDialog: IfWinNotExist, Abrir ahk_class #32770 Return Else WinSet, Transparent, 0, Abrir ahk_class #32770 Return RestoreWindow: IfWinNotExist, Project64 Return Else WinSet, Transparent, Off, Project64 Return HaltEmu: ControlSend, ,{Esc}, ahk_class %EmulatorClass% Return RestoreEmu: Winrestore, ahk_class %EmulatorClass% Send, !{Enter} Sleep, 500 Return CloseProcess: FadeOutStart() IfInString, exitEmulatorKey, Esc Send, !{Enter} Sleep, 500 WinClose("ahk_class Project64 Version 1.6") ReturnGostaram? Agradeçam!
6 answers to this question
