doohan Posted February 28, 2016 Posted February 28, 2016 Hi everybody, I have a script in Hyperlaunch for Dreamcast that works pretty fine (without what is in bolf) but if I add the GUI (I want to hide the launching of the emulator), Emulator is not hiding, He launchs the black screen, move the cursor to select System and game then...launchs the emulator. --------------------------------------------------------------------------------------- IniWrite, %romPath%%romname%%RomExtension%, %emupath%gdrImage.ini, Main, imagefilename sleep, 250 Run, %emupath%%executable% ;-run=dreamcast -rom=%Romname% sleep, 500 Click 20, 40 Click 20, 60 Process, WaitClose, %executable% WinActivate, HyperSpin ExitApp CloseProcess: Process, Close, %Executable% return ----------------------------------------------------------------------------------- It should to do as follow: Launch the black screen, Launch the emulator. move the cursor to select System and game move the cursor out of screen Proble is that the cursor doens't point anymore on demul but on the GUI screen. Has someone an idea ? Thanks and regards,
JoyStickKilla Posted February 28, 2016 Posted February 28, 2016 Being as most people on here use rocketlauncher I am not sure you will get much help on that.
doohan Posted February 28, 2016 Author Posted February 28, 2016 Hi JoyStickKilla. I've tried this too but don't like it really much....too many options Maybe I want have any other choice....
lassic Posted February 28, 2016 Posted February 28, 2016 I have the same problem. Loading screen shown, then the emulator GUI stays and top. no fullscreen, even if it is set up in the emulator. i use RL too.
SIMPLYAUSTIN Posted February 28, 2016 Posted February 28, 2016 Some builds of demul, I had to change manual in config then read only the file to make it stay Simply Austin's YouTube
lassic Posted February 28, 2016 Posted February 28, 2016 Ah... i found out. Just setup "Stretch" in the Video Config. Then it boots in fullscreen. Have you checked out if the resolution is compatible with your monitor?
doohan Posted February 28, 2016 Author Posted February 28, 2016 Hi, No problem to get fullscreen with Demul. Just want to hide the launching of the emulator with a black screen. But Script works not in the good order I ask to. It doesn't launch the emulator after the black screen. It launch it when all moves with the cursor are done...
