N64 setup
cross30
anyone get N64 running on the Nvidia shield?? My roms are not loading, seems like the issue is with Retroarch. any ideas?
[exe info]
path=H:\hyperspin\emulators\Nintendo 64\
rompath=Emulators/Nintendo 64/roms/
userompath=true
exe=com.retroarch/com.retroarch.browser.retroactivity.RetroActivityFuture
parameters=cores/mupen64plus_libretro_android.so
romextension=zip
searchsubfolders=true
pcgame=false
winstate=HIDDEN
hyperlaunch=true
Per_Game_Modules=false
Skipchecks=false
Hide_Cursor=use_global
Hide_Desktop=use_global
Hide_Taskbar=use_global
CPWizard_Enabled=use_global
CPWizard_Delay=use_global
CPWizard_Params=use_global
Fade_In=use_global
Fade_Out=use_global
Fade_Color=use_global
Fade_In_Duration=use_global
Fade_Out_Duration=use_global
Fade_In_Delay=use_global
7z_Enabled=use_global
7z_Extract_Dir=use_global
7z_Delete_Temp=use_global
Keymapper_Enabled=use_global
Keymapper=use_global
MultiGame_Enabled=use_global
MultiGame_Background_Color=use_global
MultiGame_Side_Padding=use_global
MultiGame_Y_Offset=use_global
MultiGame_Image_Adjust=use_global
MultiGame_Font=use_global
MultiGame_Text_1_Options=use_global
MultiGame_Text_1_Text=use_global
MultiGame_Text_2_Options=use_global
MultiGame_Text_2_Offset=use_global
MultiGame_Use_Sound=use_global
MultiGame_Sound_Frequency=use_global
MultiGame_Exit_Effect=use_global
MultiGame_Selected_Effect=use_global
MultiGame_Use_Game_Art=use_global
MultiGame_Art_Folder=use_global
[filters]
parents_only=false
themes_only=false
wheels_only=false
roms_only=false
[themes]
use_parent_vids=false
use_parent_themes=false
animate_out_default=false
reload_backgrounds=true
[wheel]
alpha=.15
small_alpha = 1
style=normal
speed=high
pin_center_width=500
horz_wheel_y=512
vert_wheel_position=right
y_rotation=center
norm_large=360
norm_small=230
vert_large=400
vert_small=240
pin_large=500
pin_small=200
horz_large=240
horz_small=150
letter_wheel_x=800
letter_wheel_y=384
text_width=700
text_font=Style4
small_text_width=260
large_text_width=400
text_stroke_size=6
text_stroke_color=0x000000
text_color1=0x00BFFD
text_color2=0xFFFFFF
text_color3=0x00BFFD
color_ratio=139
shadow_distance=0
shadow_angle=45
shadow_color=0x000000
shadow_alpha=1
shadow_blur=0
[pointer]
animated=true
x=975
y=360
[video defaults]
path=H:\hyperspin\Media\Nintendo 64\Video\
[sounds]
game_sounds=true
wheel_click=true
[navigation]
game_jump=50
use_indexes=false
jump_timer=400
remove_info_wheel=true
remove_info_text=true
use_last_game=false
last_game=Aidyn Chronicles - The First Mage (USA)
random_game=false
start_on_favorites=false
[special Art A]
default=true
active=true
x=512
y=720
in=0.4
out=0.4
length=3
delay=0
type=normal
start=bottom
[special Art B]
default=true
active=true
x=512
y=740
in=0.4
out=0.4
length=3
delay=0
type=fade
start=none
[special Art C]
active=true
x=512
y=384
in=0
out=0
length=3
delay=10
type=fade
start=none
[Game Text]
game_text_active    = true
show_year           = true
show_manf           = true
show_description    = true
text_color1         = 0x174AEF
text_color2         = 0x174AEF
stroke_color        = 0x000000
text_font           = Style3
text1_textsize=26
text1_strokesize=7
text1_x=32
text1_y=610
text2_textsize=36
text2_strokesize=8
text2_x=30
text2_y=640
  On 3/4/2016 at 7:04 AM, Sting said:
Don't think it support's .zip files, extract ROMs and add ROM extension to setting file :)
I think the mupen64 core is messed up in Retroarch at the moment.
The standalone mupenAE+ emulator works but as Sting stated, roms must be unzipped.
I also had a problem with loading N64 roms recently. Went into a working emulator and in the settings, I switched GLUI to RGUI and my roms started loading.
