Retro Arch Per Core Config
FrankyRizzo
If 5 systems all use the same core....  Is it possible to have all 5 systems use a different bezel?  Game Gear, Master System, 32x, Sega CD and Genesis all use the same core...
I am talking about using the bezel option built into retro arch.  Not the one for Rocket Launcher.
It only uses 1 config file for the core genesis_plus_gx_libretro.dll
You could try saving the core configs, then manually renaming them to something like genesis_plus_gx_gg_libretro.dll  (game gear).  then setting rocketlauncher to use that config for game gear.  I think I did this with a few systems before with success.
I renamed each of my config files to the system names.
ie. Picodrive.cfg would be changed to Sega Genesis.cfg
I would assume you could do the same thing and just copy/rename the file for each system, then set them up individually.
Come to think of it, this is exactly how my Master System and Game Gear configs look. (Genesis, CD,  32x are all in one wheel using picodrive on my build)
