Help with creating favorite wheel!!
MonsterCockie
Hello guys im looking for some help im almost done setting up hyperspin with all my favorite emulators now the only emulator im missing is mame i got a all bunch of mame 0.139 roms on my harddrive and when I checked the database file for mame is different from the other databases emulators files it has casino,sports,aviation action and all bunch of other section and i just couldn't manage to get it working, and also how do you make another wheel for your favorites games using all consoles in one wheel i saw a video from youtube and he had a nice setup husing favorites on one wheel i think the name of the wheel was Arcade Classics. Thanks for any help will be much appreciated!
The only way to manage a list of favorites in Hyperspin Android (currently) is to create a custom system-dbase.xml file, OR cull the roms or themes you want and then use rons_only/themes_only filters.
Is there a example file on what to put in the xml file or more information on the forums I couldn't find anything on the android section is it the same if i follow the PC section
Any emulator app that supports 'launching of roms' from the command line will work.    Most emulators support this functionality, a few do not.    In the sample .ini files I posted, you can see several emulators listed as possible 'launch' candidates separated by "|".    It will attempt to launch the first emulator listed, if it's not installed, it will go to the next.    I have examples of syntax for various emulators posted here:   http://www.hyperspin-fe.com/topic/8537-settings-android-emulator-settings/
Is there a way of using "|" to set a string of emulator's, so that you could have a mixed folder of ROMs (GB,SNES,n64,etc) and then it would go through the emulator (exe=,parameter lines) until it found the correct one, or is this not possible???
It might be possible IIF the roms had extensions that dictated which .emu should be launched.   This is not supported at the moment.
