retroarch stopped working
jrose1184
Hi, i downloaded retroarch from the austin video and as soo as i launch it it says "stopped working" i can see in the back ground in the cmd that it says "failed to bind api".
I then downloaded the latest stabble version and still get the same error? If any one could help that would be great.
this is out side of hyperspin
running windows 7, have direct x installed, and other emulator work
Hi yes just from the retroarch folder it self, wether i run it on rlauncher or desktop still same error. Were would i find the stable version on here please?
o is see my bad lol, yes the stable one from the web site does the same no diffrence between the two. i open the .exe and straight away says "stopped working" pc is a fresh install with windows 7 all updates done. i can run mame elulator fine with hyper spin. so i dont know....
Do you have any anti virus protection on your pc? Maybe it's deleting or stopping something from working.
Are you able to open it to the settings screen at all?
i have no anti virus on the pc, i downloaded stable 1.3.2. it crashes the second its open, so can not get to no menu. would you like a pic?
im going to try a fresh windows install i have a build in graphic at 256mb could that be a problem its a ati radeon 3100, but i can run mame snes nes ect.. all fine on there own emulators
ok i reinstalled it to win 7 32bit instead off 64bit,.... same problem
bought a geforce 8800s graphic card just to check if it needs a its own graphics... same again
any one know what else i could try. i only have mac computers so cant try on another windows machine and both macs ar ssd so cant install windows due to size
This is usually a video driver issue. Try one of these and let us know the results.
1. rename name retroarch.cfg to retroarch.cfg.org and run retroarch (this will force a new retroarch.cfg to be created)
2. open your retroarch.cfg in a text editor and change "video_driver = "gl"" to "video_driver = "sdl2"" and run retroarch
3. open an admin command prompt and run retroarch.exe from there so you can see what is actually happening
https://www.microsoft.com/en-us/download/details.aspx?id=8109 i had to download this and restart windows then try out retroarch...make sure all your drivers and vc++ files are installed also...
I hope this helps..if not hit me up ill help when i can..:) happy hyperspinning
ok i tryed downloading the dirext x link, no fix. did every think that progets said.... same error, i have no anti virus installed and uac is off
Case Closed was the graphics card unistalled it again then got latest one now it works dont know why it worked second time tho? thank you every one for your help
