Hyperspin 1.4 not calling start program?
xantari
I have randomizer set to rotate the intro videos.
If I run randomizer manually it rotates the videos just fine,
However hyperspin doesn't seem to be calling it properly.
The log file indicates it is being called properly though, which is wierd.
Anyone else have issues with randomizer and HS 1.4?
Use HyperSpin Startup Script as an alternative? Only start HyperSpin Startup Script in HyperHQ, then configure HyperSpin Startup Script to start the randomizer.
Sorry for the delay.
here is the log:
05:47:16 PM |  HyperSpin Started
05:47:16 PM |  Going FullScreen
05:47:16 PM |  LEDBlinky is set to active
05:47:16 PM |  Found LEDBlinky.exe
05:47:16 PM |  Running LEDBlinky
05:47:17 PM |  Command Line is: "D:\HyperSpin\LEDBlinky\LEDBlinky.exe" 1
05:47:17 PM |  Checking for updates
05:47:17 PM |  Update Check Complete
05:47:17 PM |  Startup program: Randomizer.exe
05:47:17 PM |  Startup params: 1
05:47:17 PM |  Working directory: D:\HyperSpin\
05:47:17 PM |  Window State: NORMAL
05:47:17 PM |  Launching Randomizer.exe
05:47:17 PM |  Command Line is Randomizer.exe 1
05:47:19 PM |  Playing intro video
05:47:23 PM |  Error intializing joysticks
05:47:23 PM |  Menu Mode is multi
05:47:23 PM |  Loading Main Menu.xml
05:47:23 PM |  Main Menu.xml successfully loaded
05:47:23 PM |  Main Menu wheel loaded successfully
05:47:24 PM |  Command Line is: "D:\HyperSpin\LEDBlinky\LEDBlinky.exe" 8
05:47:24 PM |  Loading Super Nintendo Entertainment System.xml
05:47:24 PM |  Command Line is: "D:\HyperSpin\LEDBlinky\LEDBlinky.exe" 7 "Super Nintendo Entertainment System"
05:47:24 PM |  Main Menu.xml successfully loaded
Here is screenshot.
