gertrude_34 Posted September 30, 2013 Posted September 30, 2013 Hi, just to say that I found a solution to make work relative path with video : http://www.hyperspin-fe.com/forum/showthread.php?12509-Relative-Path-for-Videos-not-working
tattoopete84 Posted December 8, 2013 Posted December 8, 2013 How do I set up Relative Paths with RocketLauncher installed? I know that HyperHQ has options for relative paths, but I haven't seen those same options in HyperLaunchHQ. Can I just use the HyperHQ settings to make this work? Also - I'm having a very hard time finding the information about what the difference between ".\" and "..\" are (google is failing me), and which option I should choose. I know they're relative, but relative to what??? HyperLaunch? The exe for the that emulator? I don't get it. I have my folder structure setup the same as the HS setup tutorials. example 1- E:\Hyperspin\Emulators\Mame\mame.exe example 2- E:\Hyperspin\Hyperlaunch\HyperLaunch.exe I have no real life DOS experience. Any help is greatly appreciated. Thanks in advance! My Professional Tattoo Portfolio: https://www.facebook.com/media/set/?set=a.234510614736.131894.234499559736 My latest Free DJ mix download: https://soundcloud.com/insectorx/insector-x-invade-pensacola
ghutch92 Posted December 8, 2013 Posted December 8, 2013 .\ means same folder as HyperLaunch.exe ..\ means up one directory from HyperLaunch.exe ..\..\ means up two directories from HyperLaunch.exe example1 translates to ..\Emulators\Mame\mame.exe example2 translates to .\HyperLaunch.exe HyperLaunchHQ automatically uses relative paths when writing the settings for HyperLaunch so no need for by-hand translating. Use the magnifying glass next to the path requests in HLHQ and you'll be fine. HyperHQ technically doesn't support relative paths. The video path is definable, but it is not relative. All the other paths you can't define. How to Install HyperSpin and more RocketLauncher HyperSpin Startup Script
brolly Posted December 8, 2013 Posted December 8, 2013 HyperLaunchHQ automatically uses relative paths when writing the settings for HyperLaunch so no need for by-hand translating. Use the magnifying glass next to the path requests in HLHQ and you'll be fine. Unless you change that setting in the HLHQ tab that is.
Dogway Posted March 27, 2014 Posted March 27, 2014 Is there a way to write relative paths in HyperSpin (not using HyperLaunch)? I tried with everything .\ ..\ %CD% etc and no success. I tried some combinations that didn't work, but copied the command line from log, executed from the HyperSpin folder and worked flawlessly so I don't know what else to try. edit: nevermind, sorted myself.
