Getting HyperSpin to Load at Startup
Wob
Just wondering if anyone has had any success getting HyperSpin to load at startup, I can run it find manually but if I try and add it to my "Run" list in the registry so that it loads at startup or I have also tried setting it as my shell, this is my prefered method as it means I don't have to waste memory with explorer.
I get a similar result to the people in the "Hyperspin not working at all" thread. HyperSpin is running but only shows a black screen, there is nothing in the log file and if I kill the task and manually rerun it it loads fine, even if explorer.exe is not running.
Cheers,
Beau
Yeah that works, always the simple solution. I would still like to run it as my shell so that I don't have to load explorer, does anyone know how I might go about debuging it?
To set it as the Shell,
1. Open Regedit.
2. Navigate to \\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
3. Change Shell Key from Explorer.exe to C:\Hyperspin\Hyperspin.exe
4. Reboot
When the system comes back up and see a black screen with a mouse pointer, I hit Ctrl-Alt-Del and launch taskmanager, I can see hyperspin.exe running, trying to switch to the task does nothing. I can kill the task and rerun it via the run command in taskmanager and it launches fine.
Thanks for the help,
Beau
Did you change this from
SYS:Microsoft\Windows NT\CurrentVersion\Winlogon to
USR:Microsoft\Windows NT\CurrentVersion\Winlogon
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\IniFileMapping\system.ini\boot
Its the string named shell
also make sure you run control userpasswords2 to disable the password login if you have one that pops up
Thanks for the Tip, I changed that Regkey but no chance, password is disabled and I have it spelled HyperSpin.exe in my registry but it shouldn't be case sensitive anyway.
I am running MicroXP, not sure if that's causing problems.
You need to specify a full path..
"c:\frontends\hyperspin\hyperspin.exe"
Your path is diffrent im sure but I hope that helps.
You must defeat Sheng Long to stand a chance.
Ahhh, I am "C:\Hyperspin\Hyperspin.exe" as mentioned above.
It's loading HyperSpin, I can see the task running, it just doesn't show anything, I just get a blank screen. Strange this is that if I kill the task and relaunch it then everything works fine.
its probably loading before other dependency's.
does your display driver load in the taskbar? err driver control panel.
Make a AHK script that waits 5 seconds before running HS would do the trick. then use the script as the shell
Thanks guys, I'll give the delay a try. My exit program is going to be shutdown once I have it all sorted. Ctrl-Alt-Del will get to to explorer should I need it :)
No Joy, I even blew the delay out to 20 seconds to make sure, Still nothing being produced in the logs. I guess for now I'll live with loading explorer as the shell and loading hyperspin via the startup folder.
  • 3 months later...
I can't do either! I've checked, double checked and triple checked and it doesn't work for me. In both cases (running as a shell and in the startup folder) nothing loads, but when I load task manager, hyperspin.exe is listed as a running program. Hyperspin runs perfectly if I run normally.
edit: I can run from the startup folder. but it'd still be nice to run this as shell
interestingly enough i get the same black screen w/ mouse pointer you guys referred to w/ hyperspin listed as running according to the taskbar if i run hyperspin via desktop shortcut
  • 5 years later...
Have people not just tried the group policy that's available in pro and above versions of Windows 7 & 8?
