lilg1983 Posted August 20, 2013 Posted August 20, 2013 Ok first things first this is the way I had got silverjuke to work in Hyperspin first off you will need to get the program called silverjuke there is a free trial version if you Google it next you will need to click your hyperHQ and go through the steps of adding a new system click main menu wizard type Jukebox click next after it will ask you if this menu item has a sub wheel click yes place the jukebox wheel image wherever you want to on the wheel I placed mine right under Atari Lynx it will tell you it has been set up minus out hyperHQ for the time being Next create a folder inside your emulators folder for HyperSpin called Jukebox in that folder create another folder called Roms I did this to make sure it worked right next you will need all of the mp3 songs you will want to play in HyperSpin these Mp3's will show up on your wheel so name them all as you want them to show place them in the HyperSpin folder emulators/jukebox/roms next you need the program called HyperROM2XML open HyperROM2XML where it says rom directory click to add directory and choose C:\Hyperspin arcade\Emulators\Jukebox\Roms where it says save as Hyperspin database xml there is a button to choose a folder to save it to this is where it should be saved C:\Hyperspin arcade\Databases\Jukebox save it as Jukebox.xml now you have your xml file for Silverjuke now you need an ahk File all I did was get the ahk file from the nintendo 64 modules folder and named it Jukebox.ahk in the modules folder creat a folder called Jukebox place the nintendo 64 ahk file in Jukebok folder go back to the emulators folder jukebox and place silverjuke into the folder go back to Hyper HQ and go to Jukebok and set the exe file to C:\Hyperspin arcade\Emulators\Jukebox Silverjuke.exe under extensions type in mp3 exit Hyper HQ and open Hyperspin click Jukebox it will now load a new wheel with all of your Mp3 songs on it it will have the name of the song when you click the song it will open up Silverjuke inside of Hyperspin to exit just press esc key you are back into Hyperspin I hope this helps out everyone if you have any questions please feel free to ask
Natdiamond Posted September 28, 2013 Posted September 28, 2013 Well, I tried this but I couldn't get the module part of it squared away. So I went with the dwjukebox module and just renamed my Silverjuke.exe to dwjukebox.exe. It loaded silverjuke right away but then after a minute after it started I got the ahk "waiting for" error screen. So I removed: WinWait("DWJukebox ahk_class AllegroWindow") WinWaitActive("DWJukebox ahk_class AllegroWindow") from the ahk file and now it loads silverjuke no problem. I'm using the free trial version so far. I have to tweak some stuff like escape to exit silverjuke and kiosk/fullscreen right away but I guess that doesn't come with the trial version.
