mattyb425 Posted April 11, 2016 Posted April 11, 2016 finally got all my games for snes to show up in hyperspin, but I cant get the games to run, keep getting error that it cant fins snes9x.conf. I googled it, and came up with what looked like a settings file, but I have no idea how to copy it and make it into a file that is readable by hyperspin... hoping its something simple lol
mattyb425 Posted April 11, 2016 Author Posted April 11, 2016 did that, it now in the folder for the emulator, but its still giving me the same error when trying to lauch the rom through rocket launcher
mattyb425 Posted April 12, 2016 Author Posted April 12, 2016 Ive actually run into a separate problem while trying to fix this problem. I'm pretty sure it found the conf, file, but now I'm getting an error message that it cant find the emulator even though I know its pointed in the right direction. so I decided to try and run a game through the emulator, and I get a black screen. is it possible that the rom set I got was for a 64 bit system and wont run on the 32 bit version of snes9x?
Metalzoic Posted April 12, 2016 Posted April 12, 2016 so I decided to try and run a game through the emulator, and I get a black screen. You should always make sure your emulators are setup correctly and running right before you try to run them through HS/RL.
mattyb425 Posted April 12, 2016 Author Posted April 12, 2016 Yea.... just learned that the hard way lol. I had for all the other systems, and it was a mix of being cocky and impatient lol Sent from my SM-N900V using Tapatalk
mattyb425 Posted April 12, 2016 Author Posted April 12, 2016 looks like it was a bad rom set. ran a few roms that I downloaded on by one, and they run fine, still cant launch them through rocket launcher, still says it cant find the emulator. going to just have to tinker for a while I suppose.
mattyb425 Posted April 12, 2016 Author Posted April 12, 2016 Why not just use retroarch?I originally did try to use retroarch but couldn't get it going. I needed the 32 bit version and when I downloaded it, all the cores were missing. Tried to download the cores and it still wasn't working. So I wanted to make sure it wasn't the roms that were the problem, so I downloaded a few standalone emulators. Those worked to run the roms so I just decided to stick with themSent from my SM-N900V using Tapatalk
mattyb425 Posted April 12, 2016 Author Posted April 12, 2016 Make sure that the path to the snes9x exe is set correctly on the Global -> Emulators tab in RLUI. That's the only thing I know of that triggers that error.Bingo, that was the problem! Everything is working as it should. Thanks again for all the helpSent from my SM-N900V using Tapatalk
Metalzoic Posted April 12, 2016 Posted April 12, 2016 I originally did try to use retroarch but couldn't get it going. I needed the 32 bit version and when I downloaded it, all the cores were missing. Tried to download the cores and it still wasn't working. So I wanted to make sure it wasn't the roms that were the problem, so I downloaded a few standalone emulators. Those worked to run the roms so I just decided to stick with them Sent from my SM-N900V using Tapatalk The day I deleted Retroarch entirely from my cab was the 3rd happiest day of my life.
mattyb425 Posted April 12, 2016 Author Posted April 12, 2016 The day I deleted Retroarch entirely from my cab was the 3rd happiest day of my life.I'm sure it's good once you get it going, but for a newcomer like me, there are enough roadblocks along the way... no need for me to add another when there are easier roads to take lolSent from my SM-N900V using Tapatalk
mattyb425 Posted April 12, 2016 Author Posted April 12, 2016 Make sure that the path to the snes9x exe is set correctly on the Global -> Emulators tab in RLUI. That's the only thing I know of that triggers that error.I spoke too soon. Rocket launcher recognizes the games, I can launch them through rocket launcher, but when I try to get into my snes wheel in hyperspin, it kicks me back out to the main wheel. I have navigation in hyperhq set to roms and wheels only. If I take off those permissions, I can get into the snes wheel, but it shows every game I have a wheel image for... and that's alot of them lolSent from my SM-N900V using Tapatalk
mattyb425 Posted April 13, 2016 Author Posted April 13, 2016 If you're using the Roms Only filter in HyperHQ you have to set your rom path and extensions in HyperHQ also. Otherwise it will kick you back to the main menu when you try to enter the wheel.When setting extensions in hyperhq, do you still list them as 7z|zip|rar etc... I have all the extensions set, rom path is set, but it's still kicking me outSent from my SM-N900V using Tapatalk
ChrisKant Posted May 25, 2016 Posted May 25, 2016 finally got all my games for snes to show up in hyperspin, but I cant get the games to run, keep getting error that it cant fins snes9x.conf. I googled it, and came up with what looked like a settings file, but I have no idea how to copy it and make it into a file that is readable by hyperspin... hoping its something simple lol i have the same problem. Rocket launcher tells me "cannot find Snes9x.conf" but this file IS in the emulator folder from SNES9x. the emulator works great outside from hyper spin. the Troubleshooting Log from RL just tells me "script Error - Cannot find /snes9x.conf" any Idea would you like to have the full trouble shooting log?
ChrisKant Posted May 25, 2016 Posted May 25, 2016 20:07:36:747 | RL | INFO | +N/A | Main - RocketLauncher v1.1.0.7 (www.rlauncher.com) 20:07:36:818 | RL | INFO | +78 | Main - System Specs: RocketLauncher Dir: C:\Hyperspin\RocketLauncher RocketLauncher is: 32-bit OS: Microsoft Windows 10 Home SKU: Windows 8 Total Memory: 16332.80 MB Free Memory: 13717.55 MB Used Memory: 2615.250 MB SystemType: 64-bit Physical Processors: 1 Logical Processors: 4 GPU 1 Name: NVIDIA GeForce GTX 970 GPU 1 RAM: -1.00 MB GPU 1 Driver Version: 10.18.13.6519 Sound 1 Device: NVIDIA High Definition Audio Sound 1 Status: Enabled Sound 2 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM) Sound 2 Status: Enabled Sound 3 Device: Realtek High Definition Audio Sound 3 Status: Enabled OS Language: German_Standard System Locale: de-DE Formats Locale: de-DE Windows UI Language: de-DE Text Encoding: Windows-1252 OS Admin Status: No RL Compatibility Flags: Latest .Net Version: v4.0.30319 Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1040 work) [32bit] [60hz] [Landscape] (Primary) Current AHK Desktop Width: 1920 Current AHK Desktop Height: 1080 Monitor #1 DPI: 100 AutoHotkey Path: AHK Version: 1.1.09.04 Unicode: No 20:07:36:819 | RL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\RocketLauncher\RocketLauncher.exe exists 20:07:36:821 | RL | TRACE | +0 | File.__New - Creating new file object of: "C:\Hyperspin\RocketLauncher\Module Extensions\RocketLauncher.dll" 20:07:36:823 | RL | INFO | +0 | File.CheckFile - Checking if "C:\Hyperspin\RocketLauncher\Module Extensions\RocketLauncher.dll" exists 20:07:36:823 | RL | TRACE | +0 | File.Exist - This file exists: C:\Hyperspin\RocketLauncher\Module Extensions\RocketLauncher.dll 20:07:36:828 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Extension: C:\Hyperspin\RocketLauncher\Module Extensions\Array.ahk 20:07:36:831 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Module Extensions\BinHexRW.ahk | v1.0.2 20:07:36:831 | RL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\RocketLauncher\Module Extensions\BlockInput.exe exists 20:07:36:833 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Extension: C:\Hyperspin\RocketLauncher\Module Extensions\CLR_L.ahk | vInterop 20:07:36:833 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Extension: C:\Hyperspin\RocketLauncher\Module Extensions\Control_AniGif.ahk | vAniGif.ahk 20:07:36:839 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Extension: C:\Hyperspin\RocketLauncher\Module Extensions\gdip.ahk 20:07:36:842 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Module Extensions\gdip_alt.ahk | v1.0.3 20:07:36:842 | RL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\RocketLauncher\Module Extensions\gsdll32.dll exists 20:07:36:843 | RL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\RocketLauncher\Module Extensions\itextsharp.dll exists 20:07:36:847 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Module Extensions\Java.ahk | v1.0.0 20:07:36:849 | RL | INFO | +15 | CRC Check - CRC matches, this is an official unedited Extension: C:\Hyperspin\RocketLauncher\Module Extensions\JSON.ahk 20:07:36:851 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Module Extensions\Origin.ahk | v1.0.2 20:07:36:853 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Extension: C:\Hyperspin\RocketLauncher\Module Extensions\RegRW64.ahk 20:07:36:855 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Extension: C:\Hyperspin\RocketLauncher\Module Extensions\RIni.ahk | v1.7 20:07:36:856 | RL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\RocketLauncher\Module Extensions\SevenZipSharp.dll exists 20:07:36:859 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Module Extensions\Steam.ahk | v1.0.3 20:07:36:861 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Extension: C:\Hyperspin\RocketLauncher\Module Extensions\VA.ahk 20:07:36:862 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Module Extensions\VA_Extension.ahk | v1.0.1 20:07:36:862 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\7z.ahk | v1.0.8 20:07:36:868 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Bezel.ahk | v1.2.3 20:07:36:871 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Fade.ahk | v1.1.8 20:07:36:873 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Fade Init.ahk | v1.0.3 20:07:36:875 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Fade Animations.ahk | v1.2.2 20:07:36:877 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Keymapper.ahk | v1.1.5 20:07:36:879 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Keymapper Init.ahk | v1.0.6 20:07:36:881 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\MultiGame.ahk | v1.1.0 20:07:36:882 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\MultiGame Init.ahk | v1.0.0 20:07:36:885 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\MultiPlayer.ahk | v1.0.8 20:07:36:891 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Pause.ahk | v1.2.3 20:07:36:893 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Pause Init.ahk | v1.0.3 20:07:36:895 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Password.ahk | v1.0.4 20:07:36:896 | RL | INFO | +15 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Classes\DLL\RocketLauncher.ahk | v1.7 20:07:36:899 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Classes\Log\Logger.ahk | v1.1 20:07:36:901 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Classes\Util\MiscUtils.ahk | v1.1 20:07:36:902 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Classes\Util\Environment\Registry.ahk | v1.0 20:07:36:903 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Classes\Util\Environment\StringUtils.ahk | v1.5 20:07:36:903 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Classes\Util\Environment\TimerUtils.ahk | v1.0 20:07:36:903 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Classes\Util\File\File.ahk | v1.5 20:07:36:909 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Classes\Util\File\Folder.ahk | v1.0 20:07:36:910 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Classes\Util\File\IniFile.ahk | v1.0 20:07:36:912 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Classes\Util\File\RIniFile.ahk | v1.0 20:07:36:913 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Classes\Util\File\Process.ahk | v1.5 20:07:36:913 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Classes\Util\File\Emulator.ahk | v1.1 20:07:36:918 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Classes\Util\Input\KeyUtils.ahk | v1.0 20:07:36:920 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Classes\Util\UI\Control.ahk | v1.2 20:07:36:922 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Classes\Util\UI\Window.ahk | v1.2 20:07:36:923 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Classes\Util\UI\WindowTitle.ahk | v1.0 20:07:36:923 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Rom Mapping Launch Menu.ahk | v1.0.7 20:07:36:923 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Shader.ahk | v1.0.1 20:07:36:929 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Shader Init.ahk | v1.0.0 20:07:36:933 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Shared.ahk | v1.4.5 20:07:36:933 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Statistics.ahk | v1.0.4 20:07:36:933 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Statistics Init.ahk | v1.0.1 20:07:36:938 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Virtual Drive.ahk | v1.0.5 20:07:36:940 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\XHotkey.ahk | v1.0.4 20:07:36:942 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\XHotkey Init.ahk | v1.0.2 20:07:36:942 | RL | INFO | +0 | Main - Raw CLI received: "-s Super Nintendo Entertainment System -r Super Street Fighter II (USA) -f C:\Hyperspin\HyperSpin.exe -p HyperSpin -c 1 -o 1" 20:07:36:942 | RL | DEBUG | +0 | Main - Received this dbName with no path via CLI: "Super Street Fighter II (USA)" 20:07:36:943 | RL | DEBUG | +15 | Main - dbName: Super Street Fighter II (USA) 20:07:36:943 | RL | INFO | +0 | Main - Loading Front End Plugin: "HyperSpin" 20:07:36:943 | RL | TRACE | +0 | Process.__New - Creating new process object for: "C:\Hyperspin\HyperSpin.exe" 20:07:36:943 | RL | TRACE | +0 | File.__New - Creating new file object of: "C:\Hyperspin\HyperSpin.exe" 20:07:36:943 | RL | INFO | +0 | Main - RocketLauncher received "Super Nintendo Entertainment System" and "Super Street Fighter II (USA)" 20:07:36:950 | RL | INFO | +0 | Main - Did not find a "C:\Hyperspin\RocketLauncher\Settings\Super Nintendo Entertainment System\Game Options.ini" file, skipping any game-specific options. 20:07:36:950 | RL | INFO | +0 | Main - Super Street Fighter II (USA) is using the default emulator: Snes9x 20:07:36:951 | RL | INFO | +0 | Main - Checking for a [Snes9x] section in C:\Hyperspin\RocketLauncher\Settings\Super Nintendo Entertainment System\Emulators.ini 20:07:36:951 | RL | INFO | +0 | Main - Found [Snes9x] in C:\Hyperspin\RocketLauncher\Settings\Super Nintendo Entertainment System\Emulators.ini 20:07:36:952 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converting "Snes9x.ahk" 20:07:36:953 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converted to "C:\Hyperspin\RocketLauncher\Modules\Snes9x\Snes9x.ahk" 20:07:36:953 | RL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\RocketLauncher\Modules\Snes9x\Snes9x.ahk exists 20:07:36:953 | RL | INFO | +0 | Main - CRC Check - CRC matches, this is an official unedited module. 20:07:36:953 | RL | INFO | +0 | Main - Super Street Fighter II (USA) will use module: C:\Hyperspin\RocketLauncher\Modules\Snes9x\Snes9x.ahk 20:07:36:953 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converting ".\Profiles" 20:07:36:958 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converted to "C:\Hyperspin\RocketLauncher\Profiles" 20:07:36:958 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converting "E:\Roms" 20:07:36:959 | RL | TRACE_DLL | +16 | RLDLL.getFullPathFromRelative - Converted to "E:\Roms" 20:07:36:960 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converting "..\..\Program Files (x86)\DAEMON Tools Lite\DTLite.exe" 20:07:36:961 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converted to "C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe" 20:07:36:962 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converting "..\..\Program Files\7-Zip\7z.exe" 20:07:36:962 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converted to "C:\Program Files\7-Zip\7z.exe" 20:07:36:962 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converting "C:\Hyperspin\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe" 20:07:36:962 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converted to "C:\Hyperspin\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe" 20:07:36:962 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converting ".\Module Extensions\HiToText.exe" 20:07:36:962 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converted to "C:\Hyperspin\RocketLauncher\Module Extensions\HiToText.exe" 20:07:36:962 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converting "..\Tools\XPadder\Xpadder.exe" 20:07:36:968 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converted to "C:\Hyperspin\Tools\XPadder\Xpadder.exe" 20:07:36:969 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converting "..\Tools\JoyToKey\JoyToKey.exe" 20:07:36:970 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converted to "C:\Hyperspin\Tools\JoyToKey\JoyToKey.exe" 20:07:36:970 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converting "..\Tools\JoyToKey\JoyToKey.exe" 20:07:36:972 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converted to "C:\Hyperspin\Tools\JoyToKey\JoyToKey.exe" 20:07:36:979 | RL | TRACE_DLL | +15 | RLDLL.getFullPathFromRelative - Converting "..\TEMP" 20:07:36:980 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converted to "C:\Hyperspin\TEMP" 20:07:36:983 | RL | INFO | +0 | Main - Using SkipChecks method "Rom and Emu" or emuName = "PCLauncher". 20:07:36:984 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converting "E:\Roms\Super Nintendo Entertainment System" 20:07:36:984 | RL | TRACE_DLL | +0 | RLDLL.getFullPathFromRelative - Converted to "E:\Roms\Super Nintendo Entertainment System" 20:07:36:985 | RL | INFO | +0 | Main - INI Keys read 20:07:36:986 | RL | INFO | +0 | CheckFile - Checking if C:\Program Files\7-Zip\7z.exe exists 20:07:36:987 | RL | INFO | +0 | CheckFile - Checking if C:\Program Files\7-Zip\7z.dll exists 20:07:36:991 | RL | INFO | +16 | Main - "Super Street Fighter II (USA)" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side 20:07:36:991 | RL | WARNING | +N/A | Main - SkipChecks is enabled and set to: Rom and Emu 20:07:36:992 | RL | INFO | +0 | CheckPaths - Started 20:07:36:992 | RL | INFO | +0 | CheckPaths - Looking for rom: E:\Roms\Super Nintendo Entertainment System\Super Street Fighter II (USA).sms 20:07:36:993 | RL | INFO | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Roms\Super Nintendo Entertainment System\Super Street Fighter II (USA)\Super Street Fighter II (USA).sms 20:07:36:993 | RL | INFO | +0 | CheckPaths - Looking for rom by extension: E:\Roms\Super Nintendo Entertainment System\Super Street Fighter II (USA)\*.sms 20:07:36:993 | RL | INFO | +0 | CheckPaths - Looking for rom: E:\Roms\Super Nintendo Entertainment System\Super Street Fighter II (USA).zip 20:07:36:993 | RL | INFO | +0 | CheckPaths - Found rom: E:\Roms\Super Nintendo Entertainment System\Super Street Fighter II (USA).zip 20:07:36:994 | RL | DEBUG | +0 | CheckPaths - Current romName: Super Street Fighter II (USA) 20:07:36:994 | RL | DEBUG | +0 | CheckPaths - Current romPath: E:\Roms\Super Nintendo Entertainment System 20:07:36:994 | RL | DEBUG | +0 | CheckPaths - Current romExtension: .zip 20:07:36:994 | RL | INFO | +0 | CheckPaths - Ended 20:07:36:995 | RL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 20:07:36:995 | RL | INFO | +0 | BuildScript - Loaded Keymapper Init.ahk scripts 20:07:36:996 | RL | INFO | +0 | BuildScript - Loaded Pause Init.ahk scripts 20:07:36:996 | RL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 20:07:36:996 | RL | WARNING | +0 | BuildScript - "C:\Hyperspin\RocketLauncher\Lib\User Functions Init.ahk" not found 20:07:36:997 | RL | DEBUG | +0 | BuildScript - Module starts on line: 2 20:07:36:997 | RL | INFO | +0 | BuildScript - Validating module 20:07:36:998 | RL | INFO | +0 | BuildScript - Validation complete 20:07:36:008 | RL | INFO | +16 | BuildScript - Loaded Pause scripts 20:07:37:010 | RL | INFO | +0 | BuildScript - Loaded Multi-Player scripts 20:07:37:011 | RL | INFO | +0 | BuildScript - Loaded Statistics.ahk script 20:07:37:012 | RL | WARNING | +0 | BuildScript - "C:\Hyperspin\RocketLauncher\Lib\User Functions.ahk" not found 20:07:37:012 | RL | INFO | +0 | BuildScript - Finished injecting functions into module 20:07:37:013 | RL | INFO | +0 | Main - Module is built 20:07:37:013 | RL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\RocketLauncher\AutoHotkey.dll exists 20:07:37:018 | RL | INFO | +0 | Main - Starting timer to watch if Front End gets displaced and restore it if it does. 20:07:37:018 | RL | INFO | +0 | Main - Running module 20:07:37:153 | MD | INFO | +N/A | Module initialized 20:07:37:158 | MD | TRACE | +0 | XHotkeyTableCreation - Started 20:07:37:159 | MD | TRACE | +0 | XHotkeyTableCreation - KeyGroup ~Esc not in TableKeyGroups 20:07:37:159 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 1 check 20:07:37:159 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 2 check 20:07:37:160 | MD | TRACE | +0 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess" 20:07:37:160 | MD | TRACE | +0 | XHotkeyTableCreation - Ended 20:07:37:161 | MD | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Tools\JoyToKey\JoyToKey.exe exists 20:07:37:182 | MD | INFO | +32 | Keymapper - Loading joytokey 20:07:37:182 | MD | INFO | +0 | RunKeymapper - Started, using method "load" 20:07:37:183 | MD | INFO | +0 | GetJoystickArray - Started 20:07:37:222 | MD | TRACE | +31 | GetJoystickArray - Joysticks Detected: 1111111000000000 20:07:37:244 | MD | INFO | +31 | GetJoystickGUID - Started 20:07:37:245 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: 400C3FD23D0EE6118001444553540000 20:07:37:246 | MD | TRACE | +0 | GetJoystickArray - ID: 1 | Port: 0 | Name: Controller (Xbox One For Windows) | MID: 045e | PID: 02ff | GUID: 400C3FD23D0EE6118001444553540000 20:07:37:249 | MD | INFO | +0 | GetJoystickGUID - Started 20:07:37:249 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: E0877E83931FE6118002444553540000 20:07:37:250 | MD | TRACE | +0 | GetJoystickArray - ID: 2 | Port: 1 | Name: Mayflash Wiimote PC Adapter | MID: 057e | PID: 0306 | GUID: E0877E83931FE6118002444553540000 20:07:37:253 | MD | INFO | +0 | GetJoystickGUID - Started 20:07:37:253 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: F0AE7E83931FE6118003444553540000 20:07:37:253 | MD | TRACE | +0 | GetJoystickArray - ID: 3 | Port: 2 | Name: Mayflash Wiimote PC Adapter | MID: 057e | PID: 0306 | GUID: F0AE7E83931FE6118003444553540000 20:07:37:253 | MD | INFO | +0 | GetJoystickGUID - Started 20:07:37:278 | MD | INFO | +31 | GetJoystickGUID - Ended and found GUID: 10FD7E83931FE6118004444553540000 20:07:37:279 | MD | TRACE | +0 | GetJoystickArray - ID: 4 | Port: 3 | Name: Mayflash Wiimote PC Adapter | MID: 057e | PID: 0306 | GUID: 10FD7E83931FE6118004444553540000 20:07:37:281 | MD | INFO | +0 | GetJoystickGUID - Started 20:07:37:283 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: A0EB7D83931FE6118001444553540000 20:07:37:283 | MD | TRACE | +0 | GetJoystickArray - ID: 5 | Port: 4 | Name: Mayflash Wiimote PC Adapter | MID: 057e | PID: 0306 | GUID: A0EB7D83931FE6118001444553540000 20:07:37:286 | MD | INFO | +0 | GetJoystickGUID - Started 20:07:37:308 | MD | INFO | +32 | GetJoystickGUID - Ended and found GUID: 107630419590E5118001444553540000 20:07:37:309 | MD | TRACE | +0 | GetJoystickArray - ID: 6 | Port: 5 | Name: Controller (Xbox 360 Wireless Receiver for Windows) | MID: 045e | PID: 02a1 | GUID: 107630419590E5118001444553540000 20:07:37:311 | MD | INFO | +0 | GetJoystickGUID - Started 20:07:37:312 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: 8068CD559590E5118002444553540000 20:07:37:312 | MD | TRACE | +0 | GetJoystickArray - ID: 7 | Port: 6 | Name: Controller (Xbox 360 Wireless Receiver for Windows) | MID: 045e | PID: 02a1 | GUID: 8068CD559590E5118002444553540000 20:07:37:312 | MD | INFO | +0 | GetJoystickArray - Ended 20:07:37:312 | MD | TRACE | +0 | RunKeymapper - Found your keymapper application here: "C:\Hyperspin\Tools\JoyToKey\JoyToKey.exe" 20:07:37:312 | MD | TRACE | +0 | RunKeymapper - Looping through controllers to find joytokey profiles for each one 20:07:37:312 | MD | TRACE | +0 | GetProfile - Searching for these profiles (| delimited): C:\Hyperspin\RocketLauncher\Profiles\joytokey\Super Nintendo Entertainment System\Super Street Fighter II (USA)\Super Street Fighter II (USA)|C:\Hyperspin\RocketLauncher\Profiles\joytokey\Super Nintendo Entertainment System\Snes9x\Snes9x|C:\Hyperspin\RocketLauncher\Profiles\joytokey\Super Nintendo Entertainment System\Super Nintendo Entertainment System|C:\Hyperspin\RocketLauncher\Profiles\joytokey\_Default\_Default 20:07:37:312 | MD | TRACE | +0 | GetProfile - Searching for a Player 1 profile -> C:\Hyperspin\RocketLauncher\Profiles\joytokey\Super Nintendo Entertainment System\Super Street Fighter II (USA)\Super Street Fighter II (USA).cfg 20:07:37:312 | MD | TRACE | +0 | GetProfile - Searching for a Player 1 profile -> C:\Hyperspin\RocketLauncher\Profiles\joytokey\Super Nintendo Entertainment System\Snes9x\Snes9x.cfg 20:07:37:312 | MD | TRACE | +0 | GetProfile - Searching for a Player 1 profile -> C:\Hyperspin\RocketLauncher\Profiles\joytokey\Super Nintendo Entertainment System\Super Nintendo Entertainment System.cfg 20:07:37:339 | MD | TRACE | +31 | GetProfile - Searching for a Player 1 profile -> C:\Hyperspin\RocketLauncher\Profiles\joytokey\_Default\_Default.cfg 20:07:37:340 | MD | WARNING | +0 | GetProfile - Keymapper support is enabled for "joytokey", but could not find a "Super Street Fighter II (USA)", "Snes9x", "Super Nintendo Entertainment System", default, a "" player 1 profile or a blank profile in "C:\Hyperspin\RocketLauncher\Profiles\joytokey" for controller "" 20:07:37:340 | MD | INFO | +0 | RunJoyToKey - Started 20:07:37:341 | MD | INFO | +0 | Process - Exist Xpadder.exe 20:07:37:343 | MD | INFO | +0 | WinClose - Closing: JoyToKey ahk_class TMainForm 20:07:39:463 | MD | INFO | +2125 | Process - WaitClose JoyToKey.exe 2 20:07:41:547 | MD | INFO | +2078 | Process - Close JoyToKey.exe 20:07:41:575 | MD | INFO | +31 | RunJoyToKey - Ended 20:07:41:576 | MD | INFO | +0 | RunKeymapper - Ended 20:07:41:579 | MD | TRACE | +0 | XHotkeyTableCreation - Started 20:07:41:580 | MD | TRACE | +0 | XHotkeyTableCreation - KeyGroup ~1 not in TableKeyGroups ~Esc, 20:07:41:581 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 1 check 20:07:41:583 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 2 check 20:07:41:609 | MD | TRACE | +31 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~1" to call label: "TogglePauseMenuStatus" 20:07:41:610 | MD | TRACE | +0 | XHotkeyTableCreation - Ended 20:07:41:612 | MD | TRACE | +0 | XHotkeyTableCreation - Started 20:07:41:613 | MD | TRACE | +0 | XHotkeyTableCreation - KeyGroup PrintScreen not in TableKeyGroups ~Esc,~1, 20:07:41:614 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 1 check 20:07:41:637 | MD | TRACE | +32 | XHotkeyTableCreation - Post loop 2 check 20:07:41:638 | MD | TRACE | +0 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "PrintScreen" to call label: "SaveScreenshot" 20:07:41:640 | MD | TRACE | +0 | XHotkeyTableCreation - Ended 20:07:41:641 | MD | INFO | +0 | StartModule - Started 20:07:41:642 | MD | INFO | +0 | StartModule - MEmu: Snes9X (-sx2) MEmuV: v1.53 (v0.2) MURL: http://www.snes9x.com/ (http://bsxproj.superfamicom.org/) MAuthor: djvj, brolly MVersion: 2.0.4 MCRC: E518EA07 iCRC: 398B012D MID: MSystem: "Bandai Sufami Turbo","Nintendo Satellaview","Nintendo Super Famicom","Super Nintendo Entertainment System" 20:07:41:644 | MD | INFO | +0 | StartModule - You have a supported System Name for this module: "Super Nintendo Entertainment System" 20:07:41:669 | MD | INFO | +31 | PluginInit - Started 20:07:41:671 | MD | DEBUG | +0 | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Publisher|Year|Genre|Rating 20:07:41:672 | MD | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Databases\Super Nintendo Entertainment System\Super Nintendo Entertainment System.xml exists 20:07:41:673 | MD | DEBUG | +0 | BuildDatabaseTable - Searching for a "Game Name" in the database 20:07:41:673 | MD | DEBUG | +0 | BuildDatabaseTable - Found "Game Name" in the database! 20:07:41:699 | MD | DEBUG | +31 | BuildDatabaseTable - Searching database for: Name 20:07:41:700 | MD | DEBUG | +0 | BuildDatabaseTable - Found "Name" with a value: "Super Street Fighter II (USA)" 20:07:41:702 | MD | DEBUG | +0 | BuildDatabaseTable - Searching database for: Cloneof 20:07:41:703 | MD | DEBUG | +0 | BuildDatabaseTable - Could not find: Cloneof 20:07:41:704 | MD | DEBUG | +0 | BuildDatabaseTable - Searching database for: Publisher 20:07:41:706 | MD | DEBUG | +0 | BuildDatabaseTable - Found "Publisher" with a value: "Capcom" 20:07:41:707 | MD | DEBUG | +0 | BuildDatabaseTable - Searching database for: Year 20:07:41:729 | MD | DEBUG | +31 | BuildDatabaseTable - Found "Year" with a value: "1994" 20:07:41:731 | MD | DEBUG | +0 | BuildDatabaseTable - Searching database for: Genre 20:07:41:732 | MD | DEBUG | +0 | BuildDatabaseTable - Found "Genre" with a value: "Fighter" 20:07:41:733 | MD | DEBUG | +0 | BuildDatabaseTable - Searching database for: Rating 20:07:41:735 | MD | DEBUG | +0 | BuildDatabaseTable - Found "Rating" with a value: "Other - NR (Not Rated)" 20:07:41:736 | MD | TRACE | +0 | PluginInit - GameInfo: GameInfo Label: Genre | GameInfo Value: Fighter GameInfo Label: Name | GameInfo Value: Super Street Fighter II (USA) GameInfo Label: Publisher | GameInfo Value: Capcom GameInfo Label: Rating | GameInfo Value: Other - NR (Not Rated) GameInfo Label: Year | GameInfo Value: 1994 20:07:41:737 | MD | DEBUG | +0 | BuildDatabaseTable - Ended 20:07:41:761 | MD | INFO | +32 | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo 20:07:41:762 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a Game Logo: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Wheel\Super Street Fighter II (USA).png 20:07:41:763 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a System Logo: C:\Hyperspin\Media\Main Menu\Images\Wheel\Super Nintendo Entertainment System.png 20:07:41:763 | MD | DEBUG | +0 | BuildAssetsTable - Media assets found: Asset Label: Game Logo | Asset Path1: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Wheel\Super Street Fighter II (USA).png | Asset Extension1: png | Asset Type1: game Asset Label: System Logo | Asset Path1: C:\Hyperspin\Media\Main Menu\Images\Wheel\Super Nintendo Entertainment System.png | Asset Extension1: png | Asset Type1: system 20:07:41:763 | MD | INFO | +0 | BuildAssetsTable - Ended 20:07:41:768 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other 20:07:41:769 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a Artwork1: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Artwork1\Super Street Fighter II (USA).png 20:07:41:770 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a Box Art: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Artwork2\Super Street Fighter II (USA).png 20:07:41:793 | MD | DEBUG | +31 | BuildAssetsTable - Searching for a Cartridge: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Artwork3\Super Street Fighter II (USA).png 20:07:41:795 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a Flyers: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Artwork4\Super Street Fighter II (USA).png 20:07:41:796 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a Letters: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters 20:07:41:861 | MD | DEBUG | +62 | BuildAssetsTable - Searching for a Other: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Other 20:07:41:886 | MD | DEBUG | +32 | BuildAssetsTable - Media assets found: Asset Label: Cartridge | Asset Path1: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Artwork3\Super Street Fighter II (USA).png | Asset Extension1: png | Asset Type1: game Asset Label: Flyers | Asset Path1: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Artwork4\Super Street Fighter II (USA).png | Asset Extension1: png | Asset Type1: game Asset Label: Letters | Asset Path1: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\!.png | Asset Extension1: png | Asset Type1: system Asset Label: Letters | Asset Path2: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\'.png | Asset Extension2: png | Asset Type2: system Asset Label: Letters | Asset Path3: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\(.png | Asset Extension3: png | Asset Type3: system Asset Label: Letters | Asset Path4: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\).png | Asset Extension4: png | Asset Type4: system Asset Label: Letters | Asset Path5: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\0.png | Asset Extension5: png | Asset Type5: system Asset Label: Letters | Asset Path6: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\1.png | Asset Extension6: png | Asset Type6: system Asset Label: Letters | Asset Path7: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\2.png | Asset Extension7: png | Asset Type7: system Asset Label: Letters | Asset Path8: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\3.png | Asset Extension8: png | Asset Type8: system Asset Label: Letters | Asset Path9: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\4.png | Asset Extension9: png | Asset Type9: system Asset Label: Letters | Asset Path10: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\5.png | Asset Extension10: png | Asset Type10: system Asset Label: Letters | Asset Path11: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\6.png | Asset Extension11: png | Asset Type11: system Asset Label: Letters | Asset Path12: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\7.png | Asset Extension12: png | Asset Type12: system Asset Label: Letters | Asset Path13: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\8.png | Asset Extension13: png | Asset Type13: system Asset Label: Letters | Asset Path14: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\9.png | Asset Extension14: png | Asset Type14: system Asset Label: Letters | Asset Path15: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\a.png | Asset Extension15: png | Asset Type15: system Asset Label: Letters | Asset Path16: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\b.png | Asset Extension16: png | Asset Type16: system Asset Label: Letters | Asset Path17: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\c.png | Asset Extension17: png | Asset Type17: system Asset Label: Letters | Asset Path18: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\d.png | Asset Extension18: png | Asset Type18: system Asset Label: Letters | Asset Path19: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\e.png | Asset Extension19: png | Asset Type19: system Asset Label: Letters | Asset Path20: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\f.png | Asset Extension20: png | Asset Type20: system Asset Label: Letters | Asset Path21: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\g.png | Asset Extension21: png | Asset Type21: system Asset Label: Letters | Asset Path22: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\h.png | Asset Extension22: png | Asset Type22: system Asset Label: Letters | Asset Path23: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\i.png | Asset Extension23: png | Asset Type23: system Asset Label: Letters | Asset Path24: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\j.png | Asset Extension24: png | Asset Type24: system Asset Label: Letters | Asset Path25: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\k.png | Asset Extension25: png | Asset Type25: system Asset Label: Letters | Asset Path26: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\l.png | Asset Extension26: png | Asset Type26: system Asset Label: Letters | Asset Path27: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\m.png | Asset Extension27: png | Asset Type27: system Asset Label: Letters | Asset Path28: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\n.png | Asset Extension28: png | Asset Type28: system Asset Label: Letters | Asset Path29: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\o.png | Asset Extension29: png | Asset Type29: system Asset Label: Letters | Asset Path30: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\p.png | Asset Extension30: png | Asset Type30: system Asset Label: Letters | Asset Path31: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\q.png | Asset Extension31: png | Asset Type31: system Asset Label: Letters | Asset Path32: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\r.png | Asset Extension32: png | Asset Type32: system Asset Label: Letters | Asset Path33: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\s.png | Asset Extension33: png | Asset Type33: system Asset Label: Letters | Asset Path34: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\t.png | Asset Extension34: png | Asset Type34: system Asset Label: Letters | Asset Path35: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\u.png | Asset Extension35: png | Asset Type35: system Asset Label: Letters | Asset Path36: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\v.png | Asset Extension36: png | Asset Type36: system Asset Label: Letters | Asset Path37: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\w.png | Asset Extension37: png | Asset Type37: system Asset Label: Letters | Asset Path38: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\x.png | Asset Extension38: png | Asset Type38: system Asset Label: Letters | Asset Path39: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\y.png | Asset Extension39: png | Asset Type39: system Asset Label: Letters | Asset Path40: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Letters\z.png | Asset Extension40: png | Asset Type40: system Asset Label: Other | Asset Path1: C:\Hyperspin\Media\Super Nintendo Entertainment System\Images\Other\Pointer.png | Asset Extension1: png | Asset Type1: system 20:07:41:888 | MD | INFO | +0 | BuildAssetsTable - Ended 20:07:41:889 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Game Video|System Video 20:07:41:891 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a Game Video: C:\Hyperspin\Media\Super Nintendo Entertainment System\Video\Super Street Fighter II (USA).* 20:07:41:893 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a System Video: C:\Hyperspin\Media\Main Menu\Video\Super Nintendo Entertainment System.* 20:07:41:894 | MD | DEBUG | +0 | BuildAssetsTable - Media assets found: Asset Label: Game Video | Asset Path1: C:\Hyperspin\Media\Super Nintendo Entertainment System\Video\Super Street Fighter II (USA).mp4 | Asset Extension1: mp4 | Asset Type1: game Asset Label: System Video | Asset Path1: C:\Hyperspin\Media\Main Menu\Video\Super Nintendo Entertainment System.mp4 | Asset Extension1: mp4 | Asset Type1: system 20:07:41:917 | MD | INFO | +31 | BuildAssetsTable - Ended 20:07:41:918 | MD | INFO | +0 | PluginInit - Ended 20:07:41:919 | MD | DEBUG | +0 | StartModule - Setting romName to the dbName sent to RocketLauncher: Super Street Fighter II (USA) 20:07:41:921 | MD | TRACE | +0 | XHotkeyTableCreation - Started 20:07:41:922 | MD | TRACE | +0 | XHotkeyTableCreation - KeyGroup ~e&~t not in TableKeyGroups ~Esc,~1,PrintScreen, 20:07:41:924 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 1 check 20:07:41:925 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 2 check 20:07:41:926 | MD | TRACE | +0 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor" 20:07:41:949 | MD | TRACE | +31 | XHotkeyTableCreation - Ended 20:07:41:950 | MD | TRACE | +0 | Process.__New - Creating new process object for: "C:\Hyperspin\HyperSpin.exe" 20:07:41:952 | MD | TRACE | +0 | File.__New - Creating new file object of: "C:\Hyperspin\HyperSpin.exe" 20:07:41:953 | MD | TRACE | +0 | File.__New - Creating new file object of: "C:\Hyperspin\RocketLauncher\Modules\Snes9x\Super Nintendo Entertainment System\Super Street Fighter II (USA).ini" 20:07:41:983 | MD | TRACE | +31 | File.__New - Creating new file object of: "C:\Hyperspin\RocketLauncher\Modules\Snes9x\Super Nintendo Entertainment System.ini" 20:07:41:989 | MD | TRACE | +0 | File.__New - Creating new file object of: "C:\Hyperspin\RocketLauncher\Modules\Snes9x\Snes9x.ini" 20:07:41:013 | MD | TRACE | +32 | File.Exist - This file exists: C:\Hyperspin\RocketLauncher\Modules\Snes9x\Snes9x.ini 20:07:42:015 | MD | DEBUG | +0 | RIniFile.__New - "Module" at index 1, adding "GlobalModuleIni" from: "C:\Hyperspin\RocketLauncher\Modules\Snes9x\Snes9x.ini" 20:07:42:043 | MD | INFO | +31 | StartModule - Ended 20:07:42:043 | MD | INFO | +0 | FadeApp - Hiding Frontend by making it transparent 20:07:42:048 | MD | INFO | +0 | CheckFile - Checking if \snes9x.conf exists 20:07:42:049 | MD | TRACE | +0 | XHotkeyTableCreation - Started 20:07:42:050 | MD | TRACE | +0 | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~1,PrintScreen,~e&~t, 20:07:42:050 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 10 check 20:07:42:051 | MD | TRACE | +0 | XHotkeyTableCreation - Disabled Hotkey for: "~Esc" 20:07:42:072 | MD | TRACE | +31 | XHotkeyTableCreation - Post loop 11 check 20:07:42:073 | MD | TRACE | +0 | XHotkeyTableCreation - Disabling "CloseProcess" standard Hotkey method for key(s): "~Esc" 20:07:42:073 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 12 check 20:07:42:073 | MD | TRACE | +0 | XHotkeyTableCreation - Ended 20:07:42:073 | MD | TRACE | +0 | XHotkeyTableCreation - Started 20:07:42:073 | MD | TRACE | +0 | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~1,PrintScreen,~e&~t, 20:07:42:073 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 10 check 20:07:42:078 | MD | TRACE | +0 | XHotkeyTableCreation - Disabled Hotkey for: "~Esc" 20:07:42:079 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 11 check 20:07:42:080 | MD | TRACE | +0 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseError" 20:07:42:081 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 12 check 20:07:42:081 | MD | TRACE | +0 | XHotkeyTableCreation - Ended 20:07:42:450 | MD | DEBUG | +375 | ScriptError - Playing error sound: error2.mp3 20:07:43:423 | MD | INFO | +969 | 7zCleanUp - Started 20:07:43:423 | MD | INFO | +0 | 7zCleanUp - Deleted 20:07:43:423 | MD | INFO | +0 | 7zCleanUp - Ended 20:07:49:761 | MD | TRACE | +6344 | XHotkeyTableCreation - Started 20:07:49:763 | MD | TRACE | +0 | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~1,PrintScreen,~e&~t, 20:07:49:763 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 10 check 20:07:49:763 | MD | TRACE | +0 | XHotkeyTableCreation - Disabled Hotkey for: "~Esc" 20:07:49:768 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 11 check 20:07:49:768 | MD | TRACE | +0 | XHotkeyTableCreation - Disabling "CloseError" standard Hotkey method for key(s): "~Esc" 20:07:49:768 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 12 check 20:07:49:769 | MD | TRACE | +0 | XHotkeyTableCreation - Ended 20:07:49:769 | MD | TRACE | +0 | XHotkeyTableCreation - Started 20:07:49:769 | MD | TRACE | +0 | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~1,PrintScreen,~e&~t, 20:07:49:770 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 10 check 20:07:49:770 | MD | TRACE | +0 | XHotkeyTableCreation - Disabled Hotkey for: "~Esc" 20:07:49:770 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 11 check 20:07:49:791 | MD | TRACE | +31 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess" 20:07:49:791 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 12 check 20:07:49:792 | MD | TRACE | +0 | XHotkeyTableCreation - Ended 20:07:49:792 | MD | ERROR | +0 | ScriptError - Cannot find \snes9x.conf 20:07:49:793 | MD | INFO | +0 | ExitModule - Started 20:07:49:793 | MD | INFO | +0 | Starting Updating Statistics: 20:07:49:793 | MD | TRACE | +0 | Total Elapsed Time in Pause in seconds: 0 20:07:49:794 | MD | TRACE | +0 | gameSectionStartTime:2658734 20:07:49:794 | MD | TRACE | +0 | ElapsedTime:7 20:07:49:794 | MD | TRACE | +0 | Statistics cleared game name: Super Street Fighter II 20:07:49:823 | MD | TRACE | +31 | Loaded game statistics from ini files: Number_of_Times_Played: 7 Last_Time_Played: Mittwoch Mai 25, 2016 08:06:44 Average_Time_Played: 7 Total_Time_Played: 46 System_Total_Played_Time: 66 Total_Global_Played_Time: 17144 20:07:49:823 | MD | TRACE | +0 | Updated Statistics: Number_of_Times_Played: 8 Last_Time_Played: Mittwoch Mai 25, 2016 08:07:42 Average_Time_Played: 7 Total_Time_Played: 53 System_Total_Played_Time: 73 Total_Global_Played_Time: 17151 20:07:49:861 | MD | INFO | +31 | Game section statistics updated. 20:07:49:862 | MD | INFO | +0 | RunKeymapper - Started, using method "unload" 20:07:49:862 | MD | INFO | +0 | GetJoystickArray - Started 20:07:49:890 | MD | TRACE | +32 | GetJoystickArray - Joysticks Detected: 1111111000000000 20:07:49:892 | MD | INFO | +0 | GetJoystickGUID - Started 20:07:49:892 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: 400C3FD23D0EE6118001444553540000 20:07:49:893 | MD | TRACE | +0 | GetJoystickArray - ID: 1 | Port: 0 | Name: Controller (Xbox One For Windows) | MID: 045e | PID: 02ff | GUID: 400C3FD23D0EE6118001444553540000 20:07:49:893 | MD | INFO | +0 | GetJoystickGUID - Started 20:07:49:893 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: E0877E83931FE6118002444553540000 20:07:49:893 | MD | TRACE | +0 | GetJoystickArray - ID: 2 | Port: 1 | Name: Mayflash Wiimote PC Adapter | MID: 057e | PID: 0306 | GUID: E0877E83931FE6118002444553540000 20:07:49:893 | MD | INFO | +0 | GetJoystickGUID - Started 20:07:49:893 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: F0AE7E83931FE6118003444553540000 20:07:49:893 | MD | TRACE | +0 | GetJoystickArray - ID: 3 | Port: 2 | Name: Mayflash Wiimote PC Adapter | MID: 057e | PID: 0306 | GUID: F0AE7E83931FE6118003444553540000 20:07:49:919 | MD | INFO | +31 | GetJoystickGUID - Started 20:07:49:920 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: 10FD7E83931FE6118004444553540000 20:07:49:920 | MD | TRACE | +0 | GetJoystickArray - ID: 4 | Port: 3 | Name: Mayflash Wiimote PC Adapter | MID: 057e | PID: 0306 | GUID: 10FD7E83931FE6118004444553540000 20:07:49:922 | MD | INFO | +0 | GetJoystickGUID - Started 20:07:49:922 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: A0EB7D83931FE6118001444553540000 20:07:49:923 | MD | TRACE | +0 | GetJoystickArray - ID: 5 | Port: 4 | Name: Mayflash Wiimote PC Adapter | MID: 057e | PID: 0306 | GUID: A0EB7D83931FE6118001444553540000 20:07:49:924 | MD | INFO | +0 | GetJoystickGUID - Started 20:07:49:925 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: 107630419590E5118001444553540000 20:07:49:925 | MD | TRACE | +0 | GetJoystickArray - ID: 6 | Port: 5 | Name: Controller (Xbox 360 Wireless Receiver for Windows) | MID: 045e | PID: 02a1 | GUID: 107630419590E5118001444553540000 20:07:49:948 | MD | INFO | +31 | GetJoystickGUID - Started 20:07:49:948 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: 8068CD559590E5118002444553540000 20:07:49:949 | MD | TRACE | +0 | GetJoystickArray - ID: 7 | Port: 6 | Name: Controller (Xbox 360 Wireless Receiver for Windows) | MID: 045e | PID: 02a1 | GUID: 8068CD559590E5118002444553540000 20:07:49:949 | MD | INFO | +0 | GetJoystickArray - Ended 20:07:49:950 | MD | TRACE | +0 | RunKeymapper - Looping through controllers to find joytokey profiles for each one 20:07:49:950 | MD | INFO | +0 | RunJoyToKey - Started 20:07:49:951 | MD | INFO | +0 | Process - Exist Xpadder.exe 20:07:49:953 | MD | INFO | +0 | WinClose - Closing: JoyToKey ahk_class TMainForm 20:07:52:070 | MD | INFO | +2125 | Process - WaitClose JoyToKey.exe 2 20:07:54:155 | MD | INFO | +2078 | Process - Close JoyToKey.exe 20:07:54:182 | MD | INFO | +32 | RunJoyToKey - Ended 20:07:54:183 | MD | INFO | +0 | RunKeymapper - Ended 20:07:54:185 | MD | TRACE | +0 | CustomFunction.PostExit - Starting 20:07:54:186 | MD | TRACE | +0 | CustomFunction.PostExit - Ending 20:07:54:188 | MD | INFO | +0 | ExitModule - Ended End of Module Logs 20:07:54:306 | RL | INFO | +17297 | Main - Module ended, exiting RocketLauncher normally 20:07:54:306 | RL | INFO | +0 | ExitScript - Started 20:07:54:311 | RL | TRACE | +0 | StringUtils.Contains - "false" does not contain "true|kill" 20:07:54:311 | RL | INFO | +0 | ExitScript - Restoring taskbar 20:07:54:312 | RL | TRACE | +0 | Window.__New - Created: "ahk_class Shell_TrayWnd" 20:07:54:312 | RL | TRACE | +0 | Window.__New - Created: "Start ahk_class Button" 20:07:54:313 | RL | TRACE | +0 | Window.Show - Unhiding window "ahk_class Shell_TrayWnd" 20:07:54:411 | RL | TRACE | +109 | Window.Show - Unhiding window "Start ahk_class Button" 20:07:54:420 | RL | INFO | +0 | SystemCursor - Restoring mouse cursor 20:07:54:428 | RL | INFO | +16 | ExitScript - Restored cursor
mattyb425 Posted May 25, 2016 Author Posted May 25, 2016 i have the same problem. Rocket launcher tells me "cannot find Snes9x.conf" but this file IS in the emulator folder from SNES9x. the emulator works great outside from hyper spin. the Troubleshooting Log from RL just tells me "script Error - Cannot find /snes9x.conf" any Idea would you like to have the full trouble shooting log? I had to change the path for the snesx folder in the global>emulators tab in rocket launcher. Give that a shot Make sure that the path to the snes9x exe is set correctly on the Global -> Emulators tab in RLUI. That's the only thing I know of that triggers that error. Sent from my SM-N900V using Tapatalk
ChrisKant Posted May 25, 2016 Posted May 25, 2016 that won't helped me. i delete the specific ones emulator settings, configured one new under global > emulators in RL. through rl i can launch the emulator perfectly, but when I try to start a game over RL or Hyperspin the error message still popping up You have skipChecks set to Rom and Emu (which you shouldn't need), and since the conf path is based on the emu path that could be causing the error. that was the problem. it really was "skip checks" to rom and emu. after I chanced it to "false" everything works well. strange but thank you a lot
moussa333 Posted June 6, 2016 Posted June 6, 2016 I think you are having problems because your rom file names need to be exactly identical to the names used by hyperspin. I used a program to check and change the names of sone roms and it worked. But i wish there was an easier way, it would take for ever if you have hundreds of roms.
moussa333 Posted June 6, 2016 Posted June 6, 2016 The program is called hypermatch. Unfortunately 1 rom at a time
