Can't launch any games in Hyperspin!
filipelux
Dear all,
I'm new in this forum and I'd like to resolve a problem (probably easy to resolve?)
I installed and configured correctly Hyperspin->Hyperlaunch and of course I use the new RocketLauncher.
I tried 3 emulators at this moment: N64, SNES and Mame->respectively Project64 (version 2.0.0.14), snes 9x and mameui64 (vers. 0.149)
All of them works perfectly under their emulators...but not Hyperspin!
When I press Enter nothing happens!
My folder is: C:\Hyperspin\ and HyperLaunch HQ is located in C:\HyperSpin\HyperLaunch\HyperLaunchHQ
Where should be the problem?
Thank you for your help.
Filipe
Hi Filipe welcome.
Did you set anything in HyperHQ? Your execution method should be Hyperlaunch, not normal. You shouldn't need to touch any settings in HyperHQ really. But if you have the Rom extension set, make sure it is set to zip not .zip.
Check if hyperlaunch is already running in the system tray.
  • 6 months later...
Hi, hope this is the right place I didn't want to start a new thread for a problem I know someone else would have.
I'm having the same problem as filipelux. I have the feeling its an obvious fix but I cant find it.
I have hyperlaunch in a different folder, all roms work using hyperlaunch HQ (and hyperlaunch obviously) but nothing happens when I push enter.
I checked hyper HQ and the execution is set to Hyperlaunch. I also made sure the extension didn't have a "."
any help would be appreciated! thanks.
In the Hyperspin> settings folder open the setting.ini. Is the path to Hyperlaunch correct and has it a backslash at the end?
Also, at least initially, remove any check marks from your filter options.
Yes it looks like this.
Hyperlaunch_Path=T:\HyperSpin\HyperLaunch\
I've removed the check marks for Mame as well to test. I remember reading another thread that someone had the same issue as mine and the checkmarks somehow resolved but I still cant get a game to start.
here's the log:
09:36:19 AM | HyperSpin Started
09:36:19 AM | Going FullScreen
09:36:19 AM | Checking for updates
09:36:19 AM | Update Check Complete
09:36:19 AM | Startup program unavailable
09:36:19 AM | Playing intro video
09:36:20 AM | Error intializing joysticks
09:36:20 AM | Menu Mode is multi
09:36:20 AM | Loading Main Menu.xml
09:36:20 AM | Main Menu.xml successfully loaded
09:36:21 AM | Main Menu wheel loaded successfully
09:36:24 AM | Loading MAME.xml
09:36:24 AM | Main Menu.xml successfully loaded
09:36:25 AM | MAME wheel loaded successfully
09:36:36 AM | Launching Game
09:36:36 AM | Using HyperLaunch
09:36:36 AM | Getting HyperLaunch path
09:36:36 AM | HyperLaunch located at T:\HyperSpin\HyperLaunch\HyperLaunch.exe
09:36:36 AM | Running HyperLaunch.exe
09:36:36 AM | HyperLaunch Command Line is: T:\HyperSpin\HyperLaunch\HyperLaunch.exe "MAME" "1942b"
09:36:42 AM | Launching Game
09:36:42 AM | Using HyperLaunch
09:36:42 AM | Getting HyperLaunch path
09:36:42 AM | HyperLaunch located at T:\HyperSpin\HyperLaunch\HyperLaunch.exe
09:36:42 AM | Running HyperLaunch.exe
09:36:42 AM | HyperLaunch Command Line is: T:\HyperSpin\HyperLaunch\HyperLaunch.exe "MAME" "88games"
09:36:44 AM | Loading Main Menu.xml
09:36:44 AM | Main Menu.xml successfully loaded
09:36:44 AM | Main Menu wheel loaded successfully
09:36:47 AM | Exit program unavailable
09:36:47 AM | Quiting Hyperspin
09:36:47 AM | Bye!
(also, Ive been subscribed and using your videos a lot! Thanks for that. :beer:)
here's the log:
09:36:47 AM | Bye!
Ok, a couple things to check.
It's a known bug that on some setups, you have to have speakers plugged in. Please check that.
Please post your HyperLaunch log (using code tags) as described here:
http://www.hyperspin-fe.com/forum/showthread.php?31072-The-HyperNoobie-Guide-For-Posting-To-The-Fourm
Thanks,
Ron
Ok here's my log file. Ill try with different speaker setups, see if that works and I'll post here again.
19:35:48:472 | HL |     INFO  | +N/A   | Main - HyperLaunch v3.0.0.9
19:35:48:474 | HL |     INFO  | +15    | Main - System Specs:
				HyperLaunch Dir: T:\HyperSpin\HyperLaunch
				OS: WIN_7
				Architecture: 64-bit (might not be accurate)
				OS Admin Status: Yes
				Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1040 work)
				Monitor #2 (\\.\DISPLAY2): 0x1080 (0x1080 work)
				AutoHotkey Path:
				AHK Version: 1.1.09.04
				Unicode: No
19:35:48:474 | HL |     INFO  | +0     | Main - HyperSpin.exe coordinates are x0 y0 w1920 h1080
19:35:48:474 | HL |     INFO  | +0     | CheckFile - Checking if T:\HyperSpin\HyperLaunch\HyperLaunch.exe exists
19:35:48:475 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				FileVersion             	3.0.0.9
				File Size:			899072 bytes
				Created:			11/18/2013 - 9:37:10 PM
				Modified:			7/28/2013 - 3:35:52 PM
19:35:48:475 | HL |     INFO  | +0     | CheckFile - Checking if T:\HyperSpin\HyperLaunch\Module Extensions\gdip.ahk exists
19:35:48:492 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
19:35:48:493 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			88789 bytes
				Created:			11/18/2013 - 9:36:54 PM
				Modified:			11/18/2013 - 9:36:54 PM
19:35:48:493 | HL |     INFO  | +0     | CheckFile - Checking if T:\HyperSpin\HyperLaunch\Module Extensions\RIni.ahk exists
19:35:48:499 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
19:35:48:499 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			67561 bytes
19:35:48:499 | HL |     INFO  | +0     | CheckFile - Checking if T:\HyperSpin\HyperLaunch\Module Extensions\CLR.ahk exists
19:35:48:509 | HL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Extension.
19:35:48:509 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			10586 bytes
19:35:48:509 | HL |     INFO  | +0     | CheckFile - Checking if T:\HyperSpin\HyperLaunch\Module Extensions\COM.ahk exists
19:35:48:520 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
19:35:48:520 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			26342 bytes
19:35:48:520 | HL |     INFO  | +0     | CheckFile - Checking if T:\HyperSpin\HyperLaunch\Module Extensions\JSON.ahk exists
19:35:48:522 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
19:35:48:522 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			9203 bytes
19:35:48:522 | HL |     INFO  | +0     | CheckFile - Checking if T:\HyperSpin\HyperLaunch\Lib\Fade Init.ahk exists
19:35:48:522 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
				File Size:			1145 bytes
19:35:48:522 | HL |     INFO  | +0     | CheckFile - Checking if T:\HyperSpin\HyperLaunch\Lib\HyperPause Init.ahk exists
19:35:48:523 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
19:35:48:523 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			691 bytes
19:35:48:523 | HL |     INFO  | +0     | CheckFile - Checking if T:\HyperSpin\HyperLaunch\Lib\Keymapper Init.ahk exists
19:35:48:535 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
19:35:48:535 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			2485 bytes
19:35:48:535 | HL |     INFO  | +0     | CheckFile - Checking if T:\HyperSpin\HyperLaunch\Lib\MultiGame Init.ahk exists
19:35:48:536 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
19:35:48:536 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			161 bytes
19:35:48:536 | HL |     INFO  | +0     | CheckFile - Checking if T:\HyperSpin\HyperLaunch\Lib\Statistics Init.ahk exists
				File Size:			167 bytes
19:35:48:536 | HL |     INFO  | +0     | CheckFile - Checking if T:\HyperSpin\HyperLaunch\Lib\Fade.ahk exists
19:35:48:552 | HL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
19:35:48:553 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			26644 bytes
19:35:48:553 | HL |     INFO  | +0     | CheckFile - Checking if T:\HyperSpin\HyperLaunch\Lib\HyperPause.ahk exists
19:35:48:571 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
19:35:48:571 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			326352 bytes
19:35:48:571 | HL |     INFO  | +0     | CheckFile - Checking if T:\HyperSpin\HyperLaunch\Lib\Keymapper.ahk exists
19:35:48:573 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
19:35:48:573 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			27844 bytes
19:35:48:573 | HL |     INFO  | +0     | CheckFile - Checking if T:\HyperSpin\HyperLaunch\Lib\MultiGame.ahk exists
19:35:48:574 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
19:35:48:574 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			28070 bytes
19:35:48:574 | HL |     INFO  | +0     | CheckFile - Checking if T:\HyperSpin\HyperLaunch\Lib\Bezel.ahk exists
19:35:48:575 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
19:35:48:576 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			21407 bytes
19:35:48:576 | HL |     INFO  | +0     | CheckFile - Checking if T:\HyperSpin\HyperLaunch\Lib\Statistics.ahk exists
19:35:48:586 | HL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
19:35:48:586 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			26089 bytes
19:35:48:586 | HL |     INFO  | +0     | CheckFile - Checking if T:\HyperSpin\HyperLaunch\Lib\Rom Mapping Launch Menu.ahk exists
19:35:48:593 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
19:35:48:593 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			63798 bytes
19:35:48:593 | HL |     INFO  | +0     | CheckFile - Checking if T:\HyperSpin\HyperLaunch\Lib\Shared.ahk exists
19:35:48:595 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
19:35:48:595 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			65137 bytes
19:35:48:595 | HL |     INFO  | +0     | CheckFile - Checking if T:\HyperSpin\HyperLaunch\Lib\XHotkey.ahk exists
19:35:48:597 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
19:35:48:597 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			28659 bytes
19:35:48:597 | HL |     INFO  | +0     | CheckFile - Checking if T:\HyperSpin\HyperLaunch\Lib\Fade Animations.ahk exists
19:35:48:598 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
19:35:48:598 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			48181 bytes
19:35:48:599 | HL |     INFO  | +0     | Main - HyperLaunch received "MAME" and "1942b"
19:35:48:602 | HL |     INFO  | +0     | Main - 1942b is using the default emulator: MAME
19:35:48:602 | HL |     INFO  | +0     | Main - Checking for a [MAME] section in T:\HyperSpin\HyperLaunch\Settings\MAME\Emulators.ini
19:35:48:602 | HL |     INFO  | +0     | Main - Checking for a [MAME] section in T:\HyperSpin\HyperLaunch\Settings\Global Emulators.ini
19:35:48:602 | HL |     INFO  | +0     | Main - Found [MAME] in T:\HyperSpin\HyperLaunch\Settings\Global Emulators.ini
19:35:48:602 | HL |     INFO  | +0     | CheckFile - Checking if T:\HyperSpin\HyperLaunch\Modules\MAME\MAME.ahk exists
19:35:48:603 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			9871 bytes
19:35:48:603 | HL |     INFO  | +0     | Main - CRC Check - CRC matches, this is an official unedited module.
19:35:48:603 | HL |     INFO  | +0     | Main - 1942b will use module: T:\HyperSpin\HyperLaunch\Modules\MAME\MAME.ahk
19:35:48:609 | HL |     INFO  | +0     | Main - Using standard method with "Rom Extensions" SkipChecks or without any SkipChecks.
19:35:48:611 | HL |     INFO  | +0     | Main - INI Keys read
19:35:48:611 | HL |     INFO  | +0     | CheckFile - Checking if T:\HyperSpin\HyperLaunch\Module Extensions\7z.exe exists
19:35:48:623 | HL |   DEBUG1  | +16    | CheckFile - Attributes:
				FileVersion             	9.20
				InternalName            	7z
				ProductVersion          	9.20
				File Size:			163840 bytes
19:35:48:623 | HL |     INFO  | +0     | CheckFile - Checking if T:\HyperSpin\HyperLaunch\Module Extensions\7z.dll exists
19:35:48:629 | HL |   DEBUG1  | +15    | CheckFile - Attributes:
				FileVersion             	9.20
				InternalName            	7za
				ProductVersion          	9.20
				File Size:			914432 bytes
19:35:48:629 | HL |     INFO  | +0     | CheckPaths - Started
19:35:48:629 | HL |   DEBUG1  | +0     | CheckPaths - Looking for rom: T:\HyperSpin\Emulators\MAME\roms\1942b.zip
19:35:48:629 | HL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: T:\HyperSpin\Emulators\MAME\roms\1942b\1942b.zip
19:35:48:629 | HL |   DEBUG1  | +0     | CheckPaths - Looking for rom by extension: T:\HyperSpin\Emulators\MAME\roms\1942b\*.zip
19:35:48:630 | HL |   DEBUG1  | +0     | CheckPaths - Looking for rom: T:\HyperSpin\Emulators\MAME\roms\1942b.7z
19:35:48:630 | HL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: T:\HyperSpin\Emulators\MAME\roms\1942b\1942b.7z
19:35:48:630 | HL |   DEBUG1  | +0     | CheckPaths - Looking for rom by extension: T:\HyperSpin\Emulators\MAME\roms\1942b\*.7z
19:35:48:630 | HL |   DEBUG1  | +0     | CheckPaths - Looking for rom: T:\HyperSpin\Roms\mame\1942b.zip
19:35:48:642 | HL |     INFO  | +0     | CheckPaths - Found rom: T:\HyperSpin\Roms\mame\1942b.zip
19:35:48:642 | HL |     INFO  | +0     | CheckFile - Checking if T:\HyperSpin\Emulators\MAME\mame.exe exists
19:35:48:657 | HL |   DEBUG1  | +16    | CheckFile - Attributes:
				FileDescription         	Multiple Arcade Machine Emulator
				FileVersion             	0, 151, 0, 0
				InternalName            	MAME
				LegalCopyright          	Copyright Nicola Salmoria and the MAME team
				OriginalFilename        	MAME
				ProductName             	MAME
				ProductVersion          	0.151
				CompanyName             	MAME Team
				File Size:			81334784 bytes
				Created:			11/18/2013 - 10:14:01 PM
				Modified:			11/5/2013 - 3:40:46 AM
19:35:48:657 | HL |     INFO  | +0     | CheckPaths - Ended
19:35:48:657 | HL |     INFO  | +0     | BuildScript - User Variables:
				; INJECTED VARIABLES
				#NoTrayIcon
				#InstallKeybdHook
				DetectHiddenWindows, ON
				SetTitleMatchMode, 2
				SendMode, Event
				0 = 2
				frontendPID = 5480
				frontendPath = T:\HyperSpin
				frontendExe = HyperSpin.exe
				frontendExt = exe
				frontendName = HyperSpin
				frontendDrive = T:
				exitEmulatorKey = ~Esc
				exitEmulatorKeyWait = 0
				forceHoldKey = ~Esc
				restoreFE = false
				exitScriptKey = ~q & ~s
				emuFullPath = T:\HyperSpin\Emulators\MAME\mame.exe
				emuPath = T:\HyperSpin\Emulators\MAME
				emuName = MAME
				emuExt = exe
				romPath = T:\HyperSpin\Roms\mame
				romPathFromIni = T:\HyperSpin\Emulators\MAME\roms|T:\HyperSpin\Roms\mame
				romExtension = .zip
				romExtensionOrig = .zip
				romExtensions = zip|7z
				executable = mame.exe
				systemName = MAME
				dbName = 1942b
				romName =
				romMapPath =
				romMappingEnabled = false
				romMappingMenuWidth = 300
				romMappingMenuMargin = 50
				romMappingTextMargin = 10
				romMappingMenuFlagWidth = 40
				skipchecks = false
				romMatchExt = true
				logFile = T:\HyperSpin\HyperLaunch\HyperLaunch.log
				logLevel = 10
				logIncludeModule = true
				logShowCommandWindow = false
				logCommandWindow = false
				navUpKey = Up
				navDownKey = Down
				navLeftKey = Left
				navRightKey = Right
				navSelectKey = Enter
				navP2UpKey = Numpad8
				navP2DownKey = Numpad2
				navP2LeftKey = Numpad4
				navP2RightKey = Numpad6
				navP2SelectKey = NumpadEnter
				originalWidth = 1920
				originalHeight = 1080
				dtEnabled = true
				dtPath =
				dtUseSCSI = true
				dtAddDrive = true
				emuIdleShutdown = 0
				hideEmu = false
				hideFE = false
				fadeIn = false
				fadeInDuration = 500
				fadeInDelay = 0
				fadeInExitDelay = 0
				fadeOutExitDelay = 0
				fadeOut = false
				fadeOutDuration = 500
				fadeOutDelay = 0
				fadeLyrInterpolation = 7
				fadeLyr1Color = FF000000
				fadeLyr2X = 300
				fadeLyr2Y = 300
				fadeLyr2Adjust = 1
				fadeLyr2PicPad = 0
				fadeLyr3Pos = Center
				fadeLyr3X = 300
				fadeLyr3Y = 300
				fadeLyr3Adjust = 0.75
				fadeLyr3Speed = 750
				fadeLyr3Type = imageandbar
				fadeLyr3Repeat = 1
				fadeLyr3PicPad = 0
				fadeLyr4Adjust = 0.75
				fadeLyr4X = 100
				fadeLyr4Y = 100
				fadeLyr4FPS = 10
				fadeLyr4PicPad = 0
				fadeTranspGifColor = FFFFFF
				fadeBarWindow = false
				fadeBarWindowX =
				fadeBarWindowY =
				fadeBarWindowW = 600
				fadeBarWindowH = 120
				fadeBarWindowR = 20
				fadeBarWindowM = 20
				fadeBarWindowHatchStyle = 8
				fadeBarBack = true
				fadeBarBackColor = FF555555
				fadeBarH = 20
				fadeBarR = 5
				fadeBarColor = DD00BFFF
				fadeBarHatchStyle = 3
				fadeBarPercentageText = true
				fadeBarInfoText = true
				fadeBarXOffset = 0
				fadeBarYOffset = 100
				fadeRomInfoDescription = text
				fadeRomInfoSystemName = text
				fadeRomInfoYear = text
				fadeRomInfoGenre = text
				fadeRomInfoRating = text
				fadeRomInfoTextMargin = 5
				fadeStatsInfoTextMargin = 5
				fadeText1X = 0
				fadeText1Y = 0
				fadeText1 = Loading Game
				fadeText2X = 0
				fadeText2Y = 0
				fadeFont = Arial
				fadeInterruptKey =
				detectFadeErrorEnabled = true
				fadeImgPath = T:\HyperSpin\HyperLaunch\Media\Fade
				HLDataPath = T:\HyperSpin\HyperLaunch\Data
				HLMediaPath = T:\HyperSpin\HyperLaunch\Media
				HLErrSoundPath = T:\HyperSpin\HyperLaunch\Media\Sounds\Error
				modulesPath = T:\HyperSpin\HyperLaunch\Modules
				moduleFullName = T:\HyperSpin\HyperLaunch\Modules\MAME\MAME.ahk
				moduleName = MAME
				modulePath = T:\HyperSpin\HyperLaunch\Modules\MAME
				moduleExtension = ahk
				moduleExtensionsPath = T:\HyperSpin\HyperLaunch\Module Extensions
				libPath = T:\HyperSpin\HyperLaunch\Lib
				7zEnabled = false
				7zPath = T:\HyperSpin\HyperLaunch\Module Extensions\7z.exe
				7zDllPath = T:\HyperSpin\HyperLaunch\Module Extensions\7z.dll
				7zExtractPath = C:\temp\HS
				7zExtractPathOrig =
				7zAttachSystemName = false
				7zDelTemp = true
				7zSounds = true
				mgEnabled = false
				mgKey = ~NumpadSub
				mgBackgroundColor = FF000000
				mgSidePadding = 0.2
				mgYOffset = 500
				mgImageAdjust = 0
				mgFont = Arial
				mgText2Offset = 70
				mgUseSound = true
				mgSoundfreq = 300
				mgExitEffect = none
				mgSelectedEffect = rotate
				mgUseGameArt = false
				mgArtworkDir = Artwork1
				hpEnabled = false
				hpKey = ~NumpadAdd
				hpBackToMenuBarKey = X
				hpZoomInKey = C
				hpZoomOutKey = V
				hpHiToTextPath = T:\HyperSpin\HyperLaunch\Module Extensions\HiToText.exe
				hpSaveStateKeyCodes = {shift down}{F7 down}{F7 up}{shift up}
				hpLoadStateKeyCodes = {shift down}{F7 down}{F7 up}{shift up}
				keymapperEnabled = false
				keymapper =
				xpadderFullPath = T:\HyperSpin\Utilities\Xpadder\xpadder.exe
				joyToKeyFullPath = T:\HyperSpin\Utilities\JoyToKey\JoyToKey.exe
				keymapperProfilePath = T:\HyperSpin\HyperLaunch\Profiles\
				JoyIDsEnabled = false
				JoyIDsPreferredControllersSystem = use_global
				CustomJoyNamesEnabled = false
				CustomJoyNames =
				FEProfile = T:\HyperSpin\HyperLaunch\Profiles\\HyperSpin
				defaultProfile = T:\HyperSpin\HyperLaunch\Profiles\\_Default
				systemProfile = T:\HyperSpin\HyperLaunch\Profiles\\MAME
				xPadderSystemProfile = T:\HyperSpin\HyperLaunch\Profiles\\MAME\_Default
				emuProfile = T:\HyperSpin\HyperLaunch\Profiles\\MAME\MAME
				romProfile = T:\HyperSpin\HyperLaunch\Profiles\\MAME\1942b
				blankProfile = T:\HyperSpin\HyperLaunch\Profiles\\blank
				HyperLaunchProfile = T:\HyperSpin\HyperLaunch\Profiles\\HyperLaunch
				bezelEnabled = false
				statisticsEnabled = true
19:35:48:658 | HL |     INFO  | +0     | BuildScript - Loaded XHotkey Init.ahk scripts
19:35:48:658 | HL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
19:35:48:658 | HL |     INFO  | +0     | BuildScript - Loaded User Functions Init.ahk script
19:35:48:658 | HL |   DEBUG1  | +0     | BuildScript - Module starts on line: 285
19:35:48:659 | HL |     INFO  | +0     | BuildScript - Module:
				MEmu = MAME
				MEmuV =  v0.148
				MURL = http://www.mame.net/
				MAuthor = djvj
				MVersion = 2.0.6
				MCRC = D558F163
				iCRC = CD775A90
				MID = 635038268903403479
				MSystem = "AAE","Cave","LaserDisc","MAME","Nintendo Arcade Systems","Sega Model 1","Sega ST-V","SNK Neo Geo","SNK Neo Geo AES"
				; Notes:
				; No need to edit mame.ini and set your rom folder, module sends the rompath for you.
				; Command Line Options - http://easyemu.mameworld.info/mameguide/mameguide-options.html
				; High Scores DO NOT SAVE when cheats are enabled!
				; HLSL Documentation: http://mamedev.org/source/docs/hlsl.txt.html
				; MAME 149 is currently bugged and HyperPause support is broken. Emu does not let you alt-tab out. This is a mamedev issue, not an HL one.
				; If you use MAME for AAE, create a vector.ini in mame's ini subfolder and paste these HLSL settings in there: http://www.mameworld.info/ubbthreads/showflat.php?Cat=&Number=309968&page=&view=&sb=5&o=&vc=1
				StartModule()
				FadeInStart()
				settingsFile := CheckFile(modulePath . "\" . moduleName . ".ini")
				Videomode := IniReadCheck(settingsFile, "Settings", "Videomode","d3d",,1)
				hideConsole := IniReadCheck(settingsFile, "Settings", "HideConsole","true",,1)	; Hides console window from view if it shows up
				pauseMethod := IniReadCheck(settingsFile, "Settings", "PauseMethod",1,,1)	; set the pause method that works better on your machine (preferred methods 1 and 2) 1 = Win7 and Win8 OK - Problems with Win XP, 2 = preferred method for WinXP - Problems in Win7, 3 and 4 = same as 1 and 2, 5 = only use If you have a direct input version of mame, 6 = suspend mame process method, it could crash mame in some computers
				bezelMode := IniReadCheck(settingsFile, "Settings", "BezelMode","layout",,1)	; "layout" or "normal"
				cheatMode := IniReadCheck(settingsFile, "Settings", "CheatMode","false",,1)
				cheatModeKey := IniReadCheck(settingsFile, "Settings", "CheatModeKey",A_Space,,1)	; user defined key to be held down before launching a mame rom.
				sysParams := IniReadCheck(settingsFile, systemName, "Params", A_Space,,1)
				romParams := IniReadCheck(settingsFile, romName, "Params", A_Space,,1)
				mameRomName := IniReadCheck(settingsFile, romName, "MameRomName", A_Space,,1)
				Use_Bezels := IniReadCheck(settingsFile, "Settings", "Use_Bezels", "true",,1)
				Use_Bezels := IniReadCheck(settingsFile, romName, "Use_Bezels", Use_Bezels,,1)	; default is the system's current setting
				Use_Overlays := IniReadCheck(settingsFile, "Settings", "Use_Overlays", "true",,1)
				Use_Overlays := IniReadCheck(settingsFile, romName, "Use_Overlays", Use_Overlays,,1)	; default is the system's current setting
				Use_Backdrops := IniReadCheck(settingsFile, "Settings", "Use_Backdrops", "true",,1)
				Use_Backdrops := IniReadCheck(settingsFile, romName, "Use_Backdrops", Use_Backdrops,,1)	; default is the system's current setting
				If bezelEnabled = true
				{	ListXMLtable := []
					ListXMLtable := ListXMLInfo(romName)
					If bezelMode = layout
						useBezels := If (Use_Bezels = "true") ? "-use_bezels" : "-nouse_bezels"
						useOverlays := If (Use_Overlays = "true") ? "-use_overlays" : "-nouse_overlays"
						useBackdrops := If (Use_Backdrops = "true") ? "-use_backdrops" : "-nouse_backdrops"
						BezelStart(romName,ListXMLtable[1],ListXMLtable[2],ListXMLtable[3],ListXMLtable[4])
					} Else {
						useBezels := "-nouse_bezels"
						useOverlays := "-nouse_overlays"
						useBackdrops := "-nouse_backdrops"
						BezelStart(,,ListXMLtable[2])
				; -romload part of 147u2 that shows what roms were checked when missing roms
				winstate := If (Fullscreen = "true") ? "Hide UseErrorLevel" : "UseErrorLevel"
				fullscreen := If (Fullscreen = "true") ? "-nowindow" : "-window"
				videomode := If (Videomode != "" ) ? "-video " . videomode : ""
				sysParams := If sysParams != ""  ? sysParams : ""
				romParams := If romParams != ""  ? romParams : ""
				StringReplace,mameRomPaths,romPathFromIni,|,`"`;`",1	; replace all instances of | to ; in the Rom_Path from Emulators.ini so mame knows where to find your roms
				mameRomPaths := "-rompath """ .  (If mameRomName ? romPath : mameRomPaths) . """"	; if using an alt rom, only supply mame with the path to that rom so it doesn't try to use the original rom
				If InStr(romParams,"-rompath")
					ScriptError("""-rompath"" is defined as a parameter for " . romName . ". The MAME module fills this automatically so please remove this from Params in the module's settings.")
				If InStr(sysParams,"-rompath")
					ScriptError("""-rompath"" is defined as a parameter for " . systemName . ". The MAME module fills this automatically so please remove this from Params in the module's settings.")
				If mameRomName {
					FileMove, %romPath%\%romName%%romExtension%, %romPath%\%mameRomName%%romExtension%	; rename rom to match what mame needs
					originalRomName := romName	; store romName from database so we know what to rename it back to later
					romName := mameRomName
					If ErrorLevel
						ScriptError("There was a problem renaming " . romName . "  to " . mameRomName . " in " . romPath . ". Please check you have write permission to this folder/file and you don't already have a file named """ . mameRomName . """ in your rom folder.",8)
					Else	; if rename was successful, set var so we know to move it back later
						fileRenamed = 1
				If cheatMode = true
				{	If cheatModeKey	; if user wants to use a key to enable CheatMode
						cheatEnabled := If XHotkeyAllKeysPressed(cheatModeKey) ? "-cheat" : ""
					Else	; no cheat mode key defined
						cheatEnabled := "-cheat"
				If hideConsole = true
					SetTimer, HideConsole, 10
				Run(executable . A_Space . romName . A_Space . fullscreen . A_Space . cheatEnabled . A_Space . videomode . A_Space . useBezels . A_Space . useOverlays . A_Space . useBackdrops . A_Space . mameRomPaths . A_Space . sysParams . A_Space . romParams, emuPath, winstate)
				If(ErrorLevel != 0){
					If (ErrorLevel = 1)
						Error = Failed Validity
					Else If(ErrorLevel = 2)
						Error = Missing Files
					Else If(ErrorLevel = 3)
						Error = Fatal Error
					Else If(ErrorLevel = 4)
						Error = Device Error
					Else If(ErrorLevel = 5)
						Error = Game Does Not Exist
					Else If(ErrorLevel = 6)
						Error = Invalid Config
					Else If ErrorLevel in 7,8,9
						Error = Identification Error
					Else
						Error = MAME Error
					ScriptError("MAME Error - " . Error)
				WinWait("ahk_class MAME")
				WinWaitActive("ahk_class MAME")
				BezelDraw()
				FadeInExit()
				BezelExit()
				If fileRenamed {	; rename file back to alternate name for next launch
					FileMove, %romPath%\%romName%%romExtension%, %romPath%\%originalRomName%%romExtension%
					If ErrorLevel	; if rename was successful, set var so we know to move it back later
						ScriptError("There was a problem renaming " . romName . " back to " . originalRomName)
				FadeOutExit()
				ExitModule()
				ListXMLInfo(rom){ ; returns MAME/MESS info about parent rom, orientation angle, resolution
					Global emuFullPath, emuPath
					ListXMLtable := []
					RunWait, % comspec . " /c " . """" . emuFullPath . """" . " -listxml " . rom . " > tempBezel.txt", %emuPath%, Hide
					Fileread, ListxmlContents, %emuPath%\tempBezel.txt
					RegExMatch(ListxmlContents, "s)<game.*name=" . """" . rom . """" . ".*" . "cloneof=" . """" . "[^""""]*", parent)
					RegExMatch(parent,"cloneof=" . """" . ".*", parent)
					RegExMatch(parent,"""" . ".*", parent)
					StringTrimLeft, parent, parent, 1
					RegExMatch(ListxmlContents, "s)<display.*rotate=" . """" . "[0-9]+" . """", angle)
					RegExMatch(angle,"[0-9]+", angle, "-6")
					RegExMatch(ListxmlContents, "s)<display.*width=" . """" . "[0-9]+" . """", width)
					RegExMatch(width,"[0-9]+", width, "-6")
					RegExMatch(ListxmlContents, "s)<display.*height=" . """" . "[0-9]+" . """", Height)
					RegExMatch(Height,"[0-9]+", Height, "-6")
					ListXMLtable[1] := parent
					ListXMLtable[2] := angle
					If (ListXMLtable[2]<>0)
						ListXMLtable[3] := height
					Else
						ListXMLtable[3] := width
						ListXMLtable[4] := width
					Else
						ListXMLtable[4] := height
					FileDelete, %emuPath%\tempBezel.txt
					Return ListXMLtable
				HaltEmu:
					If pauseMethod = 1
					{	disableSuspendEmu = true
						disableRestoreEmu = true
						PostMessage,0x211, 1, , , ahk_class MAME
					} Else If pauseMethod = 2
					} Else If pauseMethod = 3
						PostMessage,% 0x0400+6, 1, , , ahk_class MAME
					} Else If pauseMethod = 4
					} Else If pauseMethod = 5
						Send, {P down}
						Sleep, 1000
						Send, {P up}
				Return
				RestoreEmu:
					If pauseMethod = 1
					{	PostMessage,0x212, 1, , , ahk_class MAME
						WinActivate, ahk_class MAME
					{	PostMessage,% 0x0400+6, 0, , , ahk_class MAME
						Send, {P down}
						Sleep, 1000
						Send, {P up}
					} Else If pauseMethod = 6
				Return
				HideConsole:
					hideConsoleTimer++
					IfWinExist, ahk_class ConsoleWindowClass
					{	Log("Module - HideConsole - Console window found, hiding it out of view.")
						WinSet, Transparent, 0, ahk_class ConsoleWindowClass
						SetTimer, HideConsole, Off
					} Else If hideConsoleTimer >= 200
				Return
				CloseProcess:
					FadeOutStart()
					WinClose("ahk_class MAME")
				Return
19:35:48:659 | HL |     INFO  | +0     | BuildScript - Loaded Statistics.ahk script
19:35:48:659 | HL |     INFO  | +0     | BuildScript - Loaded User Functions.ahk script
19:35:48:659 | HL |     INFO  | +0     | BuildScript - Finished injecting functions into module
19:35:48:659 | HL |     INFO  | +0     | Main - Module is built
19:35:48:659 | HL |     INFO  | +0     | CheckFile - Checking if T:\HyperSpin\HyperLaunch\AutoHotkey.dll exists
19:35:48:673 | HL |   DEBUG1  | +15    | CheckFile - Attributes:
				File Size:			785408 bytes
19:35:48:682 | HL |     INFO  | +16    | Main - Hiding desktop
19:35:48:686 | HL |     INFO  | +0     | Main - Running module
19:35:48:686 | HL |     INFO  | +0     | Main - Starting timer to watch if Front End gets displaced and restore it if it does.
19:35:48:755 | MD |     INFO  | +N/A   | Module initialized
19:35:48:758 | MD |     INFO  | +0     | StartModule - Started
19:35:48:758 | MD |     INFO  | +0     | StartModule - MEmu: MAME
				MEmuV: v0.148
				MURL: http://www.mame.net/
				MAuthor: djvj
				MVersion: 2.0.6
				MCRC: D558F163
				iCRC: CD775A90
				MID:
				MSystem: "AAE","Cave","LaserDisc","MAME","Nintendo Arcade Systems","Sega Model 1","Sega ST-V","SNK Neo Geo","SNK Neo Geo AES"
19:35:48:758 | MD |     INFO  | +0     | StartModule - You have a supported System Name for this module: "MAME"
19:35:48:758 | MD |   DEBUG1  | +0     | StartModule - Setting romName to the dbName sent to HyperLaunch:
19:35:48:758 | MD |     INFO  | +0     | StartModule - Ended
19:35:48:758 | MD |     INFO  | +0     | StartGlobalUserFeatures - Starting
19:35:48:758 | MD |     INFO  | +0     | StartGlobalUserFeatures - Ending
19:35:48:758 | MD |     INFO  | +0     | CheckFile - Checking if T:\HyperSpin\HyperLaunch\Modules\MAME\MAME.ini exists
19:35:48:772 | MD |   DEBUG1  | +16    | CheckFile - Attributes:
				File Size:			2352 bytes
				Created:			11/18/2013 - 9:36:53 PM
				Modified:			11/18/2013 - 9:36:53 PM
19:35:48:772 | MD |     INFO  | +0     | Module Setting - Fullscreen: true
19:35:48:772 | MD |     INFO  | +0     | Module Setting - Videomode: d3d
19:35:48:773 | MD |     INFO  | +0     | Module Setting - HideConsole: true
19:35:48:773 | MD |     INFO  | +0     | Module Setting - PauseMethod: 4
19:35:48:773 | MD |     INFO  | +0     | Module Setting - BezelMode: normal
19:35:48:773 | MD |     INFO  | +0     | Module Setting - CheatMode: true
19:35:48:773 | MD |     INFO  | +0     | Module Setting - CheatModeKey: Z&X
19:35:48:773 | MD |     INFO  | +0     | Module Setting - Use_Bezels: true
19:35:48:773 | MD |     INFO  | +0     | Module Setting - Use_Overlays: true
19:35:48:773 | MD |     INFO  | +0     | Module Setting - Use_Backdrops: true
19:35:48:774 | MD |     INFO  | +0     | Module Setting - Use_Backdrops: true
19:35:48:774 | MD |     INFO  | +0     | Module Run - Running: T:\HyperSpin\Emulators\MAME\mame.exe 1942b -nowindow  -video d3d    -rompath "T:\HyperSpin\Emulators\MAME\roms";"T:\HyperSpin\Roms\mame"
19:35:48:883 | MD |     INFO  | +109   | Module - HideConsole - Console window found, hiding it out of view.
19:35:52:020 | MD |   DEBUG1  | +3135  | Module Run - "mame.exe 1942b -nowindow  -video d3d    -rompath "T:\HyperSpin\Emulators\MAME\roms";"T:\HyperSpin\Roms\mame"  " Process ID: 3948
19:35:52:021 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: BlackScreen | Class: AutoHotkeyGUI | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0x3a05de | Process ID: 4256 | Process Path: T:\HyperSpin\HyperLaunch\HyperLaunch.exe
19:35:52:021 | MD |     INFO  | +0     | Module WinWait - Waiting for ahk_class MAME
19:35:53:405 | MD |   DEBUG1  | +1389  | GetActiveWindowStatus - Title: MAME: 1942 (First Version) [1942b] | Class: MAME | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0x80390 | Process ID: 3948 | Process Path: T:\HyperSpin\Emulators\MAME\mame.exe
19:35:53:405 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: MAME: 1942 (First Version) [1942b] | Class: MAME | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0x80390 | Process ID: 3948 | Process Path: T:\HyperSpin\Emulators\MAME\mame.exe
19:35:53:405 | MD |     INFO  | +0     | Module WinWaitActive - Waiting for "ahk_class MAME"
19:35:53:520 | MD |   DEBUG1  | +109   | GetActiveWindowStatus - Title: MAME: 1942 (First Version) [1942b] | Class: MAME | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0x80390 | Process ID: 3948 | Process Path: T:\HyperSpin\Emulators\MAME\mame.exe
19:35:53:520 | MD |     INFO  | +0     | Module Process - WaitClose mame.exe
19:36:49:009 | MD |   DEBUG1  | +55489 | CloseProcess started, user requested to end launched application
19:36:49:009 | MD |     INFO  | +0     | Module WinClose - Closing: ahk_class MAME
19:36:49:320 | MD |   DEBUG1  | +312   | CloseProcess ended
19:36:49:321 | MD |     INFO  | +0     | StopGlobalUserFeatures - Starting
19:36:49:321 | MD |     INFO  | +0     | StopGlobalUserFeatures - Ending
19:36:49:321 | MD |     INFO  | +0     | ExitModule - Started
19:36:49:321 | MD |     INFO  | +0     | Starting Updating Statistics:
19:36:49:322 | MD |   DEBUG2  | +0     | Total Elapsed Time in Pause in seconds: 0
19:36:49:322 | MD |   DEBUG2  | +0     | gameSectionStartTime:115931971
19:36:49:322 | MD |   DEBUG2  | +0     | ElapsedTime:60
19:36:49:322 | MD |     INFO  | +0     | CreateRomTable - Started
19:36:49:322 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "1942b" and "(Disc"
19:36:49:322 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "1942b" and "(Disk"
19:36:49:322 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "1942b" and "(Cart"
19:36:49:322 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "1942b" and "(Tape"
19:36:49:322 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "1942b" and "(Cassette"
19:36:49:322 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "1942b" and "(Part"
19:36:49:322 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "1942b" and "(Side"
19:36:49:322 | MD |     INFO  | +0     | CreateRomTable - Ended, 7 Loops to create table.
19:36:49:322 | MD |   DEBUG2  | +0     | Statistics cleared game name: 1942b
19:36:49:388 | MD |   DEBUG2  | +63    | Loaded game statistics from ini files:
				Number_of_Times_Played: 0
				Last_Time_Played: 0
				Average_Time_Played: 0
				Total_Time_Played: 0
				System_Total_Played_Time: 5814
				Total_Global_Played_Time: 15686
19:36:49:388 | MD |   DEBUG2  | +0     | Updated Statistics: Number_of_Times_Played: 1
				Last_Time_Played: Wednesday May 28, 2014 07:36:49 PM
				Average_Time_Played: 60
				Total_Time_Played: 60
				System_Total_Played_Time: 5874
				Total_Global_Played_Time: 15746
19:36:49:421 | MD |     INFO  | +31    | Game section statistics updated.
19:36:49:421 | MD |     INFO  | +0     | ExitModule - Ended
19:36:49:422 | MD |     INFO  | +0     | End of Module Logs
19:36:49:475 | HL |     INFO  | +60793 | Main - Module ended, exiting HyperLaunch normally
19:36:49:475 | HL |     INFO  | +0     | ExitScript - Started
19:36:49:477 | HL |   DEBUG1  | +0     | ExitScript - Putting HyperSpin.exe back in focus
Speakers didn't change anything. :vollkommenauf:
				OS: WIN_7
				AutoHotkey Path:
				Unicode: No
				FileVersion             	3.0.0.9
				FileVersion             	9.20
				InternalName            	7z
				ProductVersion          	9.20
				FileVersion             	9.20
				InternalName            	7za
				ProductVersion          	9.20
				InternalName            	MAME
				ProductName             	MAME
				#NoTrayIcon
				#InstallKeybdHook
				SendMode, Event
				0 = 2
				frontendPID = 5480
				frontendExt = exe
				frontendDrive = T:
				forceHoldKey = ~Esc
				restoreFE = false
				emuName = MAME
				emuExt = exe
				romExtension = .zip
				systemName = MAME
				dbName = 1942b
				romName =
				romMapPath =
				skipchecks = false
				romMatchExt = true
				logLevel = 10
				navUpKey = Up
				navDownKey = Down
				navLeftKey = Left
				navRightKey = Right
				dtEnabled = true
				dtPath =
				dtUseSCSI = true
				dtAddDrive = true
				emuIdleShutdown = 0
				hideEmu = false
				hideFE = false
				fadeIn = false
				fadeInDelay = 0
				fadeInExitDelay = 0
				fadeOut = false
				fadeOutDelay = 0
				fadeLyr2X = 300
				fadeLyr2Y = 300
				fadeLyr2Adjust = 1
				fadeLyr2PicPad = 0
				fadeLyr3X = 300
				fadeLyr3Y = 300
				fadeLyr3Speed = 750
				fadeLyr3Repeat = 1
				fadeLyr3PicPad = 0
				fadeLyr4X = 100
				fadeLyr4Y = 100
				fadeLyr4FPS = 10
				fadeLyr4PicPad = 0
				fadeBarWindowX =
				fadeBarWindowY =
				fadeBarWindowR = 20
				fadeBarWindowM = 20
				fadeBarBack = true
				fadeBarH = 20
				fadeBarR = 5
				fadeBarXOffset = 0
				fadeText1X = 0
				fadeText1Y = 0
				fadeText2X = 0
				fadeText2Y = 0
				fadeFont = Arial
				fadeInterruptKey =
				moduleName = MAME
				7zEnabled = false
				7zExtractPathOrig =
				7zDelTemp = true
				7zSounds = true
				mgEnabled = false
				mgKey = ~NumpadSub
				mgSidePadding = 0.2
				mgYOffset = 500
				mgImageAdjust = 0
				mgFont = Arial
				mgText2Offset = 70
				mgUseSound = true
				mgSoundfreq = 300
				mgExitEffect = none
				hpEnabled = false
				hpKey = ~NumpadAdd
				hpZoomInKey = C
				hpZoomOutKey = V
				keymapper =
				CustomJoyNames =
				MEmu = MAME
				MEmuV =  v0.148
				MAuthor = djvj
				MVersion = 2.0.6
				MCRC = D558F163
				iCRC = CD775A90
				; Notes:
				StartModule()
				FadeInStart()
					} Else {
				If mameRomName {
					If ErrorLevel
						fileRenamed = 1
				If cheatMode = true
					If (ErrorLevel = 1)
						Error = Fatal Error
					Else
						Error = MAME Error
				BezelDraw()
				FadeInExit()
				BezelExit()
				FadeOutExit()
				ExitModule()
					ListXMLtable := []
					Else
					Else
					Return ListXMLtable
				HaltEmu:
					If pauseMethod = 1
						Send, {P down}
						Sleep, 1000
						Send, {P up}
				Return
				RestoreEmu:
					If pauseMethod = 1
						Send, {P down}
						Sleep, 1000
						Send, {P up}
				Return
				HideConsole:
					hideConsoleTimer++
				Return
				CloseProcess:
					FadeOutStart()
				Return
				MEmuV: v0.148
				MAuthor: djvj
				MVersion: 2.0.6
				MCRC: D558F163
				iCRC: CD775A90
				MID:
				Last_Time_Played: 0
