SteveB69 Posted November 6, 2013 Posted November 6, 2013 Until recently I had a happy working cab that supported one ledwiz drive. I managed to blow this drive so ordered 2 new ones from groovygame gear. The two new ones are both labelled Dev 2. I cannot for the life of me to get the ledwiz to work with tables in VP. So far I have it working under the lum aura control, under the DOF test config panel & it also works in ledblinky. I have tried this using the Legacy output & the Direct Output Framework. Have configured my ledcontrol.ini via the [site reference removed] config tool. I've created different table folders, one for legacy & one for DOF. i've un-installed VP & re-installed. I don't know what to do, I've emailed groovygame for support & posted loads of various forums but zilcho! Can anyone teamviewer to my PC (or similar) & see what I'm doing wrong. If you can help please PM me & we can arrange a price & a time asap to do it? Thanks The PC: Win 7: 3.59 AMD A8-5600K APU, 8GB RAM. NVidia Geforce GT560 ti (Playfield), AMD Radeon HD 7560D (Backglass &DMD) The Cab: 5 x Contactors (2 x Flippers, 3 x Bumpers), 20 x LEDs 8 for slingshots, 12 for bumpers. 3 x Strobe Lights - Run through Ledwiz Buttons: 2 x Flippers, 2 x Magna Saves, 1 & 2 player, Start, Launch Ball, 6 admin buttons - Run through IPac.
megabyte417 Posted November 6, 2013 Posted November 6, 2013 Hi SteveB, You mentioned both LedWiz devices are labeled #2. Numbers should be different. Example, device #1, #2, #3, etc. If your using just one device you will need to have purchased a #1. Since your using 2 devices, you should have ordered a #1 and #2. You should contact Randy T at GGG as he maybe able to assist. Good luck with your system :-)
SteveB69 Posted November 6, 2013 Author Posted November 6, 2013 I've just spoken to Randy & apparently it doesn't matter that the device is labelled Dev 2. I bought 2 ledwiz for different machines so only 1 x Dev 2 ledwiz is in my cab? I still have my old ledwiz Dev 1 & had this plugged in but it didn't make it work. The PC: Win 7: 3.59 AMD A8-5600K APU, 8GB RAM. NVidia Geforce GT560 ti (Playfield), AMD Radeon HD 7560D (Backglass &DMD) The Cab: 5 x Contactors (2 x Flippers, 3 x Bumpers), 20 x LEDs 8 for slingshots, 12 for bumpers. 3 x Strobe Lights - Run through Ledwiz Buttons: 2 x Flippers, 2 x Magna Saves, 1 & 2 player, Start, Launch Ball, 6 admin buttons - Run through IPac.
megabyte417 Posted November 6, 2013 Posted November 6, 2013 Ahh ok, good to know. I thought that may have been the problem. I am stumped now as well. Maybe someone else on the HS forum maybe able to jump into the convo and assist you with your issue.
SteveB69 Posted November 6, 2013 Author Posted November 6, 2013 >>>Maybe someone else on the HS forum maybe able to jump into the convo and assist you with your issue. I do hope so, I am so missing my LEDS & Contactors! The PC: Win 7: 3.59 AMD A8-5600K APU, 8GB RAM. NVidia Geforce GT560 ti (Playfield), AMD Radeon HD 7560D (Backglass &DMD) The Cab: 5 x Contactors (2 x Flippers, 3 x Bumpers), 20 x LEDs 8 for slingshots, 12 for bumpers. 3 x Strobe Lights - Run through Ledwiz Buttons: 2 x Flippers, 2 x Magna Saves, 1 & 2 player, Start, Launch Ball, 6 admin buttons - Run through IPac.
