AutoHotKey - Call to nonexistent function
kcstol
I keep getting a bunch of Call to nonexistent function errors when trying to run certain modules...MAME, Neo Geo, Sega, etc.
Most of the time it complains about a ServoStik function
I've tried fiddling with the AutoHotKey.dll in HyperLaunch, the AutoHotKey Module Extensions, updating AutoHotKey on my machine, removing it. I even tried using fresh AHKs for MAME.
Here are the versions...
HyperLaunch: 3.0.1.0
DLL: 1.0.0.1
HQ: 1.0.11.0
Thanks for the help...
I messed up that line, I had screenshots in there and the forum wouldn't let me post. I've been so deep in this I just typed the wrong thing. Versions are correct now.
If you can update HyperLaunch in HyperLaunchHQ, I don't see a setting for it. I'm guessing that's a newer RocketLauncher feature.
I also tried running in Admin but I got same errors.
Thanks for your help.
RocketLAuncher has built in updating. HyperLaunch you had to manually update it all and since it hasn't been supported or updated in nearly a year you might have it as up to date as it can be.
Could it be caused by having a servo-stick option turned on in the HyperLaunchHQ settings? (If it even has that option. I know RL does)
