pind112 Posted April 30, 2016 Posted April 30, 2016 i can't use my "left - right - up - down" keys on my controlpad in hyperpause ?
Spawk Posted April 30, 2016 Posted April 30, 2016 In rocketlauncher, there are three basic profiles: Hyperspin RocketLauncher _Default The RocketLauncher profile is the one to edit for pause. Sent from my SGH-I337M using Tapatalk
pind112 Posted April 30, 2016 Author Posted April 30, 2016 Yes i know that But can't get it to work.. Works fine in Hyperspin, but not in hyperpause I can get the selection key to work, but not the left/right/up/down ?
pind112 Posted April 30, 2016 Author Posted April 30, 2016 SOLVED: In JoyToKey, go into to Options tab. In the "Keyboard emulation mode" drop-down menu, select Alternative 2 (Scancode base).
wrufai Posted May 7, 2017 Posted May 7, 2017 I have the same issue with hyperpause not being able to recognize my xin-mo directional arcade controls. I tried to use the suggested joy2key solution and it stll does not work. Any other suggestions?
lsudolemite Posted May 29, 2017 Posted May 29, 2017 On 5/7/2017 at 2:59 PM, wrufai said: I have the same issue with hyperpause not being able to recognize my xin-mo directional arcade controls. I tried to use the suggested joy2key solution and it stll does not work. Any other suggestions? A couple of things: 1. Make sure you have a global RocketLauncher Joy2Key profile created and configured, this is what Pause will use once it's toggled. (GLOBAL in left menu -> Keymapper tab -> Joy2Key subtab). 2. Also make sure Joy2Key is set to your default keymapper (GLOBAL left menu -> Settings tab -> Mapping subtab -> Keymapper).
