Mame open a game then close!
greenhunter1983
When i start a mame game in RocketLaucher or Hyperspin the game is opened and then close after.
PLEASE HELPME! (i change win10 to win7, install all DirectX i try everything.)
MY SETUP: (HS1.4+RL v1.01.5+MAMEUIFX .153 x64 )
HS Log:
12:03:46 PM |  HyperSpin Started
12:03:46 PM |  Going FullScreen
12:03:46 PM |  Checking for updates
12:03:46 PM |  Update Check Complete
12:03:46 PM |  Startup program: HyperSpin Startup Script.exe
12:03:46 PM |  Startup params not set
12:03:46 PM |  Working directory: E:\Hyperspin\Utilities\
12:03:46 PM |  Window State: NORMAL
12:03:46 PM |  Launching HyperSpin Startup Script.exe
12:03:46 PM |  Command Line is HyperSpin Startup Script.exe
12:03:47 PM |  Error intializing joysticks
12:03:47 PM |  Menu Mode is multi
12:03:47 PM |  Loading Main Menu.xml
12:03:47 PM |  Main Menu.xml successfully loaded
12:03:48 PM |  Main Menu wheel loaded successfully
12:03:52 PM |  Loading Super Nintendo Entertainment System.xml
12:03:53 PM |  roms_only is true, checking files
12:03:53 PM |  Main Menu.xml successfully loaded
12:03:53 PM |  Super Nintendo Entertainment System wheel loaded successfully
12:04:05 PM |  Loading Main Menu.xml
12:04:05 PM |  Main Menu.xml successfully loaded
12:04:05 PM |  Main Menu wheel loaded successfully
12:04:11 PM |  Loading SNK Classics.xml
12:04:11 PM |  roms_only is true, checking files
12:04:11 PM |  Error: roms_only is true and there are no rom files for SNK Classics
12:04:11 PM |  Loading Main Menu.xml
12:04:11 PM |  Main Menu.xml successfully loaded
12:04:12 PM |  Main Menu wheel loaded successfully
12:04:12 PM |  Loading SNK Classics.xml
12:04:12 PM |  roms_only is true, checking files
12:04:12 PM |  Error: roms_only is true and there are no rom files for SNK Classics
12:04:12 PM |  Loading Main Menu.xml
12:04:12 PM |  Main Menu.xml successfully loaded
12:04:13 PM |  Main Menu wheel loaded successfully
12:04:15 PM |  Loading Taito Classics.xml
12:04:15 PM |  roms_only is true, checking files
12:04:15 PM |  Error: roms_only is true and there are no rom files for Taito Classics
12:04:15 PM |  Loading Main Menu.xml
12:04:15 PM |  Main Menu.xml successfully loaded
12:04:15 PM |  Main Menu wheel loaded successfully
12:04:18 PM |  Loading Taito Classics.xml
12:04:18 PM |  roms_only is true, checking files
12:04:18 PM |  Error: roms_only is true and there are no rom files for Taito Classics
12:04:18 PM |  Loading Main Menu.xml
12:04:18 PM |  Main Menu.xml successfully loaded
12:04:18 PM |  Main Menu wheel loaded successfully
12:04:19 PM |  Loading Williams Classics.xml
12:04:19 PM |  roms_only is true, checking files
12:04:19 PM |  Error: roms_only is true and there are no rom files for Williams Classics
12:04:19 PM |  Loading Main Menu.xml
12:04:19 PM |  Main Menu.xml successfully loaded
12:04:20 PM |  Main Menu wheel loaded successfully
12:04:22 PM |  Loading Nintendo Classics.xml
12:04:22 PM |  roms_only is true, checking files
12:04:22 PM |  Error: roms_only is true and there are no rom files for Nintendo Classics
12:04:22 PM |  Loading Main Menu.xml
12:04:22 PM |  Main Menu.xml successfully loaded
12:04:23 PM |  Main Menu wheel loaded successfully
12:04:24 PM |  Loading Namco Classics.xml
12:04:24 PM |  roms_only is true, checking files
12:04:24 PM |  Error: roms_only is true and there are no rom files for Namco Classics
12:04:24 PM |  Loading Main Menu.xml
12:04:24 PM |  Main Menu.xml successfully loaded
12:04:25 PM |  Main Menu wheel loaded successfully
12:04:27 PM |  Loading MAME.xml
12:04:27 PM |  Main Menu.xml successfully loaded
12:04:28 PM |  MAME wheel loaded successfully
12:04:44 PM |  MAME wheel loaded successfully
12:04:55 PM |  MAME wheel loaded successfully
12:05:47 PM |  Launching Game
12:05:47 PM |  Using HyperLaunch
12:05:47 PM |  Getting Launcher path
12:05:47 PM |  Launcher located at E:\RocketLauncher\RocketLauncher.exe
12:05:47 PM |  Running Launcher
12:05:47 PM |  Launcher Command Line is: E:\RocketLauncher\RocketLauncher.exe "MAME" "mslug"
12:24:43 PM |  Loading Main Menu.xml
12:24:43 PM |  Main Menu.xml successfully loaded
12:24:43 PM |  Main Menu wheel loaded successfully
12:24:44 PM |  Exit program unavailable
12:24:44 PM |  Quiting Hyperspin
12:24:44 PM |  Bye!
RocketLaucher Log:
12:05:49:168 | RL |     INFO  | +N/A   | Main - RocketLauncher v1.0.1.5a (www.rlauncher.com)
12:05:49:283 | RL |     INFO  | +109   | Main - System Specs:
                    RocketLauncher Dir: E:\RocketLauncher
                    RocketLauncher is: 32-bit
                    OS: Microsoft Windows 7 Ultimate
                    SKU: Ultimate
                    Total Memory: 8183.12 MB
                    Free Memory: 6012.71 MB
                    Used Memory: 2170.402 MB
                    SystemType: 64-bit
                    Physical Processors: 1
                    Logical Processors: 4
                    GPU 1 Name: AMD Radeon HD 6570
                    GPU 1 RAM: 1024.00 MB
                    GPU 1 Driver Version: 15.200.1062.1004
                    Sound 1 Device: Dispositivo de áudio USB
                    Sound 1 Status: Enabled
                    Sound 2 Device: AMD High Definition Audio Device
                    Sound 2 Status: Enabled
                    Sound 3 Device: Realtek High Definition Audio
                    Sound 3 Status: Enabled
                    OS Language: Portuguese_Brazilian
                    System Locale: pt-BR
                    Formats Locale: pt-BR
                    Windows UI Language: pt-BR
                    Text Encoding: Windows-1252
                    OS Admin Status: No
                    Latest .Net Version: v4.0.30319
                    Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1040 work) [32bit] [60hz] [Landscape]  (Primary)
                    Current AHK Desktop Width: 1920
                    Current AHK Desktop Height: 1080
                    AutoHotkey Path:
                    AHK Version: 1.1.09.04
                    Unicode: No
12:05:49:283 | RL |     INFO  | +0     | CheckFile - Checking if E:\RocketLauncher\RocketLauncher.exe exists
12:05:49:283 | RL |     INFO  | +0     | Main - Loading Front End Plugin: "HyperSpin"
12:05:49:283 | RL |     INFO  | +0     | Main - HyperSpin.exe coordinates are x0 y0 w1920 h1080
12:05:49:283 | RL |     INFO  | +0     | Main - RocketLauncher received "MAME" and "mslug"
12:05:49:308 | RL |     INFO  | +31    | Main - Did not find a "E:\RocketLauncher\Settings\MAME\Game Options.ini" file, skipping any game-specific options.
12:05:49:308 | RL |     INFO  | +0     | Main - mslug is using the default emulator: MAME
12:05:49:308 | RL |     INFO  | +0     | Main - Checking for a [MAME] section in E:\RocketLauncher\Settings\MAME\Emulators.ini
12:05:49:308 | RL |     INFO  | +0     | Main - Checking for a [MAME] section in E:\RocketLauncher\Settings\Global Emulators.ini
12:05:49:308 | RL |     INFO  | +0     | Main - Found [MAME] in E:\RocketLauncher\Settings\Global Emulators.ini
12:05:49:308 | RL |     INFO  | +0     | CheckFile - Checking if E:\RocketLauncher\Modules\MAME\MAME.ahk exists
12:05:49:313 | RL |     INFO  | +0     | Main - CRC Check - CRC matches, this is an official unedited module.
12:05:49:313 | RL |     INFO  | +0     | Main - mslug will use module: E:\RocketLauncher\Modules\MAME\MAME.ahk
12:05:49:333 | RL |     INFO  | +16    | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
12:05:49:333 | RL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Emulators\MAMEUIFX\MAMEUIFX .153 FIX x64 NoNag+HiScore+NeoGeoXtra+DirectInput.exe exists
12:05:49:333 | RL |     INFO  | +0     | Main - INI Keys read
12:05:49:333 | RL |     INFO  | +0     | CheckFile - Checking if E:\RocketLauncher\Module Extensions\7z.exe exists
12:05:49:338 | RL |     INFO  | +16    | CheckFile - Checking if E:\RocketLauncher\Module Extensions\7z.dll exists
12:05:49:338 | RL |     INFO  | +0     | Main - "mslug" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side
12:05:49:338 | RL |     INFO  | +0     | CheckPaths - Started
12:05:49:338 | RL |     INFO  | +0     | CheckPaths - Found rom: E:\Hyperspin\Roms\MAME-Neo Geo-Arcade Classics-CPS-Sega STV\mslug.zip
12:05:49:338 | RL |     INFO  | +0     | CheckPaths - Ended,
12:05:49:338 | RL |     INFO  | +0     | BuildScript - User Variables:
                    ; INJECTED VARIABLES
                    #NoTrayIcon
                    #InstallKeybdHook
                    DetectHiddenWindows, ON
                    SetTitleMatchMode, 2
                    SendMode, Event
                    0 = 2
                    pluginPath = E:\RocketLauncher\Plugins
                    pluginName = HyperSpin
                    pluginExt = .plugin
                    contextOnExit =
                    rlMode =
                    rlTitle = RocketLauncher
                    rlVersion = 1.0.1.5a
                    rlAuthor = djvj
                    rlURL = www.rlauncher.com
                    langFile = E:\RocketLauncher\Data\Language\Localization.ini
                    primMonitor = 1
                    frontendPID = 2820
                    frontendPath = E:\Hyperspin
                    frontendExe = HyperSpin.exe
                    frontendExt = exe
                    frontendName = HyperSpin
                    frontendDrive = E:
                    exitEmulatorKey = ~Esc
                    restoreFE = false
                    exitScriptKey = ~q & ~s
                    toggleCursorKey = ~e & ~t
                    emuFullPath = E:\Hyperspin\Emulators\MAMEUIFX\MAMEUIFX .153 FIX x64 NoNag+HiScore+NeoGeoXtra+DirectInput.exe
                    emuPath = E:\Hyperspin\Emulators\MAMEUIFX
                    emuName = MAME
                    emuExt = exe
                    baseRomPath = \MAME
                    romPath = E:\Hyperspin\Roms\MAME-Neo Geo-Arcade Classics-CPS-Sega STV
                    romPathFromIni = E:\Hyperspin\Roms\MAME-Neo Geo-Arcade Classics-CPS-Sega STV
                    romExtension = .zip
                    romExtensionOrig = .zip
                    romExtensions = 7z|rar|zip|chd|cue|32x|a26|a52|a78|bin|caq|col|cpr|gg|gb|gba|gbc|int|lnx|rom|sms|st2|md|j64|n64|nes|ngc|ngp|pce|sfc|sv|vb|vec|ws|wsc
                    executable = MAMEUIFX .153 FIX x64 NoNag+HiScore+NeoGeoXtra+DirectInput.exe
                    systemDbName = MAME
                    systemName = MAME
                    dbPath =
                    dbName = mslug
                    dbExt =
                    romName = mslug
                    romMapPath =
                    romMappingEnabled = false
                    romMappingHideParent = false
                    romMappingMenuWidth = 400
                    romMappingMenuMargin = 65
                    romMappingTextMargin = 15
                    romMappingGameNameTextFont = Bebas Neue
                    romMappingGameNameTextOptions = cFFFFFFFF r4 s40 Regular
                    romMappingMenuFlagWidth = 55
                    altArchiveNameOnly =
                    altRomNameOnly =
                    altArchiveAndRomName =
                    altArchiveAndManyRomNames =
                    altRomNamesOnly =
                    romMapScenario =
                    skipchecks = false
                    romMatchExt = false
                    blockInputTime = 0
                    blockInputFile = E:\RocketLauncher\Module Extensions\BlockInput.exe
                    errorLevelReporting = false
                    lockLaunch = false
                    lockLaunchGame =
                    screenRotationAngle = 0
                    screenRotationAngleGame =
                    setResolution =
                    logFile = E:\RocketLauncher\RocketLauncher.log
                    logLabel := ["    INFO"," WARNING","   ERROR","  DEBUG1","  DEBUG2"]
                    logLevel = 3
                    logShowDebugConsole = false
                    logIncludeModule = true
                    logShowCommandWindow = false
                    logCommandWindow = false
                    rlDebugConsoleStdout =
                    sysLang = Portuguese_Brazilian
                    sysType = 64-bit
                    broadcastWindowTitle =
                    navUpKey = Up
                    navDownKey = Down
                    navLeftKey = Left
                    navRightKey = Right
                    navSelectKey = Enter
                    navP2UpKey = Numpad8
                    navP2DownKey = Numpad2
                    navP2LeftKey = Numpad4
                    navP2RightKey = Numpad6
                    navP2SelectKey = NumpadEnter
                    originalWidth = 1920
                    originalHeight = 1080
                    vdEnabled = false
                    vdFullPath =
                    vdUseSCSI = true
                    vdDriveLetter =
                    vdAddDrive = true
                    servoStikEnabled = false
                    servoStikExitMode = false
                    ledblinkyEnabled = false
                    ledblinkySystemName =
                    ledblinkyFullPath =
                    ledblinkyProfilePath = E:\RocketLauncher\Profiles\LEDBlinky
                    ledblinkyRLProfile = E:\RocketLauncher\Profiles\LEDBlinky\RocketLauncher
                    winIPACFullPath =
                    ultraMapEnabled = false
                    ultraMapFullPath =
                    emuIdleShutdown = 0
                    hideCursor = false
                    hideEmu = false
                    hideFE = false
                    fadeIn = false
                    fadeInDuration = 500
                    fadeInDelay = 0
                    fadeInExitDelay = 0
                    fadeOutExitDelay = 0
                    fadeOut = false
                    fadeOutExtraScreen = false
                    fadeOutDuration = 500
                    fadeOutDelay = 0
                    fadeLyrInterpolation = 7
                    fadeMuteEmulator = false
                    fadeUseBackgrounds = false
                    fadeClickThrough = false
                    fadeWidthBaseRes = 1920
                    fadeHeightBaseRes = 1080
                    fadeLyr1Color = FF000000
                    fadeLyr2X = 0
                    fadeLyr2Y = 0
                    fadeLyr2W =
                    fadeLyr2H =
                    fadeLyr2Adjust = 1
                    fadeLyr2PicPad = 0
                    fadeLyr3Pos = Center
                    fadeLyr3X = 450
                    fadeLyr3Y = 450
                    fadeLyr3W =
                    fadeLyr3H =
                    fadeLyr3Adjust = 1
                    fadeLyr3PicPad = 0
                    fadeLyr3Speed = 750
                    fadeLyr3Type = imageandbar
                    fadeLyr3Repeat = 1
                    fadeLyr3StaticX = 0
                    fadeLyr3StaticY = 870|1575
                    fadeLyr3StaticW =
                    fadeLyr3StaticH =
                    fadeLyr3StaticAdjust = 1
                    fadeLyr3StaticPicPad = 0
                    fadeLyr4Adjust = 1
                    fadeLyr4X = 1792|952
                    fadeLyr4Y = 891|1596
                    fadeLyr4W = 128
                    fadeLyr4H =
                    fadeLyr4Pos = No Alignment
                    fadeLyr4FPS = 50
                    fadeLyr4PicPad = 0
                    fadeTranspGifColor = FFFFFF
                    fadeBarWindow = Image
                    fadeBarWindowX =
                    fadeBarWindowY =
                    fadeBarWindowW = 900
                    fadeBarWindowH =
                    fadeBarWindowR = 30
                    fadeBarWindowM = 30
                    fadeBarWindowHatchStyle = 8
                    fadeBar = 7zOnly
                    fadeBarNon7zProgressTime = 0
                    fadeBarBack = true
                    fadeBarBackColor = FF555555
                    fadeBarH = 30
                    fadeBarR = 10
                    fadeBarColor = DD00BFFF
                    fadeBarHatchStyle = 8
                    fadeBarPercentageText = true
                    fadeBarInfoText = true
                    fadeBarXOffset = 0
                    fadeBarYOffset = 150
                    fadeRomInfoSystemName = image
                    fadeRomInfoDeveloper = text with label
                    fadeRomInfoPublisher = text with label
                    fadeRomInfoGenre = disabled
                    fadeRomInfoRating = image
                    fadeRomInfoOrder = Description|SystemName|Year|Developer|Genre|Rating|Publisher
                    fadeRomInfoTextMargin = 7
                    fadeRomInfoText7Options = h135 x500 y960|1665 cFFCFCFCA r4 s66 Regular
                    fadeStatsInfoTextMargin = 7
                    fadeText1X = 0
                    fadeText1Y = 0
                    fadeText1 = Loading Game
                    fadeText2X = 0
                    fadeText2Y = 0
                    fadeText3 = Loading Game
                    fadeText4 = Loading Complete
                    fadeFont = Bebas Neue
                    fadeExtractionTime = disabled
                    fadeExtractionTimeTextX = 0
                    fadeExtractionTimeTextY = 0
                    fadeInterruptKey =
                    detectFadeErrorEnabled = true
                    fadeImgPath = E:\RocketLauncher\Media\Fade
                    RLDataPath = E:\RocketLauncher\Data
                    RLMediaPath = E:\RocketLauncher\Media
                    RLErrSoundPath = E:\RocketLauncher\Media\Sounds\Error
                    modulesPath = E:\RocketLauncher\Modules
                    moduleFullName = E:\RocketLauncher\Modules\MAME\MAME.ahk
                    moduleName = MAME
                    modulePath = E:\RocketLauncher\Modules\MAME
                    moduleExtension = ahk
                    moduleExtensionsPath = E:\RocketLauncher\Module Extensions
                    libPath = E:\RocketLauncher\Lib
                    sevenZEnabled = false
                    sevenZPath = E:\RocketLauncher\Module Extensions\7z.exe
                    sevenZDllPath = E:\RocketLauncher\Module Extensions\7z.dll
                    sevenZExtractPath = E:\RocketLauncher\temp
                    sevenZExtractPathOrig =
                    sevenZAttachSystemName = false
                    sevenZDelTemp = true
                    sevenZSounds = true
                    sevenZFormats = .zip|.rar|.7z|.lzh|.gzip|.tar
                    sevenZFormatsNoP = zip|rar|7z|lzh|gzip|tar
                    sevenZFormatsRegEx = \.zip|\.rar|\.7z|\.lzh|\.gzip|\.tar
                    7zExtractPath = E:\RocketLauncher\temp
                    mgEnabled = true
                    mgKey = ~NumpadSub
                    mgBackgroundColor = FF000000
                    mgSidePadding = 0.2
                    mgWidthBaseRes = 1920
                    mgHeightBaseRes = 1080
                    mgYOffset = 500|800
                    mgFont = Arial
                    mgText2Offset = 100
                    mgUseSound = true
                    mgSoundfreq = 300
                    mgExitEffect = none
                    mgSelectedEffect = rotate
                    mgUseGameArt = false
                    mgCandidate =
                    mgValidTypes = \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side
                    mgOnLaunch = false
                    pauseEnabled = false
                    pauseKey = ~NumpadAdd
                    pauseBackToMenuBarKey = X
                    pauseZoomInKey = C
                    pauseZoomOutKey = V
                    pauseHiToTextPath = E:\RocketLauncher\Module Extensions\HiToText.exe
                    pauseSaveStateKeyCodes = {shift down}{F7 down}{F7 up}{shift up}
                    pauseLoadStateKeyCodes = {F7 down}{F7 up}
                    keyboardEncoder =
                    keyboardEncoderEnabled = false
                    keymapperEnabled = false
                    keymapperAHKMethod = false
                    keymapper = xpadder
                    xpadderFullPath = E:\Utilities\Xpadder\xpadder.exe
                    joyToKeyFullPath = E:\Utilities\JoyToKey\JoyToKey.exe
                    profilePath = E:\RocketLauncher\Profiles
                    keymapperProfilePath = E:\RocketLauncher\Profiles\xpadder
                    keymapperFrontEndProfileName = RocketLauncherUI
                    joyIDsEnabled = false
                    joyIDsPreferredControllersGlobal =
                    joyIDsPreferredControllersSystem = use_global
                    joyIDsPreferredControllersOnExit =
                    CustomJoyNamesEnabled = false
                    CustomJoyNames =
                    rotateMethod = false
                    FEProfile = E:\RocketLauncher\Profiles\xpadder\RocketLauncherUI
                    defaultProfile = E:\RocketLauncher\Profiles\xpadder\_Default
                    systemProfile = E:\RocketLauncher\Profiles\xpadder\MAME
                    xPadderSystemProfile = E:\RocketLauncher\Profiles\xpadder\MAME\_Default
                    emuProfile = E:\RocketLauncher\Profiles\xpadder\MAME\MAME
                    romProfile = E:\RocketLauncher\Profiles\xpadder\MAME\mslug
                    RocketLauncherProfile = E:\RocketLauncher\Profiles\xpadder\RocketLauncher
                    blankProfile = E:\RocketLauncher\Profiles\xpadder\_Default\blank
                    ahkFEProfile = E:\RocketLauncher\Profiles\AHK\RocketLauncherUI
                    ahkDefaultProfile = E:\RocketLauncher\Profiles\AHK\_Default
                    ahkSystemProfile = E:\RocketLauncher\Profiles\AHK\MAME
                    ahkEmuProfile = E:\RocketLauncher\Profiles\AHK\MAME\MAME
                    ahkRomProfile = E:\RocketLauncher\Profiles\AHK\MAME\mslug
                    ahkRocketLauncherProfile = E:\RocketLauncher\Profiles\AHK\RocketLauncher
                    bezelEnabled = false
                    bezelICEnabled = false
                    statisticsEnabled = true
                    pressDuration = -1
                    emuVolume = 1
                    dxwndIni = E:\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini
                    dxwndFullPath = E:\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe
                    qResFullPath = E:\RocketLauncher\Module Extensions\QRes.exe
                    mon1O =
                    pacDrivedllFile = E:\RocketLauncher\Module Extensions\PacDrive32.dll
                    userFadeAnimIniFile = E:\RocketLauncher\Lib\User Fade Animations.ini
12:05:49:338 | RL |     INFO  | +0     | BuildScript - Loaded XHotkey Init.ahk scripts
12:05:49:338 | RL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
12:05:49:338 | RL |     INFO  | +0     | BuildScript - Loaded MultiGame Init.ahk scripts
12:05:49:338 | RL |  WARNING  | +0     | BuildScript - "E:\RocketLauncher\Lib\User Functions Init.ahk" not found
12:05:49:338 | RL |     INFO  | +0     | BuildScript - Validating module
12:05:49:348 | RL |     INFO  | +0     | BuildScript - Validation complete
12:05:49:348 | RL |     INFO  | +0     | BuildScript - Module:
                    MEmu = MAME
                    MEmuV =  v0.166
                    MURL = http://www.mame.net/
                    MAuthor = djvj,faahrev,brolly,Tomkun
                    MVersion = 2.3.1
                    MCRC = 9B041EF3
                    iCRC = 72BB0F21
                    mId = 635746812784197028
                    MSystem = "AAE","Aamber Pegasus","Acorn Electron","Amstrad CPC","Amstrad GX4000","APF Imagination Machine","Apple II","Apple IIGS","Applied Technology MicroBee","Atari 8-Bit","Atari 2600","Atari 5200","Atari 7800","Atari Classics","Atari Jaguar","Atari Lynx","Bally Astrocade","Bandai Super Vision 8000","Bandai WonderSwan","Bandai WonderSwan Color","Bit Corporation Gamate","Camputers Lynx","Capcom","Capcom Classics","Capcom Play System","Capcom Play System II","Capcom Play System III","Casio PV-1000","Casio PV-2000","Cave","Coleco ADAM","ColecoVision","Commodore 64","Commodore MAX Machine","Creatronic Mega Duck","Data East Classics","EACA EG2000 Colour Genie","Emerson Arcadia 2001","Entex Adventure Vision","Epoch Game Pocket Computer","Epoch Super Cassette Vision","Exidy Sorcerer","Fairchild Channel F","Fujitsu FM-7","Funtech Super Acan","GamePark 32","GCE Vectrex","Hartung Game Master","HBMAME","Interton VC 4000","Irem Classics","JungleTac Sport Vii","Jupiter Ace","Konami Classics","LaserDisc","Magnavox Odyssey 2","MAME","Matra & Hachette Alice","Mattel Aquarius","Mattel Intellivision","MGT Sam Coupe","Midway Classics","Milton Bradley MicroVision","Namco Classics","Namco System 22","NEC PC-8801","NEC PC Engine","NEC PC Engine-CD","NEC SuperGrafx","NEC TurboGrafx-16","NEC TurboGrafx-CD","Nintendo 64","Nintendo 64DD","Nintendo Arcade Systems","Nintendo Classics","Nintendo Entertainment System","Nintendo Famicom","Nintendo Famicom Disk System","Nintendo Game Boy","Nintendo Game Boy Advance","Nintendo Game Boy Color","Nintendo Pokemon Mini","Nintendo Satellaview","Nintendo Super Famicom","Nintendo Super Game Boy","Nintendo Virtual Boy","Othello Multivision","PacMAME","Philips CD-i","Philips VG 5000","Philips Videopac Plus G7400","RCA Studio II","Sega 32X","Sega CD","Sega Classics","Sega Game Gear","Sega Genesis","Sega Master System","Sega Mega Drive","Sega Model 1","Sega Pico","Sega Saturn","Sega SC-3000","Sega SG-1000","Sega ST-V","Sega VMU","Sharp X1","Sinclair ZX81","SNK Classics","SNK Neo Geo","SNK Neo Geo AES","SNK Neo Geo AES","SNK Neo Geo CD","SNK Neo Geo MVS","SNK Neo Geo Pocket","SNK Neo Geo Pocket Color","Sony PlayStation","Sony PocketStation","Sord M5","Soundic Victory MPT-02","Super Nintendo Entertainment System","Taito Classics","Tandy TRS-80 Color Computer","Texas Instruments TI 99-4A","Tiger Game.com","Tomy Tutor","VTech CreatiVision","Watara Supervision","Williams Classics"
                    ; Notes:
                    ; This module now includes everything from the legacy MAME and MESS modules, but combined to match the merge of the 2 emulators that occured on version 0.162.
                    ; Exit fade will only work correctly if you don't have Esc, the default MAME exit key,  as your exit key. If you use Esc, turn off the ExitScreen
                    ; This module will set your rom paths on the fly via CLI, but you must make sure the RLUI module setting for this module "MAME_BIOS_Path" is correctly set. It defaults to your roms subfolder where MAME.exe is found.
                    ; This module assumes you have bios zip in your MAME "roms" directory, which might be different than your actual roms directory, for each system you need this module for. All tested systems listed below
                    ; If MAME has a problem reading the bios zips, try archving them with "no compression"
                    ; This site can help a ton with details for the various systems supported: http://www.progettoemma.net/mess/index.html
                    ; You may get a black screen or MAME may close w/o notice if you do not have a bios rom for your system when one is needed.
                    ; If you use bezel, it is recommended to set the module bezel mode to normal, and go to your MAME.ini file, on your emulator folder, and choose these options: artwork_crop 1, use_backdrops 1, use_overlays 1, use_bezels 0
                    ; Command Line Options - http://easyemu.mameworld.info/mameguide/mameguide-options.html
                    ; High Scores DO NOT SAVE when cheats are enabled!
                    ; HLSL Documentation: http://mamedev.org/source/docs/hlsl.txt.html
                    ; If you use MAME for AAE, create a vector.ini in mame's ini subfolder and paste these HLSL settings in there: http://www.mameworld.info/ubbthreads/showflat.php?Cat=&Number=309968&page=&view=&sb=5&o=&vc=1
                    ; Be aware that several systems will require a BIOS zip with their roms inside. They all come bundled in the MAME set so make sure you add your MAME roms folder to the
                    ; roms path for that system. If you have doubts about their filenames check the mTypeVar module variable content.
                    ; Following systems will also require some specific files to operate properly:
                    ; APF Imagination Machine - apfimag (tape games), apfm1000 (cart games)
                    ; Camputers Lynx - lynx64k, lynx96k, lynx128k
                    ; Coleco ADAM - adam, adam_ddp, adam_fdc, adam_kb, adam_prn, adam_spi
                    ; NEC PC Engine-CD - "Super CD-ROM2 System V3.0 (J).pce" [262,656 bytes] (placed in the roms subfolder in the emuPath)
                    ; NEC TurboGrafx-CD - "Super CD-ROM2 System V3.01 (U).pce" [262,144 bytes] (placed in the roms subfolder in the emuPath)
                    ; Sega CD - segacd, megacd, megacd2j (megacd2j seems to be more compatible over megacdj)
                    ; Sony PlayStation - psa, pse, psj, psu
                    ; Tape Control:
                    ; MAME tape/cassette emulation is terrible because normally it means you need to manually start and stop the tapes yourself so it's highly suggested that you use another emulator for such systems.
                    ; Tape control commands are accessible through the UI, press tab and then select Tape Control and you can start/stop the loaded tape from there.
                    ; The following hotkeys can also be used:
                    ; F2 - Start Tape
                    ; Left Shift + F2 - Stop Tape
                    ; Insert - While held, runs the game with throttling disabled and with the maximum frameskip. Useful to speedup the long tape loading process.
                    ; Be aware that tape games are normally used on PC systems therefore it's likely that full keyboard emulation is enabled which means that you'll need to disable it in order to use any of the above
                    ; hotkeys. To disable it press the Scroll Lock key, press it again to enable it back.
                    ; 7z Support:
                    ; Make sure you have 7z disabled for all MAME Arcade systems. Their roms are supposed to be archived, if you have 7z enabled then your games will fail to load. It's
                    ; fine to enable 7z to non-arcade systems.
                    ; Custom Configuration Files:
                    ; If you want to use custom configuration files (.cfg files) for some games you will need to store them inside your MAME cfg folder using the following structure:
                    ; cfg\mame_system_name\database_rom_name\mame_system_name.cfg
                    ; An example of a game that requires specific settings is ICBM Attack for the Bally Astrocade, in this case special cfg file should be:
                    ; cfg\astrocde\I.C.B.M. Attack (USA) (Unl)\astrocde.cfg
                    ; Ini Files:
                    ; Module will set most settings through command line which will override any settings you might have on your MAME ini files. Everything else will be read from
                    ; those. MAME supports a hierarchical ini file structure and will load settings from several ini files following a specific order:
                    ;- mame.ini
                    ;- <mymame>.ini (i.e. if MAME was renamed mame060.exe, MAME parses mame060.ini here)
                    ;- debug.ini (if the debugger is enabled)
                    ;- <parent>.ini (for clones only, may be called recursively)
                    ;- <gamename>.ini
                    ;- vertical.ini (for games with vertical monitor orientation)
                    ;- horizont.ini (for games with horizontal monitor orientation)
                    ;- vector.ini (for vector games only)
                    ;- <driver>.ini (based on the source filename of the driver)
                    ; The settings in the later ini's override those in the earlier ini's.
                    ; It's highly recommended that you set skipchecks to 'Rom Only" for MAME otherwise RocketLauncher won't be able to launch several games due
                    ; to the way MAME roms are packaged. This will be even more noticeable for those using merged sets.
                    ; Bally Astrocade:
                    ; ICBM requires a soft reset (even on the real hardware) to launch. You can read about it here: http://www.ballyalley.com/ballyalley/articles/Playing_ICBM_Attack_Using_MESS.pdf
                    ; Other games might require this as well, you can enable this in the module's settings so the machine is reset automatically on launch, otherwise you need to press F3 to start the game.
                    ; Also ICBM Attack uses different controls then the rest of the games. Make sure you follow the procedure explained above under "Custom Configuration Files" to create such file.
                    ; GCE Vectrex:
                    ; Requires a vectrex.lay and a png overlay for each game. These all need to be placed in the MAME\artwork\vectrex folder.
                    ; You can download all these pngs and the lay file in my ftp folder. You need to use the HyperList XML to match the pngs.
                    ; Jupiter Ace:
                    ; Set mame to 48k ram
                    ; Magnavox Odyssey 2:
                    ; Euro games should use the videopac bios instead of the odyssey2 one or you'll get some timing issues.
                    ; Use the systemName ini file in the folder with this module for this, example:
                    ; [Moto-Crash (France)]
                    ; Bios=videopac
                    ; RCA Studio 2:
                    ; Most of the games require you to press a button to start the game, like 1 or 2 (refer to the game's manual).
                    ; The game screen will be black until you do.
                    ; Texas Instruments TI 99/4A:
                    ; This system requires full keyboard emulation to work properly
                    ; Split cart dumps are not supported since MESS .145 so you'll have to convert them to RPK format or use an earlier version of MESS (and a different module)
                    ; You can check how to convert split cart dumps to RPK here:
                    ; http://www.ninerpedia.org/index.php/MESS_multicart_system
                    ; For floppy games make sure you have a RPK dump of an extended basic rom on your roms folder. It should be named "extended_basic.rpk"
                    ; This system requires you to use a MAME build with Direct Input enabled in order to auto start the games. Most games will require commands to be typed to start
                    ; and it's normally too complex to be able to do it through the -ab switch so SendCommand is used instead which means a Direct Input enabled MAME version is required.
                    ; Bezels:
                    ; Module settings control whether RocketLauncher or MAME bezels are shown
                    ; In the bezel normal mode only RocketLauncher Bezels will be show and the MAME use_bezels option will be forced disbaled
                    ; In the bezel layout mode, RocketLauncher Bezels will be drawn only when you do not have a layout file on your MAME folders for the current game
                    ; ServoStik:
                    ; The module will automatically control any connected ServoStiks found on the system.
                    ; It does this by reading the xml info from MAME. If that XML info has directional info at 4 or less, 4-way mode will be enabled. All others get 8-way mode.
                    ; Per game controller types:
                    ; MAME allows you to change the controller type for each game by using slot devices. Slot devices are highly customizable and vary greatly from system to
                    ; system so to avoid adding a huge complexity to the module this must be done through the Parameters settings.
                    ; Slot devices are stored in the MAME ini file you are using, so the best way to find the command line you need to use is to start your game set the slot devices
                    ; through the MAME UI (Press tab while in MAME) exit and then open the MAME ini file and search for a section named SLOT DEVICES.
                    ; This is an example for Atari 2600 for a game using wheel controllers on both joy ports:
                    ; # SLOT DEVICES
                    ; joyport1     wheel
                    ; joyport2     wheel
                    ; The suggested method is to set the desired controllers you want to use by default in the Module Global Settings, in this case under the Atari 2600 tab you would
                    ; set Parameters=-joyport1 joy -joyport2 joy
                    ; And then for specific games do the same under Module Specific Settings for that system, if a game requires the wheel controller you'd set
                    ; Parameters=-joyport1 wheel -joyport2 wheel
                    ; Another option is to set the default values in the MAME ini file and make sure you also set writeconfig to 0.
                    ; Swapping slot devices wipes out SYSTEM custom configs on the unplugged controllers, so to avoid any customised controls getting erased everytime you change slot devices,
                    ; ensure you set your controls in the main MAME config file (MAME.ini), not the system one (ex. Atari 2600.ini).
                    ; Linking/NetPlay:
                    ; The module will automatically set correct network ports for linked games.
                    ; Up to 8 players on the same PC are supported. Multiple copies of MAME will be launched.
                    ; Placement of the screens are automatic but can be controlled in RocketLauncherUI MAME module settings. Windowed mode is required when more than one copy of mame is launched and is set automatically.
                    ; Each player will use a different cfg and nvram folder in your MAME folder. Player 1 will always use .\cfg and .\nvram.
                    ; Players 2 through 8 will use .\cfg2, .\cfg3, etc and .\nvram2, .\nvram3, etc
                    ; These folders and cfg/nvram files will be automatically created for you on launch so you do not need to create them manually.
                    ; Global inputs is automatically turned on for you but it is your job to setup individual controls for each instance. MAME only supports raw-input in this mode however.
                    ; Over a LAN/WAN connection only 2 players are supported due to the way the ports are designated, it's impossible to automate port allocation because there is no 1 server where all hosts connect to.
                    ; Default starting port for the Master is 15111 and consecutively goes up from there upto 15119 for 8 players. You can change the default starting port in the module settings if it conflicts with used ports on your network.
                    ; There are other network related settings in the module settings to assist with starting IPs and connectivity, so check them out as well.
                    ; NVRAM Automation for linked games:
                    ; When launching linked games on the same pc NVRAM settings are automatically set for you so each player will be unique.
                    ; For instance, in Virtua Racing, Player 1 is red, player 2 is blue, player 3 is yellow, etc.
                    ; To do this, some other options are also set automatically for you as well, like region, difficulty, countr, course, etc
                    ; I set these to defaults, but prefer USA region. If you do not like these, you will have to disable NVRAM automation in the module settings in RocketLauncherUI.
                    ; Additional Link info that may be of some importance:
                    ; The original Model-1 has a max Bandwidth of 6 MBit/s (TOTX173/TORX173).
                    ; One Board sends about 20 KByte/s.
                    ; So bandwidth CLIENTSIDE is like...
                    ; 2 Boards - 20 KByte/s inbound and 20 KByte/s outbound.
                    ; 3 Boards - 40 KByte/s inbound and 20 KByte/s outbound.
                    ; 4 Boards - 60 KByte/s inbound and 20 KByte/s outbound.
                    ; etc.
                    ; Some good info on Linking: http://www.mameworld.info/ubbthreads/showflat.php?Cat=&Number=297577&page=0
                    ; also http://forum.arcadecontrols.com/index.php/topic,130136.msg1331485.html
                    StartModule()
                    BezelGUI()
                    ; This object controls how the module reacts to different systems. MAME can play a lot of systems, but needs to know what system you want to run, so this module has to adapt.
                    mTypeVar := "
                        ( LTrim
                        Aamber Pegasus|pegasus
                        Acorn Electron|electron
                        Amstrad CPC|cpc664
                        Amstrad GX4000|gx4000
                        APF Imagination Machine|apfimag
                        Apple II|apple2ep
                        Apple IIGS|apple2gs
                        Applied Technology MicroBee|mbeeic
                        Atari 8-Bit|a800
                        Atari 2600|a2600
                        Atari 5200|a5200
                        Atari 7800|a7800
                        Atari Jaguar|jaguar
                        Atari Lynx|lynx
                        Bally Astrocade|astrocde
                        Bandai Super Vision 8000|sv8000
                        Bandai WonderSwan|wswan
                        Bandai WonderSwan Color|wscolor
                        Bit Corporation Gamate|gamate
                        Camputers Lynx|lynx128k
                        Casio PV-1000|pv1000
                        Casio PV-2000|pv2000
                        Coleco ADAM|adam
                        ColecoVision|coleco
                        Commodore 64|c64
                        Commodore MAX Machine|vic10
                        Creatronic Mega Duck|megaduck
                        EACA EG2000 Colour Genie|cgenie
                        Emerson Arcadia 2001|arcadia
                        Entex Adventure Vision|advision
                        Epoch Game Pocket Computer|gamepock
                        Epoch Super Cassette Vision|scv
                        Exidy Sorcerer|sorcerer
                        Fairchild Channel F|channelf
                        Fujitsu FM-7|fmnew7
                        Funtech Super Acan|supracan
                        GamePark 32|gp32
                        GCE Vectrex|vectrex
                        Hartung Game Master|gmaster
                        Interton VC 4000|vc4000
                        JungleTac Sport Vii|vii
                        Jupiter Ace|jupace
                        Magnavox Odyssey 2|odyssey2
                        Matra & Hachette Alice|alice32
                        Mattel Aquarius|aquarius
                        Mattel Intellivision|intv
                        MGT Sam Coupe|samcoupe
                        Milton Bradley MicroVision|microvsn
                        NEC PC-8801|pc8801
                        NEC PC Engine|pce
                        NEC PC Engine-CD|pce
                        NEC SuperGrafx|sgx
                        NEC TurboGrafx-16|tg16
                        NEC TurboGrafx-CD|tg16
                        Nintendo 64|n64
                        Nintendo 64DD|n64dd
                        Nintendo Entertainment System|nes
                        Nintendo Famicom|famicom
                        Nintendo Famicom Disk System|fds
                        Nintendo Game Boy|gameboy
                        Nintendo Game Boy Advance|gba
                        Nintendo Game Boy Color|gbcolor
                        Nintendo Pokemon Mini|pokemini
                        Nintendo Satellaview|snes
                        Nintendo Super Famicom|snes
                        Nintendo Super Game Boy|supergb
                        Nintendo Virtual Boy|vboy
                        Othello Multivision|omv1000
                        Philips CD-i|cdimono1
                        Philips Videopac Plus G7400|g7400
                        Philips VG 5000|vg5k
                        RCA Studio II|studio2
                        Sega 32X|32x
                        Sega CD|segacd
                        Sega Game Gear|gamegear
                        Sega Genesis|genesis
                        Sega Master System|sms
                        Sega Mega Drive|megadriv
                        Sega Pico|pico
                        Sega Saturn|saturn
                        Sega SC-3000|sc3000
                        Sega SG-1000|sg1000
                        Sega VMU|svmu
                        Sharp X1|x1turbo40
                        Sinclair ZX81|zx81
                        SNK Neo Geo AES|aes
                        SNK Neo Geo CD|neocdz
                        SNK Neo Geo Pocket|ngp
                        SNK Neo Geo Pocket Color|ngpc
                        Sony PlayStation|psx
                        Sony PocketStation|pockstat
                        Sord M5|m5
                        Soundic Victory MPT-02|mpt02
                        Super Nintendo Entertainment System|snes
                        Tandy TRS-80 Color Computer|coco3
                        Texas Instruments TI 99-4A|ti99_4a
                        Tiger Game.com|gamecom
                        Tomy Tutor|tutor
                        VTech CreatiVision|crvision
                        Watara Supervision|svision
                    mType := Object()
                    Loop, Parse, mTypeVar, `n, `r
                        obj := {}
                        Loop, Parse, A_LoopField, |
                            If (A_Index = 1)
                                obj.System := A_LoopField
                            Else    ; 2
                                obj.mameID := A_LoopField
                        mType.Insert(obj["System"], obj)
                    Log("Module - Finished building the " . MEmu . " object",4)
                    ; For easier use throughout the module
                    mameSystem := mType[systemName].System
                    mameID := mType[systemName].mameID
                    If !mameSystem {
                        Log("Module - """ . systemName . """ is not a known console or computer system. Defaulting to MAME's Arcade mode for the remainder of this " . MEmu . " module.",2)
                        mameSystem := systemName
                        mameID := "MAME"
                    Fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1)        ; Set fullscreen mode
                    legacyMode := IniReadCheck(settingsFile, "Settings|" . systemName . "|" . romName, "LegacyMode","false",,1)
                    mameBiosPath := IniReadCheck(settingsFile, "Settings", "MAME_BIOS_Path", emuPath . "\roms",,1)
                    mameBiosPath := GetFullName(mameBiosPath)
                    Videomode := IniReadCheck(settingsFile, "Settings", "Videomode","d3d",,1)    ; Choices are gdi,ddraw,d3d. If left blank, MAME uses d3d by default
                    pauseMethod := IniReadCheck(settingsFile, "Settings", "PauseMethod",1,,1)    ; set the pause method that works better on your machine (preferred methods 1 and 2) 1 = Win7 and Win8 OK - Problems with Win XP, 2 = preferred method for WinXP - Problems in Win7, 3 and 4 = same as 1 and 2, 5 = only use If you have a direct input version of mame, 6 = suspend mame process method, it could crash mame in some computers
                    bilinearFilter := IniReadCheck(settingsFile, "Settings|" . mameSystem, "BilinearFilter","false",,1)
                    hlsl := IniReadCheck(settingsFile, "Settings|" . mameSystem . "|" . romName, "HLSL","false",,1)
                    glsl := IniReadCheck(settingsFile, "Settings|" . mameSystem . "|" . romName, "GLSL","false",,1)
                    bezelMode := IniReadCheck(settingsFile, "Settings|" . systemName . "|" . romName, "BezelMode","layout",,1)    ; "layout" or "normal"
                    verticalRotationMode := IniReadCheck(settingsFile, "Settings|" . mameSystem . "|" . romName, "VerticalRotationMode","none",,1)
                    cheatMode := IniReadCheck(settingsFile, "Settings", "CheatMode","false",,1)
                    cheatModeKey := IniReadCheck(settingsFile, "Settings", "CheatModeKey",A_Space,,1)    ; user defined key to be held down before launching a mame rom.
                    UseSoftwareList := IniReadCheck(settingsFile, mameSystem . "|" . romName, "UseSoftwareList","false",,1)
                    sysStaticParams := IniReadCheck(settingsFile, mameSystem, "StaticParameters", A_Space,,1)
                    sysParams := IniReadCheck(settingsFile, mameSystem, "Parameters", A_Space,,1)
                    romParams := IniReadCheck(settingsFile, romName, "Parameters", sysParams,,1)
                    mameRomName := IniReadCheck(settingsFile, romName, "MameRomName", A_Space,,1)
                    autosave := IniReadCheck(settingsFile, systemName . "|" . romName, "Autosave", "false",,1)
                    volume := IniReadCheck(settingsFile, "Settings|" . systemName . "|" . romName, "Volume",,,1)
                    Artwork_Crop := IniReadCheck(settingsFile, mameSystem . "|" . romName, "Artwork_Crop", "true",,1)
                    Use_Bezels := IniReadCheck(settingsFile, mameSystem . "|" . romName, "Use_Bezels", "false",,1)
                    Use_Overlays := IniReadCheck(settingsFile, mameSystem . "|" . romName, "Use_Overlays", "true",,1)
                    Use_Backdrops := IniReadCheck(settingsFile, mameSystem . "|" . romName, "Use_Backdrops", "true",,1)
                    Use_Cpanels := IniReadCheck(settingsFile, mameSystem . "|" . romName, "Use_Cpanels", "false",,1)
                    Use_Marquees := IniReadCheck(settingsFile, mameSystem . "|" . romName, "Use_Marquees", "false",,1)
                    inipath := IniReadCheck(settingsFile, mameSystem, "IniPath", "",,1)
                    hashpath := IniReadCheck(settingsFile, mameSystem, "HashPath", "",,1)
                    ; Loop, 8
                        ; car%A_Index%Color := IniReadCheck(settingsFile, romName, "Car_" . A_Index . "_Color","",,1)
                    enableLinkPlay := IniReadCheck(settingsFile, "Link/Network|" . romName, "Enable_Link_Play", "false",,1)
                    networkSession := ""
                    If (enableLinkPlay != "false") {
                        Log("Module - Link/Network Multi-Player is an available option for " . romName,4)
                        getWANIP := IniReadCheck(settingsFile, "Link/Network", "Get_WAN_IP","false",,1)
                        myIP := If getWANIP = "true" ? GetPublicIP() : "127.0.0.1"    ; use local ip by default if user does not want to get the WAN IP as MAME needs this for linked games
                        networkPlayers := enableLinkPlay    ; Max amount of networkable players
                        localLink := 1    ; Tell Multiplayer menu to enable menu option for local linking
                        enableNVRAMAutomation := IniReadCheck(settingsFile, "Link/Network|" . romName, "Enable_NVRAM_Automation","true",,1)
                        maxPlayersPerMonitor := IniReadCheck(settingsFile, "Link/Network|" . romName, "Max_Players_Per_monitor","1|1|1|1|1|1|1|1",,1)
                        splitScreen2PlayersMode := IniReadCheck(settingsFile, "Link/Network|" . romName, "SplitScreen_2_Players","Horizontal",,1) ;horizontal or vertical
                        splitScreen3PlayersMode := IniReadCheck(settingsFile, "Link/Network|" . romName, "SplitScreen_3_Players","P1top",,1) ; For Player1 screen to be on left: P1left. For Player1 screen to be on top: P1top. For Player1 screen to be on bottom: P1bottom. For Player1 screen to be on right: P1right.
                        localPort := IniReadCheck(settingsFile, "Link/Network", "Local_Port","15111",,1)
                        defaultServerIP := IniReadCheck(settingsFile, "Link/Network", "Default_Server_IP", myIP,,1)
                        defaultServerPort := IniReadCheck(settingsFile, "Link/Network", "Default_Server_Port","15111",,1)
                        lastIP := IniReadCheck(settingsFile, "Link/Network", "Last_IP", defaultServerIP,,1)    ; also known as the Remote IP in mame. Does not need to be on the ISD
                        lastPort := IniReadCheck(settingsFile, "Link/Network", "Last_Port", defaultServerPort,,1)    ; also known as the Remote Port in mame. Does not need to be on the ISD
                        MultiplayerMenu(lastIP, lastPort, networkType, networkPlayers,,,,,,localLink,"ipAndPort")
                        ;MultiPlayer Menu Result
                        ; If !(networkType)
                            ; MsgBox, % "Single Player Game"
                        ; Else If (networkType="localLink")
                            ; MsgBox, % "Local Link selected with the number of players equal to: " . networkPlayers
                        ; Else If (networkType="server")
                            ; MsgBox, % "WAN IP Address=" . networkIP . " | LAN IP Address=" . localIP[1,2] . " | Port=" . networkPort . " | networkPlayers=" . networkPlayers . " | networkRequiresSetup=" . networkRequiresSetup
                        ; Else If (networkType="client")
                            ; MsgBox, % "NetworkIP=" . networkIP . " | Port Number=" . networkPort . " | networkRequiresSetup=" . networkRequiresSetup
                        If networkSession {
                            Log("Module - Using a Network for " . romName,4)
                            multiPlayerObj := Object()    ; initialize object to store the multiplayer options
                            If (networkType="localLink") {
                                Log("Module - Setting remote host to 127.0.0.1 to support local link mode as it is running on this PC.")
                                linkEnabledGame := 1
                                If networkPlayers > 1
                                {    Log("Module - Local link mode was selected and " . networkPlayers . " sessions will be launched.")
                                    fullscreen := "false"    ; must turn off fullscreen if running multiple MAMEs on the same machine
                                    Loop % networkPlayers {
                                        multiPlayerObj[A_Index,"Player"] := A_Index
                                        multiPlayerObj[A_Index,"CfgDir"] := " -cfg_directory cfg" . (If A_Index = 1 ? "" : A_Index)
                                        multiPlayerObj[A_Index,"NvramDir"] := " -nvram_directory nvram" . (If A_Index = 1 ? "" : A_Index)
                                        If (A_Index = 1) {    ; Player 1
                                            initialLocalPort := localPort    ; must be stored for last player
                                            multiPlayerObj[A_Index,"LocalHost"] := " -comm_localhost 0.0.0.0"
                                            multiPlayerObj[A_Index,"LocalPort"] := " -comm_localport " . localPort
                                            localPort++
                                            multiPlayerObj[A_Index,"RemotePort"] := " -comm_remoteport " . localPort
                                        } Else {    ; Players 2+
                                            localPort++
                                            multiPlayerObj[A_Index,"RemoteHost"] := " -comm_remotehost 127.0.0.1"
                                            multiPlayerObj[A_Index,"RemotePort"] := " -comm_remoteport " . (If A_Index = networkPlayers ? initialLocalPort : localPort)    ; must set remote port to first port on last player
                                        ; msgbox % "Player: " . multiPlayerObj[A_Index]["Player"] . "`nLocalHost: " . multiPlayerObj[A_Index]["LocalHost"] . "`nLocalPort: " . multiPlayerObj[A_Index]["LocalPort"] . "`nRemoteHost: " . multiPlayerObj[A_Index]["RemoteHost"] . "`nRemotePort: " . multiPlayerObj[A_Index]["RemotePort"] . "`nCfgDir: " . multiPlayerObj[A_Index]["CfgDir"] . "`nNvramDir: " . multiPlayerObj[A_Index]["NvramDir"]
                                } Else
                                    Log("Module - Local link mode was selected but user only chose 1 player. Launch will be a normal session.")
                            } Else If (networkType = "client") {
                                Log("Module - Remote host is running on another PC, module will use remote link mode.")
                                IniWrite, %networkIP%, %settingsFile%, Link/Network, Last_IP    ; Save last used IP and Port for quicker launching next time
                                IniWrite, %networkPort%, %settingsFile%, Link/Network, Last_Port
                                linkType := "Slave"
                                networkPlayers := 1
                                multiPlayerObj[1,"Player"] := 1
                                multiPlayerObj[1,"CfgDir"] := " -cfg_directory cfg"
                                multiPlayerObj[1,"NvramDir"] := " -nvram_directory nvram"
                                multiPlayerObj[1,"LocalHost"] := " -comm_localhost 0.0.0.0"        ; don't really need to set this but just in case
                                multiPlayerObj[1,"LocalPort"] := " -comm_localport " . localPort
                                multiPlayerObj[1,"RemoteHost"] := " -comm_remotehost " . networkIP
                                multiPlayerObj[1,"RemotePort"] := " -comm_remoteport " . networkPort
                            } Else {    ; server
                                Log("Module - This PC is acting as the host, telling mame to listen for incoming connections on port: " . localPort)
                                linkType := "Master"
                                networkPlayers := 1
                                multiPlayerObj[1,"LocalPort"] := " -comm_localport " . networkPort
                            Log("Module - Starting a network session using the IP """ . networkIP . """ and PORT """ . networkPort . """",4)
                        } Else {
                            Log("Module - User chose Single Player mode for this session",4)
                    FadeInStart()
                    ;Read settings from system name ini file
                    sysSettingsFile := modulePath . "\" . mameSystem . ".ini"
                    If FileExist(sysSettingsFile) {
                        romParams := IniReadCheck(sysSettingsFile, romName, "Parameters", romParams,,1)
                        hlsl := IniReadCheck(sysSettingsFile, romName, "HLSL",hlsl,,1)
                        glsl := IniReadCheck(sysSettingsFile, romName, "GLSL",glsl,,1)
                        Artwork_Crop := IniReadCheck(sysSettingsFile, romName, "Artwork_Crop", Artwork_Crop,,1)
                        Use_Bezels := IniReadCheck(sysSettingsFile, romName, "Use_Bezels", Use_Bezels,,1)
                        Use_Overlays := IniReadCheck(sysSettingsFile, romName, "Use_Overlays", Use_Overlays,,1)
                        Use_Backdrops := IniReadCheck(sysSettingsFile, romName, "Use_Backdrops", Use_Backdrops,,1)
                        Use_Cpanels := IniReadCheck(sysSettingsFile, romName, "Use_Cpanels", Use_Cpanels,,1)
                        Use_Marquees := IniReadCheck(sysSettingsFile, romName, "Use_Marquees", Use_Marquees,,1)
                        UseSoftwareList := IniReadCheck(sysSettingsFile, romName, "UseSoftwareList", UseSoftwareList,,1)
                    If inipath
                        inipath := AbsoluteFromRelative(EmuPath, inipath)
                    If hashpath
                        hashpath := AbsoluteFromRelative(EmuPath, hashpath)
                    artworkCrop := If (Artwork_Crop = "true") ? " -artwork_crop" : " -noartwork_crop"
                    useBezels := If (Use_Bezels = "true") ? " -use_bezels" : " -nouse_bezels"
                    useOverlays := If (Use_Overlays = "true") ? " -use_overlays" : " -nouse_overlays"
                    useBackdrops := If (Use_Backdrops = "true") ? " -use_backdrops" : " -nouse_backdrops"
                    useCpanels := If (Use_Cpanels = "true") ? " -use_cpanels" : " -nouse_cpanels"
                    useMarquees := If (Use_Marquees = "true") ? " -use_marquees" : " -nouse_marquees"
                    autosave := If autosave = "true"  ? " -autosave" : ""
                    volume := If volume != ""  ? " -volume " . volume : ""
                    inipath := If inipath != "" ? " -inipath """ . inipath . """" : ""
                    hashpath := If hashpath != "" ? " -hashpath """ . hashpath . """" : ""
                    If (verticalRotationMode = "none")
                        verticalRotationMode := ""
                    ; Process mame's ListXML for certain features
                    If (bezelEnabled = "true" || servoStikEnabled = "auto" || verticalRotationMode) {
                        ListXMLObject := Object()
                        ListXMLObject := ListXMLInfo(If mameRomName ? mameRomName : romName)
                        Angle := ListXMLObject["Angle"].Value
                        If (bezelEnabled = "true") {
                            If (networkPlayers > 1) {
                                useBezels := " -nouse_bezels"   ; force disabling MAME built-in bezels
                                BezelStart(networkPlayers)
                            } Else {
                                If (bezelMode = "layout"){
                                    BezelStart("layout",ListXMLObject["Parent"].Value,Angle,romName)
                                } Else { ;bezel mode = normal
                                    BezelStart(,,Angle)
                        If (servoStikEnabled = "auto") {
                            ServoStik(If ListXMLObject["Ways"].Value <= 4 ? 4 : 8)    ; If "ways" in the xml is set to 4 or less, the servo will go into 4-way mode, else 8-way mode will be enabled
                        If (verticalRotationMode && Angle) {
                            Log("Setting rotation mode to " . verticalRotationMode . " - Game's angle is " . Angle)
                            If (verticalRotationMode = "original")
                                verticalRotationMode := " -norotate"
                            Else If (verticalRotationMode = "right")
                                verticalRotationMode := " -ror"
                            Else If (verticalRotationMode = "left")
                                verticalRotationMode := " -rol"
                            Else
                        Else
                    winstate := If (Fullscreen = "true") ? "Hide UseErrorLevel" : "UseErrorLevel"
                    fullscreenParam := If (Fullscreen = "true") ? " -nowindow" : " -window"
                    hideEmuObj := Object(dialogOpen . " ahk_class ConsoleWindowClass",0,"ahk_class MAMEDebugWindow",0,"ahk_class MAMEOutput",0,"ahk_class MAME",1)    ;Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later
                    7z(romPath, romName, romExtension, sevenZExtractPath)
                    ; Get MAME version from executable, this is needed since some CLI switches are not available in older MAME versions
                    exeAtrib := FileGetVersionInfo_AW(EmuPath . "\" . executable, "FileVersion|ProductVersion", "|")
                    Loop, Parse, exeAtrib, |%A_Tab%, %A_Space%
                        A_Index & 1 ? ( _ := A_LoopField ) : ( %_% := A_LoopField )
                    If ProductVersion
                        StringRight, MAMEVersion, ProductVersion, StrLen(ProductVersion) - 2
                    Log("Module - Detected MAME Product Version from '" . EmuPath . "\" . executable . "' is " . MAMEVersion)
                    If (videomode = "opengl") {
                        hlsl := " -nohlsl_enable"
                        If (MAMEVersion > 159)
                            glsl := If glsl = "true" ? " -gl_glsl" : (If glsl = "ini" ? "" : " -nogl_glsl")
                        Else
                            glsl := ""
                    } Else {
                        hlsl := If hlsl = "true" ? " -hlsl_enable" : (If hlsl = "ini" ? "" : " -nohlsl_enable")
                            glsl := If videomode = "ini" ? "" : " -nogl_glsl"
                        Else
                            glsl := ""
                        If (videomode = "ini")
                            videomode := ""
                    videomode := If (Videomode != "" ) ? " -video " . videomode : ""
                    param1 := " -cart """ . romPath . "\" . romName . romExtension . """"    ; default param1 used for launching most systems.
                    If romExtension = .txt    ; This can be applied to all systems
                        param1 := ""
                    If (mameID = "apfimag")    ; APF Imagination Machine
                        If (romExtension != ".tap")
                            mameID := "apfm1000"    ; cart games for APF Imagination Machine require a different bios to be loaded
                    If (UseSoftwareList != "true")
                    {    ; Now that we know the system we are loading, determine if we use an ini assocated with that system for custom game configs a user might need. Then load the configs associated to that game.
                        If mameID in ti99_4a,aes,apple2gs,electron,mbeeic,odyssey2,astrocde,samcoupe,vic10,cpc664    ; these systems will use an ini to store game specific settings
                            mameSysINI := CheckFileMAME(modulePath . "\" . mameSystem . ".ini")    ; create the ini if it does not exist
                            If (mameID = "ti99_4a")    ; Texas Instruments TI 99-4A
                                ExpansionCartLocation := IniReadCheck(sysSettingsFile, "Settings", "ExpansionCartLocation", romPath . "\System",,1)
                                ExpansionCartLocation := GetFullName(ExpansionCartLocation)
                                CommandWaitOffset := IniReadCheck(sysSettingsFile, "Settings", "CommandWaitOffset", 0,,1)
                                ExpansionCart := IniReadCheck(sysSettingsFile, romName, "Expansion_Cart","extended_basic.rpk",,1)    ; user can specify a rom specific cart instead of the default basic one
                                Command := IniReadCheck(sysSettingsFile, romName, "Command", "",,1)
                                ; Now set the parameters to send to MAME
                                If (romExtension = ".dsk")    ; Expansion Disk
                                    ; If using the mainCart , send expansionLocation to MAME. This will require DirectInput to be enabled on the MAME build! Else we are loading a Disk game
                                    param1 := " -nat -gromport single -cart1"
                                    param2 := " """ . ExpansionCartLocation . "\" . ExpansionCart . """"
                                    param3 := " -peb:slot2 32kmem -peb:slot3 speech -peb:slot6 tirs232 -peb:slot8 hfdc"
                                    param4 := " -flop1"
                                    param5 := " """ . romPath . "\" . romName . romExtension . """"
                                    If InStr(romName, "(Disk")
                                        Sleep, 50
                                        If (romTable.MaxIndex() = 2)
                                            param4 := " -flop1 " . " """ . romTable[1,1] . """"
                                            param5 := " -flop2 " . " """ . romTable[2,1] . """"
                                } Else If (romExtension = ".rpk")    ; Cart Game (RPK Format)
                                    param1 := " -nat -gromport single -cart1", param2:=" """ . romPath . "\" . romName . romExtension . """", param3:=" -peb:slot3 speech" ;-cart will also work here
                                param6 := " -ui_active" ;Enable partial keyboard mode at startup
                            } Else If (mameID = "aes")    ; SNK Neo Geo AES
                            {    biosRegion := IniReadCheck(mameSysINI, romName, "BIOS_Region","asia",,1)
                                param1 := " -bios " . biosRegion    ; can also be japan, but the asian one has english menus for most games
                                param2 := " -cart " . romName
                            }Else If (mameID = "apple2gs")    ; Apple IIGS
                            {    externalOS := IniReadCheck(mameSysINI, romName, "External_OS","false",,1)
                                2gsSystemFile := "System6.2mg"    ;For games without OS included, always force this name and error out if not found
                                multipartTable := CreateRomTable(multipartTable)
                                If (externalOS = "true")
                                {    CheckFile(romPath . "\" . 2gsSystemFile)
                                    param1 := " -flop3", param2:=" """ . romPath . "\" . 2gsSystemFile . """", param3:=" -flop4", param4:=" """ . romPath . "\" . romName . romExtension . """"
                                } Else {
                                    param1 := " -flop3", param2:=" """ . romPath . "\" . romName . romExtension . """"
                                    If (multipartTable.MaxIndex() > 1)
                                        param3 := " -flop4", param4 := " """ . multipartTable[2,1] . """"
                                param5 := " -ui_active" ;Enable partial keyboard mode at startup
                            }Else If (mameID = "electron") ; Acorn Electron
                            {    AutoBootDelay := IniReadCheck(mameSysINI, "Settings", "AutoBootDelay","2",,1)    ; Read delay from config.
                                AutoBootDelay := " -autoboot_delay " . AutoBootDelay
                                If (romExtension = ".bin")
                                    mediaDeviceType := "cart"
                                Else    ; any other format
                                    mediaDeviceType := "cass"
                                param1 := " -" . mediaDeviceType . " """ . romPath . "\" . romName . romExtension . """ -autoboot_command ""chain""""""""""""\n""" . AutoBootDelay . ""
                            }Else If (mameID = "sc3000") ; Sega SC-3000
                                If romExtension In .bin,.sg,.sc
                            }Else If (mameID = "c64") ; Commodore 64
                                If romExtension In .d64,.g64,.g41,.d77,.d88,.1dd,.dfi,.imd,.ipf,.mfi,.mfm,.td0,.cqm,.cqi,.dsk
                                    mediaDeviceType := "flop1"
                                Else If romExtension In .wav,.tap
                                    mediaDeviceType := "cass1"
                                Else If romExtension In .80,.a0,.e0,.crt
                                    mediaDeviceType := "cart1"
                                Else If romExtension In .p00,.prg,.t64
                                    mediaDeviceType := "quik1"
                            }Else If mameID = mbeeic ; Applied Technology MicroBee
                            {    microbeeModel := IniReadCheck(mameSysINI, romName, "MicroBee_Model","mbeeic",,1)
                                If microbeeModel not in mbee,mbeeic,mbeepc,mbeepc85,mbee56
                                    ScriptError("This is not a known MicroBee model value: " . microbeeModel)
                                Else If (microbeeModel != "mbeeic")
                                    mameID := microbeeModel
                                If romExtension in .mwb,.com,.bee
                                Else If romExtension in .wav,.tap
                                Else If romExtension in .rom
                                Else If romExtension in .dsk
                                Else    ; .bin format
                                    mediaDeviceType := "quik2"
                                param1 := " -" . mediaDeviceType . " """ . romPath . "\" . romName . romExtension . """"
                            }Else If (mameID = "odyssey2")    ; Magnavox Odyssey 2
                            {    param2 := " -ui_active" ;Enable partial keyboard mode at startup
                                If romName not contains (USA
                                    mameID := "videopac"
                            }Else If (mameID = "astrocde") ; Bally Astrocade
                                BlueRAMBasicRom := IniReadCheck(mameSysINI, "Settings", "BlueRAMBasicRom","Blue RAM Basic v1.1 (USA).bin",,1)    ; Blue RAM Basic rom
                                RequiresReset := IniReadCheck(mameSysINI, romname, "RequiresReset","false",,1)    ; Check if game requires a reset
                                BlueRAMBasicRomPath := romPath . "\" . BlueRAMBasicRom
                                If (romExtension = ".script") {
                                    ;Will require blue ram basic
                                    If !FileExist(BlueRAMBasicRomPath) {
                                        ;Blue RAM Basic games might be in their own sub-folders since they have several files, so let's try to find the Blue RAM cart in the parent folder as well
                                        SplitPath,romPath,,romBasePath
                                        BlueRAMBasicRomPath := CheckFile(romBasePath . "\" . BlueRAMBasicRom, "Couldn't find " . BlueRAMBasicRom . " on any of these paths:" . romBasePath . "|" . romPath)
                                    scriptFile := romPath . "\" . romName . romExtension
                                    param1 := " -cart """ . BlueRAMBasicRomPath . """"
                                    ;Replace rompath variable in script
                                    FileRead, scriptData, %scriptFile%
                                    StringReplace, scriptData, scriptData, {romPath}, %romPath%, all
                                    ;Create cmd file to send to MESS
                                    FileDelete, %romPath% . "\" . %romName% . ".cmd"
                                    FileAppend, %scriptData%, %romPath%\%romName%.cmd
                                    param2 := " -exp blue_ram_16k -debug -debugscript """ . romPath . "\" . romName . ".cmd"""
                                    closeDebugWindow := "true"
                            }Else If (mameID = "samcoupe")    ; MGT Sam Coupe
                                If romExtension in .mgt,.dsk,.d77,.d88,.1dd,.dfi,.imd,.ipf,.mfi,.mfm,.td0,.cqm,.cqi
                                    param1 := " -" . mediaDeviceType . " """ . romPath . "\" . romName . romExtension . """ -autoboot_command ""\nBOOT\n""" . AutoBootDelay . ""
                            }Else If (mameID = "vic10")    ; Commodore MAX Machine
                                If romExtension in .e0,.80
                                    param1 := " -cass """ . romPath . "\" . romName . romExtension . """"
                                Else If romExtension in .t64,.prg,.p00
                                    mediaDeviceType := "quik"
                                    param1 := " -" . mediaDeviceType . " """ . romPath . "\" . romName . romExtension . """ -autoboot_command ""RUN""" . AutoBootDelay . ""
                            }Else If (mameID = "cpc664")    ; Amstrad CPC
                            {    LaunchProgram := IniReadCheck(mameSysINI, romName, "LaunchProgram","disk",,1)    ; Read command from config.
                                LaunchProgram := " -autoboot_command " . """RUN \""" . LaunchProgram . "\n"""
                                If romExtension in .d77,.d88,.1dd,.dfi,.imd,.ipf,.mfi,.mfm,.td0,.cqm,.cqi,.dsk
                                    param1 := " -" . mediaDeviceType . " """ . romPath . "\" . romName . romExtension . """" . LaunchProgram . AutoBootDelay
                            ;Use a different bios if needed (This must be done after the above if conditions since the mameID will change)
                            iniBios := IniReadCheck(mameSysINI, romName, "Bios",mameID,,1) ; for all games, we use the default bios. Some games might require different bios like Odyssey2's Jopac games use the videopac bios instead, which should be defined in the ini
                            If (iniBios != "")
                                mameID := iniBios    ; need to change the bios name for some games
                        ; These systems don't use an ini, but do require parameters to be changed from the default method of launching MAME
                        If (mameID = "neocdz" || mameID = "cdimono1" || mameID = "segacd" || mameID = "saturn" || mameID = "psx" || (mameID = "tg16" && mameSystem = "NEC TurboGrafx-CD") || (mameID = "pce" && mameSystem = "NEC PC Engine-CD"))    ; SNK Neo Geo CD, Philips CD-i, Sega CD, Sega Saturn, Sony PlayStation, NEC PC Engine-CD or NEC TurboGrafx-CD
                        {    If romExtension not in .chd,.cue
                                ScriptError("MAME only supports " . mameSystem . " games in chd and cue format. It does not support:`n" . romExtension)
                            If (mameSystem = "NEC TurboGrafx-CD") {        ; NEC TurboGrafx-CD needs an additional bios mounted as a cart to run
                                ; tgcdBios := CheckFile(emuPath . "\roms\CD-ROM System V2.01 (U).pce")    ; older bios that doesn't seem to work with many games
                                tgcdBios := CheckFile(emuPath . "\roms\Super CD-ROM2 System V3.01 (U).pce")
                                param2 := " -cart " . """" . tgcdBios . """"
                            } Else If (mameSystem = "NEC PC Engine-CD") {        ; NEC PC Engine-CD needs an additional bios mounted as a cart to run
                                pcecdBios := CheckFile(emuPath . "\roms\Super CD-ROM2 System V3.0 (J).pce")
                                param2 := " -cart " . """" . pcecdBios . """"
                            } Else If (mameID = "psx") {        ; Sony PlayStation
                                mameID := "psu"        ; changing mameID sent to MAME to use the USA bios
                                ; SelectMemCard()    ; future function to swap around memcards
                                ; Usage: mc1 "J:\MAME\software\psu\card1.mc"
                            } If (mameSystem = "Sega CD") {    ;
                                If InStr(romName,"(Jap")    ; Mega CD Japanese v2
                                    mameID := "megacd2j"
                                Else If InStr(romName,"(Euro")    ; Mega CD European (PAL)
                                    mameID := "megacd"
                            param1 := " -cdrm """ . romPath . "\" . romName . romExtension . """"
                        }Else If (mameID = "gamecom")    ; Tiger Game.com
                        {    If (romExtension != ".txt")
                                param1 := " -cart1 """ . romPath . "\" . romName . romExtension . """"
                        }Else If (mameID = "genesis")    ; Sega Genesis
                        {    If (InStr(romName, "(Europe") || InStr(romName, "(PAL"))    ; if rom is from europe, tell MAME to boot a Mega Drive instead
                                mameID := "megadriv"
                        }Else If (mameID = "megadriv")    ; Sega Mega Drive
                        {    If (InStr(romName, "(USA") || InStr(romName, "(NTSC"))    ; if rom is from America, tell MAME to boot a Genesis instead
                                mameID := "genesis"
                        }Else If (mameID = "vii") ; JungleTac Sport Vii
                        {   If (romName = "Built-In Games (China)")    ;  Has some built-in games, gotta launch just BIOS for it.
                                param1 := ""
                        }Else If (mameID = "alice32") ; Matra & Hachette Alice
                                param1 := " -cass1 """ . romPath . "\" . romName . romExtension . """"
                        }Else If (mameID = "cgenie") ; EACA EG2000 Colour Genie
                        }Else If (mameID = "pockstat")    ; Sony PocketStation
                        {    If (romExtension != ".gme")
                        }Else If (mameID = "coco3")    ; Tandy TRS-80 Color Computer
                        }Else If (mameID = "zx81")        ; Sinclair ZX81
                        }Else If (mameID = "lynx128k")    ; Camputers Lynx
                        }Else If (mameID = "vg5k")        ; Philips VG 5000
                        }Else If (mameID = "sorcerer")    ; Exidy Sorcerer
                        {    If (romExtension = ".snp")    ; Snapshot file
                                param1 := " -dump """ . romPath . "\" . romName . romExtension . """"
                            Else If (romExtension = ".bin")
                                param1 := " -quik """ . romPath . "\" . romName . romExtension . """"
                        }Else If (messID = "jupace")     ; jupiter ace
                        {    If (romExtension = ".ace")
                        }Else If (mameID = "a800" || mameID = "fds")    ; Atari 8-Bit, Nintendo Famicom Disk System
                                param1 := " -flop1 """ . romPath . "\" . romName . romExtension . """"
                        }Else If (mameID = "vectrex")    ; GCE Vectrex
                        {    If (romName = "Mine Storm (World)")        ; MAME dumps an error if you try to launch Mine Storm using a rom instead of just booting vectrex w/o a game in it (Mine Storm is built into vectrex)
                                param1 := ""
                        }Else If (mameID = "apfm1000")    ; APF Imagination Machine/APF M1000
                        {    If (romName = "Rocket Patrol (USA)")    ; Rocket Patrol is built into the APF M1000 ROM.
                                param1 := ""
                        }Else If (mameID = "adam")        ; Coleco ADAM
                            param1 := (If romExtension = ".ddp" ? " -cass1" : (If romExtension = ".dsk" ? " -flop1" : " -cart1")) . " """ . romPath . "\" . romName . romExtension . """"    ;  Decide if tape, disk, or cart game
                        Else If (mameID = "pegasus")    ; Aamber Pegasus
                        }Else If (mameID = "gp32")    ; GamePark 32
                                param1 := " -memc """ . romPath . "\" . romName . romExtension . """"
                        }Else If (mameID = "svmu")    ; Sega VMU
                        }Else If (mameID = "x1turbo40")    ; Sharp X1
                        {   If romExtension in .bin,.rom
                            Else
                        }Else If (mameID = "pc8801")    ; NEC PC-8801
                        {   If (romExtension = ".d88")
                        }Else If (mameID = "fmnew7    ")    ; Fujitsu FM-7
                        {   If romExtension in .fdi,.td0,.imd,.cqm,.dsk,.d77,.d88,.1dd
                            Else If romExtension in .wav,.t77
                        }Else If (mameID = "apple2ep")    ; Apple II
                        {    If romExtension in .dsk,.do,.po,.rti,.edd,.d77,.d88,.1dd,.dfi,.imd,.i pf,.mfi,.mfm,.td0,.cqm,.cqi
                        }Else If (mameID = "n64dd")        ; Nintendo 64DD
                            If FileExist(romPath . romName . ".n64")
                                param1 := " -cart """ . romPath . "\" . romName . ".n64"" -quik """ . romPath . "\" . romName . romExtension . """"
                            Else
                        }Else If mameID in studio2,mpt02        ;RCA Studio 2
                            Else {
                                If romName contains Doodle
                                    button2 := "A 1"    ; Press 1 on P1 controller
                                If romName contains Patterns
                                    button2 := "A 2"    ; Press 2 on P1 controller
                                If romName contains Bowling
                                    button2 := "A 3"    ; Press 3 on P1 controller
                                If romName contains Freeway
                                    button2 := "A 4"    ; Press 4 on P1 controller
                                If romName contains Addition
                                    button2 := "A 5"    ; Press 5 on P1 controller
                            ; Generate a lua script to press the Clear button so games will start
                            ScriptFileName := GeneratePressButtonScript("Clear",button2)
                            bootscript := " -script """ . ScriptFileName . """ -autoboot_delay 1"
                    } Else {    ; Use Software List
                        hashname := mameID
                        param1 := " """ . romName . """" ; param1 used for launching from software lists
                        {    hashname := "neogeo"
                            param2 := " -bios " . biosRegion    ; can also be japan, but the asian one has english menus for most games
                        CheckFile(emuPath . "\hash\" . hashname . ".xml","Could not find a software list for the system " . mameID) ;Check if software list for selected system exists
                        param2 := " -view "  . (If (FileExist(emuPath . "\artwork\Vectrex\" . romName . ".png"))?("""" . romName . """"):"standard")    ; need overlays extracted in the artwork\vectres folder. PNGs must match romName
                    sysStaticParams := If sysStaticParams != ""  ? A_Space . sysStaticParams : "" ; tacking on a space in case user forgot to add one
                    romParams := If romParams != ""  ? A_Space . romParams : "" ; tacking on a space in case user forgot to add one
                    StringReplace,mameRomPaths,romPathFromIni,|,`"`;`",1    ; replace all instances of | to ; in the Rom_Path from RL's Emulators.ini so MAME knows where to find your roms
                    mameRomPaths := " -rompath """ .  (If mameRomName ? romPath : mameRomPaths) . (If mameBiosPath ? ";" . mameBiosPath : "") . """"    ; If using an alt rom, only supply mame with the path to that rom so it doesn't try to use the original rom. If a bios path was supplied, add it into the rom paths sent to MAME
                    If InStr(romParams,"-rompath")
                        ScriptError("""-rompath"" is defined as a parameter for " . romName . ". The MAME module fills this automatically so please remove this from Params in the module's settings.")
                    If InStr(sysStaticParams,"-rompath")
                        ScriptError("""-rompath"" is defined as a parameter for " . mameSystem . ". The MAME module fills this automatically so please remove this from Params in the module's settings.")
                    ; use a custom rom name, not the one from the db
                    If mameRomName {
                        FileMove, %romPath%\%romName%%romExtension%, %romPath%\%mameRomName%%romExtension%    ; rename rom to match what mame needs
                        originalRomName := romName    ; store romName from database so we know what to rename it back to later
                        romName := mameRomName
                        If ErrorLevel
                            ScriptError("There was a problem renaming " . romName . "  to " . mameRomName . " in " . romPath . ". Please check you have write permission to this folder/file and you don't already have a file named """ . mameRomName . """ in your rom folder.",8)
                        Else    ; if rename was successful, set var so we know to move it back later
                            fileRenamed := 1
                    ; use a custom cfg file if it exists and append it to param1
                    If FileExist(emuPath . "\cfg\" . mameID . "\" . dbName)
                        param1 := " -cfg_directory " . """" . emuPath . "\cfg\" . mameID . "\" . dbName . """" . param1
                    If (bilinearFilter = "true")
                        bilinearEnabled := " -filter"
                    Else
                        bilinearEnabled := " -nofilter"
                    If (cheatMode = "true")
                    {    If (!FileExist(emuPath . "\cheat.zip") && !FileExist(emuPath . "\cheat.7z"))
                            ScriptError("You have cheats enabled for " . MEmu . " but could not locate a ""cheat.zip"" or ""cheat.7z"" in " . emuPath)
                        Else
                            Log("Module - Cheat file found in " . emuPath,4)
                        If cheatModeKey    ; if user wants to use a key to enable CheatMode
                            cheatEnabled := If XHotkeyAllKeysPressed(cheatModeKey) ? " -cheat" : ""    ; only enables cheatMode when key is held down on launch
                        Else    ; no cheat mode key defined
                            cheatEnabled := " -cheat"
                    If (RequiresReset = "true")
                    {    ; Generate a lua script to send a system soft reset
                        ScriptFileName := GenerateSoftResetScript()
                    HideEmuStart()
                    If (legacyMode = "true")
                    {    Log("Module - Running MAME in legacy Mode")
                        errLvl := Run("""" . executable . """ " . (If mameID = "MAME" ? romName : mameID . param1 . param2 . param3 . param4 . param5 . param6) . fullscreenParam . cheatEnabled . volume . mameRomPaths . sysStaticParams . romParams, emuPath, winstate)
                    } Else {
                        Log("Module - Running MAME in non-legacy mode")
                        ; If (networkPlayers = 1 || !linkEnabledGame) {
                        If !networkSession {
                            Log("Module - Single session",4)
                            errLvl := Run("""" . executable . """ " . (If mameID = "MAME" ? romName : mameID . param1 . param2 . param3 . param4 . param5 . param6) . mameRomPaths . sysStaticParams . romParams . fullscreenParam . hlsl . glsl . cheatEnabled . volume . inipath . hashpath . verticalRotationMode . videomode . artworkCrop . useBezels . useOverlays . useBackdrops . useCpanels . useMarquees . autosave . bootscript . bilinearEnabled . " -skip_gameinfo", emuPath, winstate)
                        } Else { ; multiplayer game run
                            Log("Module - Network/MultiPlayer session",4)
                            BuildNVRAMObject()    ; build nvram object
                            ;screen positions
                            screenPos := []
                            screenPos := SplitScreenPos(networkPlayers,splitScreen2PlayersMode,splitScreen3PlayersMode,maxPlayersPerMonitor)
                                globalInputs := " -global_inputs"        ; tell mame to accept inputs when its window is not focused
                            Loop, %networkPlayers%
                                currentPlayer := A_Index
                                ; Update NVRAM setting(s)
                                If (enableNVRAMAutomation = "true") {
                                    If nvramSettings[romName]["Settings"]["Credit"]["Position"].MaxIndex() {    ; If nvram settings exist for this game
                                        nvramFile := emuPath . "\nvram" . (If currentPlayer = 1 ? "" : currentPlayer) . "\" . romName . "\" . nvramSettings[romName]["Settings"]["NVRAM"]["File"][1]
                                        If FileExist(nvramFile) {
                                            Log("Module - Checking nvram file(s) for required changes",4)
                                            If (networkType = "localLink") {    ; only local link is supported for now
                                                ; Parse through each setting of each player and lookup the position to write new setting to the nvram file
                                                for playerOptionLabel, selectedPlayerOption in nvramSettings[romName]["Player"][currentPlayer] ;looping on each player selected options
                                                    for index, setting in nvramSettings[romName]["Settings"][playerOptionLabel]["Position"] ;Looping through hex values of the current option
                                                        HexCompareWrite(nvramFile,nvramSettings[romName]["Settings"][playerOptionLabel]["Position"][index],nvramSettings[romName]["Settings"][playerOptionLabel]["Option"][selectedPlayerOption][index])
                                                for index, playerCRC in nvramSettings[romName]["CRC"]["Player"][currentPlayer] ;looping on each player selected options
                                                    HexCompareWrite(nvramFile,nvramSettings[romName]["Settings"]["CRC"]["Position"][index],nvramSettings[romName]["CRC"]["Player"][currentPlayer][index])
                                            } Else If (networkType = "Server") {
                                                Log("Module - Converting this nvram to ""Master"" in: " . nvramFile,4)
                                                ; Log("Module - NVRAM automation for ""Server"" not supported at this time",4)    ; only idea to get this to work is to duplicate nvram edit code from local link here but only set player 1
                                                HexCompareWrite(nvramFile,nvramSettings[romName]["Settings"]["Link"]["Position"][1],nvramSettings[romName]["Settings"]["Link"]["Option"]["Master"][1])
                                            } Else If (networkType = "Client") {
                                                Log("Module - Converting this nvram to ""Slave"" in: " . nvramFile,4)
                                                ; Log("Module - NVRAM automation for ""Client"" not supported at this time",4)    ; only idea to get this to work is to duplicate nvram edit code from local link here but only set player 2
                                                HexCompareWrite(nvramFile,nvramSettings[romName]["Settings"]["Link"]["Position"][1],nvramSettings[romName]["Settings"]["Link"]["Option"]["Slave"][1])
                                        } Else
                                            Log("Module - Did not find an NVRAM file to update for player " . currentPlayer . " (Ignore this if this is the first time you are launching this rom): " . nvramFile,4)
                                    } Else
                                        Log("Module - This rom does not contain an entry in the NVRAM object",4)
                                ;;Run Line for each of the multiplayer MAME instances using the nvramPath and cfgPath variables to the extra mames
                                errLvl := Run("""" . executable . """ " . (If mameID = "MAME" ? romName : mameID . param1 . param2 . param3 . param4 . param5 . param6) . mameRomPaths . multiPlayerObj[currentPlayer]["CfgDir"] . multiPlayerObj[currentPlayer]["NvramDir"] . globalInputs . multiPlayerObj[currentPlayer]["LocalHost"] . multiPlayerObj[currentPlayer]["LocalPort"] . multiPlayerObj[currentPlayer]["RemoteHost"] . multiPlayerObj[currentPlayer]["RemotePort"] . sysStaticParams . romParams . fullscreenParam . hlsl . glsl . cheatEnabled . volume . inipath . hashpath . verticalRotationMode . videomode . artworkCrop . useBezels . useOverlays . useBackdrops . useCpanels . useMarquees . autosave . bootscript . bilinearEnabled . " -skip_gameinfo", emuPath, winstate, Screen%currentPlayer%PID)
                                WinWait("ahk_pid " . Screen%currentPlayer%PID)
                            ignoreWindows := "MAMEOutput"    ; ignore the mame debug window
                                WinGet, Screen%A_Index%ID, ID, % "ahk_pid " . Screen%A_Index%PID,, %ignoreWindows%
                                WinSet, Style, -0xC00000, % "ahk_id " . Screen%A_Index%ID,, %ignoreWindows%
                                ToggleMenu(Screen%A_Index%ID)
                                WinSet, Style, -0xC40000, % "ahk_id " . Screen%A_Index%ID,, %ignoreWindows%
                                MoveWindow("ahk_id " . Screen%A_Index%ID, screenPos[A_Index].X, screenPos[A_Index].Y, screenPos[A_Index].W, screenPos[A_Index].H,,ignoreWindows)
                                Sleep, 50
                    If errLvl {
                        If (errLvl = 1)
                            Error := "Failed Validity"
                        Else If(errLvl = 2)
                            Error := "Missing Files"
                        Else If(errLvl = 3)
                            Error := "Fatal Error"
                        Else If(errLvl = 4)
                            Error := "Device Error"
                        Else If(errLvl = 5)
                            Error := "Game Does Not Exist"
                        Else If(errLvl = 6)
                            Error := "Invalid Config"
                        Else If errLvl in 7,8,9
                            Error := "Identification Error"
                        Else
                            Error := "MAME Error"
                        Log("MAME Error - " . Error,3)
                    WinWait("ahk_class MAME")
                    WinWaitActive("ahk_class MAME")
                        SendCommand("X", 1000) ;To bypass the first screen
                        If (Command)
                            SendCommand(Command,,,,,, CommandWaitOffset) ;Send command affect it with an offset if needed
                    ;Close the debugger window if exists
                    If (closeDebugWindow = "true") {
                        WinWait("ahk_class MAMEDebugWindow",,2)
                        WinClose("ahk_class MAMEDebugWindow")
                    BezelDraw()
                    HideEmuEnd()
                        WinShow, ahk_class MAME    ; Show the emulator
                    } Else {
                        Loop %networkPlayers%
                            WinShow, % "ahk_id " . Screen%a_index%ID    ; Show the emulator
                        WinActivate, ahk_id %Screen1ID%        ; activate first player window so that first player can use keyboard instead of last player
                    FadeInExit()
                    7zCleanUp()
                    BezelExit()
                    If fileRenamed {    ; rename file back to alternate name for next launch
                        FileMove, %romPath%\%romName%%romExtension%, %romPath%\%originalRomName%%romExtension%
                        If ErrorLevel    ; if rename was successful, set var so we know to move it back later
                            ScriptError("There was a problem renaming " . romName . " back to " . originalRomName)
                    FadeOutExit()
                    ExitModule()
                    ; This will simply create a new blank ini if one does not exist
                    CheckFileMAME(file){
                        If !FileExist(file)
                            FileAppend,, %file%
                        Return file
                    ListXMLInfo(rom){ ; returns MAME info about parent rom, orientation angle, resolution
                        Global emuFullPath, emuPath
                        listXMLVarLog := ""
                        RunWait, % comspec . " /c " . """" . emuFullPath . """" . " -listxml " . rom . " > tempBezel.txt", %emuPath%, Hide
                        Fileread, ListxmlContents, %emuPath%\tempBezel.txt
                        RegExMatch(ListxmlContents, "s)<game.*name=" . """" . rom . """" . ".*" . "cloneof=" . """" . "[^""""]*", parent)
                        RegExMatch(parent,"cloneof=" . """" . ".*", parent)
                        RegExMatch(parent,"""" . ".*", parent)
                        StringTrimLeft, parent, parent, 1
                        RegExMatch(ListxmlContents, "s)<display.*rotate=" . """" . "[0-9]+" . """", angle)
                        RegExMatch(angle,"[0-9]+", angle, "-6")
                        RegExMatch(ListxmlContents, "s)<display.*width=" . """" . "[0-9]+" . """", width)
                        RegExMatch(width,"[0-9]+", width, "-6")
                        RegExMatch(ListxmlContents, "s)<display.*height=" . """" . "[0-9]+" . """", Height)
                        RegExMatch(Height,"[0-9]+", Height, "-6")
                        RegExMatch(ListxmlContents, "s)<control.*ways=" . """" . "[0-9]+" . """", Ways)
                        RegExMatch(Ways,"[0-9]+", Ways, "-6")
                        logVars := "Parent|Angle|Height|Width|Ways"
                        Loop, Parse, logVars, |
                            currentobj := {}
                            currentobj.Label := A_Loopfield
                            currentobj.Value := %A_Loopfield%
                            ListXMLObject.Insert(currentobj["Label"], currentobj)
                            listXMLLog .= "`r`n`t`t`t`t`t" . currentobj["Label"] . " = " . currentobj["Value"]
                        Log("Module - MAME ListXML values: " . listXMLLog,5)
                        If (ListXMLObject["Height"].Value > ListXMLObject["Width"].Value) {
                            ListXMLObject["Angle"].Value := true
                            Log("Module - This game's height is greater than its width, forcing vertical mode",5)
                        FileDelete, %emuPath%\tempBezel.txt
                        Return ListXMLObject
                    GenerateSoftResetScript(){    ; Generates a lua script to send a soft reset to MAME
                        Global emuPath
                        ScriptFileName := emuPath . "\soft_reset.lua"
                        FileDelete, %ScriptFileName%
                        FileAppend,
                        -- This script will reset the machine
                        local function reset_machine()
                          if resetcounter == nil then
                            manager:machine():soft_reset();
                            resetcounter = 1;
                          end
                        end
                          emu.wait(1);
                          reset_machine();
                        end
                        ), %ScriptFileName%
                        Return, ScriptFileName
                    GeneratePressButtonScript(button1,button2=""){    ; Generates a lua script to send a soft reset to MAME
                        Global emuPath
                        ScriptFileName := emuPath . "\press_button.lua"
                        If (button2) {
                            button2str = `n`t`temu.wait(1);`n`t`tioport["%button2%"]:write(1);`n`t`temu.wait(1);`n`t`tioport["%button2%"]:write(0);
                        FileAppend,
                        local function press_button()
                            ioport["%button1%"]:write(1);
                            emu.wait(1);
                            ioport["%button1%"]:write(0);
                            resetcounter = 1;%button2str%
                          end
                        end
                          emu.wait(1);
                          press_button();
                        end
                        ), %ScriptFileName%
                    BuildNVRAMObject() {
                        Global nvramSettings
                        Log("BuildNVRAMObject - Started",4)
                        nvramSettings := {}
                        nvramSettings["vr"] := {}
                        nvramSettings["vr"]["Settings"] := {"BiosCounter":{"Position":["248"], "Option":{0:["00"], 1:["01"], 2:["02"], 3:["03"]}}, "Cabinet":{"Position":["52"], "Option":{"Special":["00"], "Standard":["01"], "Upright":["02"], "2PLink":["03"]}}, "Color":{"Position":["68"], "Option":{"Red":["00"], "Blue":["01"], "Yellow":["02"], "Green":["03"], "Black":["04"], "Pink":["05"], "SkyBlue":["06"], "Orange":["07"]}}, "Country":{"Position":["54"], "Option":{"Japan":["00"], "USA":["01"], "Export":["02"]}}, "Course":{"Position":["66"], "Option":{"Vote":["00"], "Beginner":["01"], "Middle":["02"], "Expert":["03"]}}, "CRC":{"Position":["16","18"]}, "Credit":{"Position":["32","40"], "Option":{"1":["00","00"], "Freeplay":["1A","01"]}}, "Difficulty":{"Position":["64"], "Option":{"Easy":["00"], "Normal":["01"], "Hard":["02"], "Hardest":["03"]}}, "Link":{"Position":["24"], "Option":{"None":["00"], "Master":["01"], "Slave":["02"], "Live":["03"]}}, "Monitor":{"Position":["22"], "Option":{"Standard":["00"], "Wide":["01"]}}, "NVRAM":{"File":["nvram"]}, "Race":{"Position":["70"], "Option":{"Normal":["00"], "Grandprix":["01"]}}, "StartCoin":{"Position":["42"], "Option":{1:["01"], 2:["02"], 3:["03"], 4:["04"], 5:["05"]}}}
                        nvramSettings["vr"]["Player"] := {}
                        nvramSettings["vr"]["Player"].Insert(1, {"BiosCounter":"3", "Cabinet":"Standard", "Color":"Red", "Country":"USA", "Course":"Vote", "Credit":"Freeplay", "Difficulty":"Normal", "Link":"Master", "Monitor":"Wide", "Race":"Normal", "StartCoin":"1"})
                        nvramSettings["vr"]["Player"].Insert(2, {"BiosCounter":"3", "Cabinet":"Standard", "Color":"Blue", "Country":"USA", "Course":"Vote", "Credit":"Freeplay", "Difficulty":"Normal", "Link":"Slave", "Monitor":"Wide", "Race":"Normal", "StartCoin":"1"})
                        nvramSettings["vr"]["Player"].Insert(3, {"BiosCounter":"3", "Cabinet":"Standard", "Color":"Yellow", "Country":"USA", "Course":"Vote", "Credit":"Freeplay", "Difficulty":"Normal", "Link":"Slave", "Monitor":"Wide", "Race":"Normal", "StartCoin":"1"})
                        nvramSettings["vr"]["Player"].Insert(4, {"BiosCounter":"3", "Cabinet":"Standard", "Color":"Green", "Country":"USA", "Course":"Vote", "Credit":"Freeplay", "Difficulty":"Normal", "Link":"Slave", "Monitor":"Wide", "Race":"Normal", "StartCoin":"1"})
                        nvramSettings["vr"]["Player"].Insert(5, {"BiosCounter":"3", "Cabinet":"Standard", "Color":"Black", "Country":"USA", "Course":"Vote", "Credit":"Freeplay", "Difficulty":"Normal", "Link":"Slave", "Monitor":"Wide", "Race":"Normal", "StartCoin":"1"})
                        nvramSettings["vr"]["Player"].Insert(6, {"BiosCounter":"3", "Cabinet":"Standard", "Color":"Pink", "Country":"USA", "Course":"Vote", "Credit":"Freeplay", "Difficulty":"Normal", "Link":"Slave", "Monitor":"Wide", "Race":"Normal", "StartCoin":"1"})
                        nvramSettings["vr"]["Player"].Insert(7, {"BiosCounter":"3", "Cabinet":"Standard", "Color":"SkyBlue", "Country":"USA", "Course":"Vote", "Credit":"Freeplay", "Difficulty":"Normal", "Link":"Slave", "Monitor":"Wide", "Race":"Normal", "StartCoin":"1"})
                        nvramSettings["vr"]["Player"].Insert(8, {"BiosCounter":"3", "Cabinet":"Standard", "Color":"Orange", "Country":"USA", "Course":"Vote", "Credit":"Freeplay", "Difficulty":"Normal", "Link":"Slave", "Monitor":"Wide", "Race":"Normal", "StartCoin":"1"})
                        nvramSettings["vr"]["CRC"] := {"Player":{1:["06","21"], 2:["3C","C7"], 3:["0E","5F"], 4:["FF","D8"], 5:["4B","7F"], 6:["BA","F8"], 7:["88","60"], 8:["79","E7"]}}
                        nvramSettings["vformula"] := {}
                        nvramSettings["vformula"]["Settings"] := {"BiosCounter":{"Position":["248"], "Option":{0:["00"], 1:["01"], 2:["02"], 3:["03"]}}, "Color":{"Position":["68"], "Option":{"Red":["00"], "Blue":["01"], "Yellow":["02"], "Green":["03"], "Black":["04"], "Pink":["05"], "SkyBlue":["06"], "Orange":["07"]}}, "Country":{"Position":["54"], "Option":{"Japan":["00"], "USA":["01"], "Export":["02"]}}, "Course":{"Position":["66"], "Option":{"Vote":["00"], "Beginner":["01"], "Middle":["02"], "Expert":["03"]}}, "CRC":{"Position":["16","18"]}, "Credit":{"Position":["32","40"], "Option":{"1":["00","00"], "Freeplay":["1A","01"]}}, "Difficulty":{"Position":["64"], "Option":{"Easy":["00"], "Normal":["01"], "Hard":["02"], "Hardest":["03"]}}, "Link":{"Position":["24"], "Option":{"None":["00"], "Master":["01"], "Slave":["02"], "Live":["03"]}}, "NVRAM":{"File":["nvram"]}, "Race":{"Position":["70"], "Option":{"Normal":["00"], "Grandprix":["01"]}}, "Sound":{"Position":["22"], "Option":{"On":["00"], "Off":["01"]}}, "StartCoin":{"Position":["42"], "Option":{1:["01"], 2:["02"], 3:["03"], 4:["04"], 5:["05"]}}}
                        nvramSettings["vformula"]["Player"] := {}
                        nvramSettings["vformula"]["Player"].Insert(1, {"BiosCounter":"1", "Color":"Red", "Country":"USA", "Course":"Vote", "Credit":"Freeplay", "Difficulty":"Normal", "Link":"Master", "Race":"Normal", "Sound":"On", "StartCoin":"1"})
                        nvramSettings["vformula"]["Player"].Insert(2, {"BiosCounter":"1", "Color":"Blue", "Country":"USA", "Course":"Vote", "Credit":"Freeplay", "Difficulty":"Normal", "Link":"Slave", "Race":"Normal", "Sound":"On", "StartCoin":"1"})
                        nvramSettings["vformula"]["Player"].Insert(3, {"BiosCounter":"1", "Color":"Yellow", "Country":"USA", "Course":"Vote", "Credit":"Freeplay", "Difficulty":"Normal", "Link":"Slave", "Race":"Normal", "Sound":"On", "StartCoin":"1"})
                        nvramSettings["vformula"]["Player"].Insert(4, {"BiosCounter":"1", "Color":"Green", "Country":"USA", "Course":"Vote", "Credit":"Freeplay", "Difficulty":"Normal", "Link":"Slave", "Race":"Normal", "Sound":"On", "StartCoin":"1"})
                        nvramSettings["vformula"]["Player"].Insert(5, {"BiosCounter":"1", "Color":"Black", "Country":"USA", "Course":"Vote", "Credit":"Freeplay", "Difficulty":"Normal", "Link":"Slave", "Race":"Normal", "Sound":"On", "StartCoin":"1"})
                        nvramSettings["vformula"]["Player"].Insert(6, {"BiosCounter":"1", "Color":"Pink", "Country":"USA", "Course":"Vote", "Credit":"Freeplay", "Difficulty":"Normal", "Link":"Slave", "Race":"Normal", "Sound":"On", "StartCoin":"1"})
                        nvramSettings["vformula"]["Player"].Insert(7, {"BiosCounter":"1", "Color":"SkyBlue", "Country":"USA", "Course":"Vote", "Credit":"Freeplay", "Difficulty":"Normal", "Link":"Slave", "Race":"Normal", "Sound":"On", "StartCoin":"1"})
                        nvramSettings["vformula"]["Player"].Insert(8, {"BiosCounter":"1", "Color":"Orange", "Country":"USA", "Course":"Vote", "Credit":"Freeplay", "Difficulty":"Normal", "Link":"Slave", "Race":"Normal", "Sound":"On", "StartCoin":"1"})
                        nvramSettings["vformula"]["CRC"] := {"Player":{1:["F2","EB"], 2:["C8","0D"], 3:["FA","95"], 4:["0B","12"], 5:["BF","B5"], 6:["4E","32"], 7:["7C","AA"], 8:["8D","2D"]}}
                        Log("BuildNVRAMObject - Ended",4)
                    BezelLabel:
                        WinSet, Transparent, 0, ahk_class ConsoleWindowClass
                    Return
                    HaltEmu:
                        If (pauseMethod = 1)
                        {    disableSuspendEmu := "true"
                            disableRestoreEmu := "true"
                            PostMessage,0x211, 1, , , ahk_class MAME
                        } Else If (pauseMethod = 2)
                        } Else If (pauseMethod = 3)
                            PostMessage,% 0x0400+6, 1, , , ahk_class MAME
                        } Else If (pauseMethod = 4)
                        } Else If (pauseMethod = 5)
                            Send, {P down}
                            Sleep, 1000
                            Send, {P up}
                    Return
                    RestoreEmu:
                        {    PostMessage,0x212, 1, , , ahk_class MAME
                            WinActivate, ahk_class MAME
                        {    PostMessage,% 0x0400+6, 0, , , ahk_class MAME
                            Send, {P down}
                            Sleep, 1000
                            Send, {P up}
                        } Else If (pauseMethod = 6)
                    Return
                    CloseProcess:
                        FadeOutStart()
                        If (networkSession && networkPlayers > 1) {
                            {    WinClose("ahk_id " . Screen%A_Index%ID)
                                WinWaitClose("ahk_id " . Screen%A_Index%ID)
                        } Else
                            WinClose("ahk_class MAME")
                    Return
12:05:49:363 | RL |     INFO  | +15    | BuildScript - Loaded MultiGame scripts
12:05:49:363 | RL |     INFO  | +0     | BuildScript - Loaded Multi-Player scripts
12:05:49:363 | RL |     INFO  | +0     | BuildScript - Loaded Statistics.ahk script
12:05:49:363 | RL |  WARNING  | +0     | BuildScript - "E:\RocketLauncher\Lib\User Functions.ahk" not found
12:05:49:363 | RL |     INFO  | +0     | BuildScript - Finished injecting functions into module
12:05:49:363 | RL |     INFO  | +0     | Main - Module is built
12:05:49:368 | RL |     INFO  | +16    | CheckFile - Checking if E:\RocketLauncher\AutoHotkey.dll exists
12:05:49:383 | RL |     INFO  | +15    | Main - Running module
12:05:49:558 | MD |     INFO  | +N/A   | Module initialized
12:05:49:558 | MD |     INFO  | +0     | StartModule - Started
12:05:49:558 | MD |     INFO  | +0     | StartModule - MEmu: MAME
                    MEmuV: v0.166
                    MURL: http://www.mame.net/
                    MAuthor: djvj,faahrev,brolly,Tomkun
                    MVersion: 2.3.1
                    MCRC: 9B041EF3
                    iCRC: 72BB0F21
                    MID:
                    MSystem: "AAE","Aamber Pegasus","Acorn Electron","Amstrad CPC","Amstrad GX4000","APF Imagination Machine","Apple II","Apple IIGS","Applied Technology MicroBee","Atari 8-Bit","Atari 2600","Atari 5200","Atari 7800","Atari Classics","Atari Jaguar","Atari Lynx","Bally Astrocade","Bandai Super Vision 8000","Bandai WonderSwan","Bandai WonderSwan Color","Bit Corporation Gamate","Camputers Lynx","Capcom","Capcom Classics","Capcom Play System","Capcom Play System II","Capcom Play System III","Casio PV-1000","Casio PV-2000","Cave","Coleco ADAM","ColecoVision","Commodore 64","Commodore MAX Machine","Creatronic Mega Duck","Data East Classics","EACA EG2000 Colour Genie","Emerson Arcadia 2001","Entex Adventure Vision","Epoch Game Pocket Computer","Epoch Super Cassette Vision","Exidy Sorcerer","Fairchild Channel F","Fujitsu FM-7","Funtech Super Acan","GamePark 32","GCE Vectrex","Hartung Game Master","HBMAME","Interton VC 4000","Irem Classics","JungleTac Sport Vii","Jupiter Ace","Konami Classics","LaserDisc","Magnavox Odyssey 2","MAME","Matra & Hachette Alice","Mattel Aquarius","Mattel Intellivision","MGT Sam Coupe","Midway Classics","Milton Bradley MicroVision","Namco Classics","Namco System 22","NEC PC-8801","NEC PC Engine","NEC PC Engine-CD","NEC SuperGrafx","NEC TurboGrafx-16","NEC TurboGrafx-CD","Nintendo 64","Nintendo 64DD","Nintendo Arcade Systems","Nintendo Classics","Nintendo Entertainment System","Nintendo Famicom","Nintendo Famicom Disk System","Nintendo Game Boy","Nintendo Game Boy Advance","Nintendo Game Boy Color","Nintendo Pokemon Mini","Nintendo Satellaview","Nintendo Super Famicom","Nintendo Super Game Boy","Nintendo Virtual Boy","Othello Multivision","PacMAME","Philips CD-i","Philips VG 5000","Philips Videopac Plus G7400","RCA Studio II","Sega 32X","Sega CD","Sega Classics","Sega Game Gear","Sega Genesis","Sega Master System","Sega Mega Drive","Sega Model 1","Sega Pico","Sega Saturn","Sega SC-3000","Sega SG-1000","Sega ST-V","Sega VMU","Sharp X1","Sinclair ZX81","SNK Classics","SNK Neo Geo","SNK Neo Geo AES","SNK Neo Geo AES","SNK Neo Geo CD","SNK Neo Geo MVS","SNK Neo Geo Pocket","SNK Neo Geo Pocket Color","Sony PlayStation","Sony PocketStation","Sord M5","Soundic Victory MPT-02","Super Nintendo Entertainment System","Taito Classics","Tandy TRS-80 Color Computer","Texas Instruments TI 99-4A","Tiger Game.com","Tomy Tutor","VTech CreatiVision","Watara Supervision","Williams Classics"
12:05:49:558 | MD |     INFO  | +0     | StartModule - You have a supported System Name for this module: "MAME"
12:05:49:563 | MD |     INFO  | +0     | PluginInit - Started
12:05:49:563 | MD |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Databases\MAME\MAME.xml exists
12:05:49:588 | MD |     INFO  | +31    | PluginInit - Ended
12:05:49:588 | MD |     INFO  | +0     | StartModule - Ended
12:05:49:588 | MD |  WARNING  | +0     | Module - "MAME" is not a known console or computer system. Defaulting to MAME's Arcade mode for the remainder of this MAME module.
12:05:49:588 | MD |     INFO  | +0     | Module Setting - [Settings] - Fullscreen: true
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [Settings] - LegacyMode: false
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [MAME] - LegacyMode: false
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [mslug] - LegacyMode: false
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [Settings] - MAME_BIOS_Path: E:\Hyperspin\Emulators\MAMEUIFX\roms
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [Settings] - Videomode: d3d
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [Settings] - PauseMethod: 1
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [Settings] - BilinearFilter: false
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [MAME] - BilinearFilter: false
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [Settings] - HLSL: false
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [MAME] - HLSL: true
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [mslug] - HLSL: true
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [Settings] - GLSL: false
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [MAME] - GLSL: false
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [mslug] - GLSL: false
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [Settings] - BezelMode: layout
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [MAME] - BezelMode: layout
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [mslug] - BezelMode: layout
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [Settings] - VerticalRotationMode: none
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [MAME] - VerticalRotationMode: none
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [mslug] - VerticalRotationMode: none
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [Settings] - CheatMode: false
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [Settings] - CheatModeKey:
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [MAME] - UseSoftwareList: false
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [mslug] - UseSoftwareList: false
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [MAME] - StaticParameters:
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [MAME] - Parameters:
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [mslug] - Parameters:
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [mslug] - MameRomName:
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [MAME] - Autosave: false
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [mslug] - Autosave: false
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [Settings] - Volume:
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [MAME] - Volume:
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [mslug] - Volume:
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [MAME] - Artwork_Crop: true
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [mslug] - Artwork_Crop: true
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [MAME] - Use_Bezels: false
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [mslug] - Use_Bezels: false
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [MAME] - Use_Overlays: true
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [mslug] - Use_Overlays: true
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [MAME] - Use_Backdrops: true
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [mslug] - Use_Backdrops: true
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [MAME] - Use_Cpanels: false
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [mslug] - Use_Cpanels: false
12:05:49:593 | MD |     INFO  | +0     | Module Setting - [MAME] - Use_Marquees: false
12:05:49:598 | MD |     INFO  | +0     | Module Setting - [mslug] - Use_Marquees: false
12:05:49:598 | MD |     INFO  | +0     | Module Setting - [MAME] - IniPath:
12:05:49:598 | MD |     INFO  | +0     | Module Setting - [MAME] - HashPath:
12:05:49:598 | MD |     INFO  | +0     | Module Setting - [Link/Network] - Enable_Link_Play: false
12:05:49:598 | MD |     INFO  | +0     | Module Setting - [mslug] - Enable_Link_Play: false
12:05:49:598 | MD |     INFO  | +0     | Module Setting - [mslug] - Parameters:
12:05:49:598 | MD |     INFO  | +0     | Module Setting - [mslug] - HLSL: true
12:05:49:598 | MD |     INFO  | +0     | Module Setting - [mslug] - GLSL: false
12:05:49:598 | MD |     INFO  | +0     | Module Setting - [mslug] - Artwork_Crop: true
12:05:49:598 | MD |     INFO  | +0     | Module Setting - [mslug] - Use_Bezels: false
12:05:49:598 | MD |     INFO  | +0     | Module Setting - [mslug] - Use_Overlays: true
12:05:49:598 | MD |     INFO  | +0     | Module Setting - [mslug] - Use_Backdrops: true
12:05:49:598 | MD |     INFO  | +0     | Module Setting - [mslug] - Use_Cpanels: false
12:05:49:598 | MD |     INFO  | +0     | Module Setting - [mslug] - UseSoftwareList: false
12:05:49:598 | MD |     INFO  | +0     | Module - Detected MAME Product Version from 'E:\Hyperspin\Emulators\MAMEUIFX\MAMEUIFX .153 FIX x64 NoNag+HiScore+NeoGeoXtra+DirectInput.exe' is 153
12:05:49:598 | MD |     INFO  | +0     | Module - Running MAME in non-legacy mode
12:05:49:598 | MD |     INFO  | +0     | Run - Running: E:\Hyperspin\Emulators\MAMEUIFX\"MAMEUIFX .153 FIX x64 NoNag+HiScore+NeoGeoXtra+DirectInput.exe" mslug -rompath "E:\Hyperspin\Roms\MAME-Neo Geo-Arcade Classics-CPS-Sega STV;E:\Hyperspin\Emulators\MAMEUIFX\roms" -nowindow -hlsl_enable -video d3d -artwork_crop -nouse_bezels -use_overlays -use_backdrops -nouse_cpanels -nouse_marquees -nofilter -skip_gameinfo
12:05:49:658 | MD |     INFO  | +63    | WinWait - Waiting for "ahk_class MAME"
12:05:49:928 | MD |     INFO  | +280   | WinWaitActive - Waiting for "ahk_class MAME"
12:05:50:178 | MD |     INFO  | +250   | Process - WaitClose MAMEUIFX .153 FIX x64 NoNag+HiScore+NeoGeoXtra+DirectInput.exe
12:24:39:633 | MD |     INFO  | +1129447 | ExitModule - Started
12:24:39:633 | MD |     INFO  | +0     | Starting Updating Statistics:
12:24:39:958 | MD |     INFO  | +328   | Game section statistics updated.
12:24:39:963 | MD |     INFO  | +0     | ExitModule - Ended
12:24:39:963 | MD |     INFO  | +0     | End of Module Logs
12:24:40:063 | RL |     INFO  | +1130680 | Main - Module ended, exiting RocketLauncher normally
12:24:40:063 | RL |     INFO  | +0     | ExitScript - Started
12:24:40:318 | RL |     INFO  | +250   | SystemCursor - Restoring mouse cursor
12:24:40:328 | RL |     INFO  | +15    | ExitScript - Ended
Sorry man. Now Mame close outside of RL or HS. I noticed that it is something related to HLSL. When the HLSL is on, mame is closed. What is burning my head is that is not always what happens. Today I play some games normally. When suddenly stops working. I restart the PC and MAME works and again suddenly stops working.
PLEASE HELP ME.
MAMEUIFX 0.153 FIX x64 NoNag+HiScore+NeoGeoXtra+DirectInput
Got from the SIMPLY AUSTIN SETUP
Yes the roms match with this version.
I always use this mame. After i formated my pc the problems began.
As I said before, everything is fine suddenly mame stop working.  Editar
[sOLVED]
Thank God! Finally I figured out the problem. There was nothing wrong with the RocketLauncher, Mame or HyperSpin. The problem was of the video card driver which has been updated. And then was causing a problem. I did a downgrade and everything worked. Thanks mate.
My Graphic Card is AMD Radeon HD 6570 and the version of right driver is Catalyst Software Suite 15.7.1 "PLEASE DON'T UPDATE"
Glad you got it figured out. No one hear would ever have been able to guess that.
Also the MAME 153 from that tutorial is really old (almost 3 years). Now that you have it working it might be good to update to the newest (or newer at least) version.
Right now 173 is the latest, but the big improvements really started happening in 162 and newer. They release a new version on the last Wednesday of every month.
