JFlash3785 Posted January 13, 2014 Posted January 13, 2014 Finally started my build. Thank you to sandman7793, sparkywallnut, polemicist. Without your help I would still be in the planning stage. Big ups! I have a few questions that I am hoping to get some help on? 1. Where should I buy buttons 2. Where should I buy trackball 3. What type of wires should I get 4. Ipac or ipac-2? 5. Anything else i need to get for the CP I went with 3/4 plywood since it was cheaper.
Polemicist Posted January 13, 2014 Posted January 13, 2014 1. Where should I buy buttons 2. Where should I buy trackball 3. What type of wires should I get 4. Ipac or ipac-2? 5. Anything else i need to get for the CP 6. I went with 3/4 plywood 1 & 2 www.ultimarc.com 3 Ulyimarc has wire kits pre done 4 You get the iPac big enough to suit your rig. All comes down to how many players you want. 5. Joystick choice. I you get joysticks that have USB connectors rather than connecting to your iPac you reduce they amount of Key Ghosting you will get. You do bring driver issues and other spin problems with HyperSpin especially with Analogue sticks but XPadder can fix that. Do you want a Spinner? If so Ultimarc. 6 Plywood is fine. Make sure you seal it perfectly with plenty of paint. Have fun.
