KMetalmind Posted May 8, 2016 Posted May 8, 2016 Hi there! I´m starting to enter the HyperList XML world. Until now, I just gave up on having extra information for each game, but since I found HyperList XMLs, all has changed. I´ve found that some lists have errors. How should I proceed to fix them? For example, on the SMS one (v1.2), Phantasy Star manufacturer is Tengen, when the game was developed and published by Sega. I don´t get what should be the manufacturer when developer and publisher aren´t the same, as I see inconsitencies. For example, Sonic Blast manufacturer is "Tec Toy"- The original game was developed and published by Sega, but Tec Toy did a SMS port later. Meanwhile, Baku Baku Animal is on the same situation, but manufacturer is Sega. Which one should be used? Lastly, there´s no number of players or controller type info... Is there any plan for this? Thanks in advance for all the answers!!
kylecp1979 Posted May 8, 2016 Posted May 8, 2016 I would say try making your own if your that hardcore about the info for each game.
32assassin Posted May 8, 2016 Posted May 8, 2016 first of you should not call those XML errors. you should call them incorrect information. an XML error will give Hyperspin a load error, incorrect information will just make you grind your teeth. second their is a group of people updating the XMLs. if you like to join or have corrections, please join the group or post your changes in the correct forum. http://www.hyperspin-fe.com/topic/15736-the-big-hs-database-update-project/
KMetalmind Posted May 13, 2016 Author Posted May 13, 2016 Thanks for pointing me in the right direction and sorry about messing the topic name
