aardal1 Posted May 14, 2016 Posted May 14, 2016 Hello Out of all my systems, i find scummvm the hardest to set up! I have been messing around with this for some time, and i see no other option then to ask for help. The games are launching fine within scummvm. When i launch a game from HL i can only see a command window briefly then for some time i get the "There was an error waiting for the window "ahk_class SDL_app"" Please see the log file: 20:14:22:795 | HL | INFO | +N/A | Main - HyperLaunch v3.0.1.0 20:14:22:796 | HL | INFO | +0 | Main - System Specs: HyperLaunch Dir: Z:\Hyperspin\HyperLaunch OS: WIN_7 Architecture: 64-bit (might not be accurate) OS Language: English_United_States OS Admin Status: Yes Monitor #1 (\\.\DISPLAY1): 1280x720 (1280x720 work) AutoHotkey Path: C:\Program Files\AutoHotkey\AutoHotkey.exe AHK Version: 1.1.09.04 Unicode: No 20:14:22:796 | HL | INFO | +0 | Main - HyperSpin.exe coordinates are x y w h 20:14:22:796 | HL | INFO | +0 | CheckFile - Checking if Z:\Hyperspin\HyperLaunch\HyperLaunch.exe exists 20:14:22:797 | HL | INFO | +0 | Main - HyperLaunch received "Scummvm" and "gob" 20:14:22:801 | HL | INFO | +0 | Main - gob is using the default emulator: ScummVM 20:14:22:801 | HL | INFO | +0 | Main - Checking for a [ScummVM] section in Z:\Hyperspin\HyperLaunch\Settings\Scummvm\Emulators.ini 20:14:22:802 | HL | INFO | +0 | Main - Checking for a [ScummVM] section in Z:\Hyperspin\HyperLaunch\Settings\Global Emulators.ini 20:14:22:802 | HL | INFO | +0 | Main - Found [ScummVM] in Z:\Hyperspin\HyperLaunch\Settings\Global Emulators.ini 20:14:22:802 | HL | INFO | +0 | CheckFile - Checking if Z:\Hyperspin\HyperLaunch\Modules\ScummVM\ScummVM.ahk exists 20:14:22:807 | HL | INFO | +0 | Main - CRC Check - CRC matches, this is an official unedited module. 20:14:22:807 | HL | INFO | +0 | Main - gob will use module: Z:\Hyperspin\HyperLaunch\Modules\ScummVM\ScummVM.ahk 20:14:22:816 | HL | INFO | +16 | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks. 20:14:22:817 | HL | INFO | +0 | Main - INI Keys read 20:14:22:817 | HL | INFO | +0 | CheckFile - Checking if Z:\Hyperspin\HyperLaunch\Module Extensions\7z.exe exists 20:14:22:817 | HL | INFO | +0 | CheckFile - Checking if Z:\Hyperspin\HyperLaunch\Module Extensions\7z.dll exists 20:14:22:818 | HL | WARNING | +0 | Main - SkipChecks is enabled and set to: Rom Extension 20:14:22:818 | HL | INFO | +0 | CheckPaths - Started 20:14:22:818 | HL | INFO | +0 | CheckPaths - Found rom: Z:\Hyperspin\Emulators\Scummvm\test rom\gob.zip 20:14:22:818 | HL | INFO | +0 | CheckFile - Checking if Z:\Hyperspin\Emulators\Scummvm\scummvm-1.5.0-win32\scummvm.exe exists 20:14:22:819 | HL | INFO | +0 | CheckPaths - Ended 20:14:22:819 | HL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 20:14:22:819 | HL | INFO | +0 | BuildScript - Loaded Keymapper Init.ahk scripts 20:14:22:819 | HL | INFO | +0 | CheckFile - Checking if Z:\Hyperspin\HyperLaunch\Module Extensions\VA.ahk exists 20:14:22:821 | HL | INFO | +0 | BuildScript - Loaded HyperPause Init.ahk scripts 20:14:22:821 | HL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 20:14:22:821 | HL | INFO | +0 | BuildScript - Loaded User Functions Init.ahk script 20:14:22:822 | HL | INFO | +0 | BuildScript - Loaded HyperPause scripts 20:14:22:822 | HL | INFO | +0 | BuildScript - Loaded Statistics.ahk script 20:14:22:822 | HL | INFO | +0 | BuildScript - Loaded User Functions.ahk script 20:14:22:822 | HL | INFO | +0 | BuildScript - Finished injecting functions into module 20:14:22:823 | HL | INFO | +0 | Main - Module is built 20:14:22:823 | HL | INFO | +0 | CheckFile - Checking if Z:\Hyperspin\HyperLaunch\AutoHotkey.dll exists 20:14:22:823 | HL | INFO | +0 | Main - Running module 20:14:22:946 | MD | INFO | +N/A | Module initialized 20:14:22:972 | MD | INFO | +31 | Keymapper - Sorting Currently Connected joysticks List to match the order of the Preferred Controller List 20:14:22:972 | MD | INFO | +0 | Keymapper - Assigning the New Joystick IDs according to the preferred list for the active controllers 20:14:22:972 | MD | INFO | +0 | CheckFile - Checking if Z:\Hyperspin\KeyMapper\JoyToKey 5.1\JoyToKey.exe exists 20:14:22:973 | MD | INFO | +0 | Keymapper - Loading joytokey 20:14:22:978 | MD | INFO | +0 | Keymapper - Loading Profile -> Z:\Hyperspin\HyperLaunch\Profiles\joytokey\Scummvm.cfg 20:14:23:090 | MD | INFO | +125 | Keymapper - Run, JoyToKey.exe "Z:\Hyperspin\HyperLaunch\Profiles\joytokey\Scummvm.cfg", Z:\Hyperspin\KeyMapper\JoyToKey 5.1 20:14:23:139 | MD | INFO | +47 | StartModule - Started 20:14:23:139 | MD | INFO | +0 | StartModule - MEmu: ScummVM MEmuV: v1.5.0 MURL: http://scummvm.org/ MAuthor: djvj MVersion: 2.0.4 MCRZ: 4C08188F iCRZ: B2D94E9B MID: MSystem: "ScummVM" 20:14:23:139 | MD | INFO | +0 | StartModule - You have a supported System Name for this module: "Scummvm" 20:14:23:139 | MD | INFO | +0 | StartModule - Ended 20:14:23:139 | MD | INFO | +0 | StartGlobalUserFeatures - Starting 20:14:23:139 | MD | INFO | +0 | StartGlobalUserFeatures - Ending 20:14:23:140 | MD | INFO | +0 | CheckFile - Checking if C:\Users\UltimateArcade\AppData\Roaming\ScummVM\scummvm.ini exists 20:14:23:140 | MD | INFO | +0 | Module Setting - [Settings] - Fullscreen: true 20:14:23:140 | MD | INFO | +0 | Module Setting - [Settings] - SaveKey: 1 20:14:23:140 | MD | INFO | +0 | Module Setting - [Settings] - LoadKey: 2 20:14:23:140 | MD | INFO | +0 | Module Setting - [Settings] - MenuKey: p 20:14:23:140 | MD | INFO | +0 | 7z - Started, received Z:\Hyperspin\Emulators\Scummvm\test rom\gob.zip. If rom is an archive, it will extract to C:\Users\Arkade\AppData\Local\Temp 20:14:23:140 | MD | INFO | +0 | CheckFile - Checking if Z:\Hyperspin\Emulators\Scummvm\test rom\gob.zip exists 20:14:23:219 | MD | INFO | +78 | CreateMGRomTable - Started 20:14:23:219 | MD | INFO | +0 | CreateRomTable - Started 20:14:23:219 | MD | INFO | +0 | CreateRomTable - Ended, 7 Loops to create table. 20:14:23:219 | MD | INFO | +0 | CreateMGRomTable - Ended 20:14:23:219 | MD | INFO | +0 | 7z - Ended 20:14:23:220 | MD | INFO | +0 | Module Setting - [gob] - path: Z:\Hyperspin\Emulators\Scummvm\test rom\gob\ 20:14:23:220 | MD | INFO | +0 | Run - Running: Z:\Hyperspin\Emulators\Scummvm\scummvm-1.5.0-win32\scummvm.exe -f "-pZ:\Hyperspin\Emulators\Scummvm\test rom\gob\" gob 20:14:23:236 | MD | INFO | +15 | WinWait - Waiting for ahk_class SDL_app 20:14:55:836 | MD | ERROR | +32604 | There was an error waiting for the window "ahk_class SDL_app". Please check you have the correct version emulator installed for this module, followed any notes in the module, and have this emulator working outside your Frontend first. Also turn off Fade to see if you are hiding your problem. 20:14:55:836 | MD | INFO | +0 | ExitModule - Started 20:14:55:836 | MD | INFO | +0 | Starting Updating Statistics: 20:14:55:937 | MD | INFO | +94 | Game section statistics updated. 20:14:55:963 | MD | INFO | +31 | Keymapper - Loading Profile -> Z:\Hyperspin\HyperLaunch\Profiles\joytokey\HyperSpin.cfg 20:14:56:092 | MD | INFO | +125 | Keymapper - Run, JoyToKey.exe "Z:\Hyperspin\HyperLaunch\Profiles\joytokey\HyperSpin.cfg", Z:\Hyperspin\KeyMapper\JoyToKey 5.1 20:14:56:117 | MD | INFO | +31 | ExitModule - Ended 20:14:56:117 | MD | INFO | +0 | End of Module Logs 20:14:56:163 | HL | INFO | +33353 | Main - Module ended, exiting HyperLaunch normally 20:14:56:163 | HL | INFO | +0 | ExitScript - Started 20:14:56:171 | HL | INFO | +0 | SystemCursor - Restoring mouse cursor 20:14:56:176 | HL | INFO | +0 | ExitScript - Ended
Guest Posted May 17, 2016 Posted May 17, 2016 Make sure you are using a recent version of ScummVM, 1.7 or 1.8. You want to have the roms unzipped with each game in its own folder, with the folder name being that from the name tab in the database. If you have the official database this should already be the case. You also need to load ScummVM on its own, and then add the games in the UI. If you load ScummVM and press shift you'll notice the buttons change to allow you to add multiple games at the same time. Press the button and select your ScummVM rom folder. Sent from my iPhone using Tapatalk
aardal1 Posted May 18, 2016 Author Posted May 18, 2016 Thanks for your reply, tonesmalone! I only have the Scummvm 1.5 module... Where can I get an updated version for 1.7 og 1.8? In my folder I have both unzipped and zipped versions of the roms. Scummvm will not add zipped roms, and Hyperlaunch will not detect unzipped rom folders... How is this done right? I dont have an official database, I created my own from my rom names... I will try with the official and then rename the roms accordingly. Edit: Is it important that the "id tag" of the game in Scummvm is matchine the rom/database name? Like This Mark Solved Quote MultiQuote Edit Report #3 tonesmalone
Guest Posted May 18, 2016 Posted May 18, 2016 Thanks for your reply, tonesmalone! I only have the Scummvm 1.5 module... Where can I get an updated version for 1.7 og 1.8? In my folder I have both unzipped and zipped versions of the roms. Scummvm will not add zipped roms, and Hyperlaunch will not detect unzipped rom folders... How is this done right? I dont have an official database, I created my own from my rom names... I will try with the official and then rename the ... Ah you're using HyperLauncher. I'd advise you move to RocketLauncher as HL is unlikely to get anymore updates. RL is basically the next version of HL just renamed now as it supports multiple frontends.I'd really advice that change as your next step. There is a migration tool and tutorial available at the RL forums.
guyverjay Posted May 19, 2016 Posted May 19, 2016 If using rocketlauncher, unzip the games (don't delete the zipped files) into the correct named folders and place those folders in your rocketlauncher temp directory (Where it unzips roms to), then add them into scummvm. Then delete the games from your temp directory. This way you can tel rocketlauncher to unzip and launch scummvm games as it will unzip them to a path scummvm expects them to be
Dime333 Posted May 19, 2016 Posted May 19, 2016 If using rocketlauncher, unzip the games (don't delete the zipped files) into the correct named folders and place those folders in your rocketlauncher temp directory (Where it unzips roms to), then add them into scummvm. Then delete the games from your temp directory. This way you can tel rocketlauncher to unzip and launch scummvm games as it will unzip them to a path scummvm expects them to be Does this method work for you with the current module? This is the method I've always been using. It stopped working after the big RL update in April. When I use an older module, it works fine. I have a thread about this in the RL forums. http://www.rlauncher.com/forum/showthread.php?3250-ScummVm-issue-with-latest-module&p=27691#post27691 Edit: Actually, I wasn't using this exact method. I didn't unzip the games to my temp folder. You don't need to do that. I have no idea how that works. All the game paths in my ScummVM ini is pointing to the folder that I unzipped the games to (which doesn't exist anymore). This works great with the older module. I just tested changing all the paths in the ini to my temp folder but it's still not working with the latest module. I even tried unzipping "atlantis-fm" manually and put the files in my temp folder. Launched the game in RL and got the error message. After that, RL had deleted the game. Something must be wrong with the module.
Dime333 Posted May 20, 2016 Posted May 20, 2016 Try setting the LaunchMode to Auto instead of ParseIni in the module settings and see if that works Dime. Oh, my god! That worked. I'm pretty sure that didn't work before I changed all the paths in the ini to point to my Temp folder. Thank you very much.
Dime333 Posted May 20, 2016 Posted May 20, 2016 Yeah, with the Auto setting it reads the emu's ini file, so if the path is correct in there it should launch. Before testing other stuff I set those paths to my temp folder and the Auto setting worked. Fantastic. Thanks again.
aardal1 Posted May 20, 2016 Author Posted May 20, 2016 Thanks for all the great feedback! I have now updated to rocketlauncher following the transition from hyperlaunch guide. I was kind of shocked when i launched rocketlauncher to find out that all my systems where gone... Is this the case or have i screwed it up?? Solved: Im sorry i found the solution in the wiki: http://www.rlauncher.com/wiki/index.php?title=RocketLauncher_Troubleshooting#I_just_setup_RocketLauncher_and_my_Front_End_does_not_show_up_in_RocketLauncherUI_and.2For_all_my_systems_are_not_there It is now showing all my systems and my original problem is solved right out of the box. Scummvm is now launching! Thanks and have a great weekend!
