den4B ReNamer batch renaming utility
I found this while searching for something to rename all of my rom files to match the various artwork packs I've downloaded off the HS forums. This is a MUST HAVE if you need to rename a ton of files for any reason...a great little freeware program where you just drop the files you want to rename (entire directories or whatever) and then throw in the wildcards you need...then hit "rename" and you're done. I found this extremely useful when my romsets had something like donkeykong (usa/europe) # 7800.zip or something for the filename and I needed it to say donkeykong.zip. Just put the wildcard " (*) # 7800 " (without quotes) in the "remove" rule and click "Interpret symbols as wildcards" and you're all done...700+ files in 2 seconds. Hopefully this will help out some of the newbies (like myself) who are looking for a quick fix to rename romsets to work with HS theme packs. Here's a link:
http://www.den4b.com/downloads.php?project=ReNamer
  • 4 years later...
