griffin518 Posted June 30, 2016 Posted June 30, 2016 Thank you! Download my RocketLauncher bezels: http://hyperspin-fe.com/files/file/14367-griffin518s-bezel-depot/ Best of MAME HyperSpin XML: http://www.hyperspin-fe.com/files/file/11710-griffin518s-best-of-mame-xml-database/ Best of MAME bezel pack: http://www.hyperspin-fe.com/files/file/11711-griffin518s-best-of-mame-bezel-pack/ Custom MAME ini files w/HLSL settings: http://www.hyperspin-fe.com/files/file/11712-griffin518s-best-of-mame-mameuifx-ini-files/
Metalzoic Posted July 1, 2016 Author Posted July 1, 2016 doing a mame as we speak and the mameuifx will be made tomorrowYou rock. Looking forward to the UiFX. Do you know if we need all new ini's & cfg's with 175 from 174? Sent from my SM-G935V
sevenseal Posted July 1, 2016 Posted July 1, 2016 You rock. Looking forward to the UiFX. Do you know if we need all new ini's & cfg's with 175 from 174? Sent from my SM-G935V to be honest, i am not sure
Metalzoic Posted July 3, 2016 Author Posted July 3, 2016 Setting it all up now. You said there was an ini line that can be changed to alternate between dinput and raw input?
rastan Posted July 3, 2016 Posted July 3, 2016 man I'm glad I decided to stay with the version of mame I had before all these major updates in the new releases... been hearing nothing but problems.
Metalzoic Posted July 3, 2016 Author Posted July 3, 2016 man I'm glad I decided to stay with the version of mame I had before all these major updates in the new releases... been hearing nothing but problems. Only with 173 & 174. Been testing 175 out and it seems great. If Raw Input works again I can see this being a very solid release. Seems to run great, without the issues (so far) of 173/174, but all of the improvements they add over the previous versions. Feels good man!
Metalzoic Posted July 3, 2016 Author Posted July 3, 2016 to be honest, i am not sure So previous game CFGs work fine. However the "Antialias" lines was removed from the ini in 175 so running a previous INI will cause it to hang on that line behind RocketLauncher. However instead of building all new ini's it was faster to go through the few special ones I have and simply delete that line. Works perfect after that. There is also a new GLSL shader in 175, but it's just 5 variations of a horrid BRZ filter. No idea why they would even add that. The games that were broken in 173 and 174 seem to be fixed (hopefully all of them), the HLSL/GLSL resolution issue still persists with certain games. But this build Jezze fixed the shader file so they can be fixed with custom HLSL settings. That's all for now. Thanks man!
sevenseal Posted July 3, 2016 Posted July 3, 2016 Setting it all up now. You said there was an ini line that can be changed to alternate between dinput and raw input? change the devices providers...keyboardprovider = dinput mouseprovider = rawinput lightgunprovider = win32 joystickprovider = auto those are somewhat the look in mame.ini
Metalzoic Posted July 3, 2016 Author Posted July 3, 2016 change the devices providers... keyboardprovider = dinput mouseprovider = rawinput lightgunprovider = win32 joystickprovider = auto those are somewhat the look in mame.ini Also to let you know Gauntlet Dark Legacy works again, all the broken games from 174 I've tried so far now work again (so it's likely they all do)
sevenseal Posted July 4, 2016 Posted July 4, 2016 Also to let you know Gauntlet Dark Legacy works again, all the broken games from 174 I've tried so far now work again (so it's likely they all do)that is good to hear
Krakerman Posted July 4, 2016 Posted July 4, 2016 Yes confirmed it is working ... just let Dark Legacy run for 1-2 mins to load.
sevenseal Posted July 9, 2016 Posted July 9, 2016 new mameuifx 0.175.1 been uploaded to the download section
Metalzoic Posted July 9, 2016 Author Posted July 9, 2016 These the only differences? - Added shortcut keys to all Menu actions in the Interface - Fixed small bug in Lightgun and Trackball Folders creation in the Interface (As reported at the Forum) - Fixed MAMETESTERS bug ID 06261 (polepos2: Crowd Cheering sounds are messed up) - Included source code from MAME SVN 52265 [Angelo Salese] - Included source code from MAME SVN 52283 [Bryan McPhail] And I'm guessing we can just drop the exe in. No need to replace the entire folder/files?
sevenseal Posted July 9, 2016 Posted July 9, 2016 These the only differences? - Added shortcut keys to all Menu actions in the Interface - Fixed small bug in Lightgun and Trackball Folders creation in the Interface (As reported at the Forum) - Fixed MAMETESTERS bug ID 06261 (polepos2: Crowd Cheering sounds are messed up) - Included source code from MAME SVN 52265 [Angelo Salese] - Included source code from MAME SVN 52283 [Bryan McPhail] And I'm guessing we can just drop the exe in. No need to replace the entire folder/files?yes, replace .exe
