Hypersearch tutorial
Could someone point me in the direction of how to set up hypersearch? I have poked around various threads and tried to piece it together, but to no avail. Thanks everyone!
No, you just have to make sure you have your RL.exe path set in the HyperSearch settings. You can also check the HyperSearchLog.txt file to see what's happening and any errors that are being thrown.
Thank you.  Had to re-download and set up from scratch because it was defaulting to the same path, despite my edits to the config file.  Works great now,  only issue is how it is displayed....the keyboard is kinda smooshed.  What would you suggest to change the deimensions to within the config to display properly?  I have a 1920 x 1080 screen.  Even when i change it to that it still displays all jacked up.  Thanks man!
  • 1 month later...
Is it possible to use Hypersearch without a keyboard?
I have it up and running, but when i highlight a letter on the virtual keyboard, and press enter Hypersearch goes searching instead of typing the letter.
How does this work?
