C_Wilson009 Posted June 10, 2016 Posted June 10, 2016 Hey guys, Im having some trouble getting daphne to work with Hyperspin after moving the files onto another computer. The games DO work outside of hyperspin. I changed the framefile locations to the new directory. Im not sure If maybe something else needs to be done? Anyways, here is the log msg I get: --DAPHNE version 1.0.12--Command line is: C:\Hyperspin\Emulators\Daphne\daphne.exe ace vldp -blank_searches -prefer_samples -noissues -fastboot -opengl -fullscreen -x 1360 -y 768 -homedir . -framefile C:\Hyperspin\Emulators\Daphne\framefile\ace.txt--CPU : GenuineIntel 2950 MHz || Mem : 3008 megs--OS : Windows XP/.NET || Video : NVIDIA GeForce 7150 / NVIDIA nForce 630i--OpenGL: Compiled In--RGB2YUV Function: MMX--Line Blending Function: MMX--Audio Mixing Function: MMXSetting alternate home dir:.Setting screen width to 1360Setting screen height to 768WARNING : You have specified an abnormal screen resolution! Normal screen resolutions are:640 x 480800 x 6001024 x 7681280 x 9601280 x 10241600 x 1200Set 1360x768 at 32 bpp with flags: 80000002Initializing sound system ...GI Sound chip initialized at 2000000 HzNo joysticks detectedRemapping input ...Loading ./roms/ace/sa_a3_u1.bin ... 0 bytes read into memoryROM sa_a3_u1.bin couldn't be found in roms/ace/, or in ./roms/ace.zipCould not load ROM images! You must supply these.Shutting down sound system...Shutting down video display... Please help if you can! Thx!
C_Wilson009 Posted June 10, 2016 Author Posted June 10, 2016 I'm not in front of my main setup at the moment so I can't check my files, but from your log the issue seems to be the path to the rom files. weird that it would work outside of hyperspin though. the framefile points to the audio/video files only right?
Metalzoic Posted June 10, 2016 Posted June 10, 2016 weird that it would work outside of hyperspin though. the framefile points to the audio/video files only right? Daphne can run outside RLauncher completely different than in RLauncher as it doesn't carry your Daphne Loader settings over. So anything you have set in Daphne Loader you also need to set in the RLauncher module if I remember right. So maybe check your emulator path and extensions in Global>emulators>daphne as well as your actual module settings. On the flip side I literally just beat Dragon's Lair for the first time in 23 years about 10 minutes ago on 1 quarter. Next I need to do it on a single life.
C_Wilson009 Posted June 10, 2016 Author Posted June 10, 2016 Daphne can run outside RLauncher completely different than in RLauncher as it doesn't carry your Daphne Loader settings over. So anything you have set in Daphne Loader you also need to set in the RLauncher module if I remember right. So maybe check your emulator path and extensions in Global>emulators>daphne as well as your actual module settings. On the flip side I literally just beat Dragon's Lair for the first time in 23 years about 10 minutes ago on 1 quarter. Next I need to do it on a single life. yay that fixed it! I just copied the module from my other pc. And props to you for beating that game, regardless of how many quarters lol. I still havn't
