AeronNL Posted June 14, 2016 Posted June 14, 2016 Hey guys, I downloaded Gigapig's Hyperspin setup mainly to make use of the preconfigured emulators in that pack. However, when i push the pause button on RetroArch the screen flashes because it is trying to open a window but fails to do that and it keep doing that till i press the pause button again, and i have no solution for that. Lomg story short, i want to download the latest version of RetroArch, and setup the shaders myself, but i really like the way they are setup in Gigapig's version, and i have no idea to achieve the same result. Can anyone help me to set up the shaders? Or can i just copy a file from Gigapig's config to my new setup so it copies just the shader config?
AeronNL Posted June 16, 2016 Author Posted June 16, 2016 Ok so i firgured it out. I downloaded the latest version of RetroArch and copied the config files from Gigapigs setup over to the new version. Everything works!
shitoken Posted June 20, 2016 Posted June 20, 2016 Do we have a complete list of those shaders somewhere for which systems , shaders, etc . so that it will help some users who want to get the same effects, I believe giga shaders taste are good, By copying full config files to my folder I am afraid it might change other setting as well such as input settings,etc.
gigapig Posted June 20, 2016 Posted June 20, 2016 Do we have a complete list of those shaders somewhere for which systems , shaders, etc . so that it will help some users who want to get the same effects, I believe giga shaders taste are good, By copying full config files to my folder I am afraid it might change other setting as well such as input settings,etc. I mainly use crt-geom for that build which is pretty simple to set up. AeronNL, I must apologise to you, you did pm me with you problem and I completely forgot to respond. I'm glad you got it working. An update version of Retroarch will be in the next version.
