style214 Posted June 21, 2016 Posted June 21, 2016 I tried to find a solution on here, but no luck. I am working on getting my system set up, and I ran into a weird issue. I have the SNES emulator set up, but when I go into a game from the wheel, it opens the emulator, but not the game. I am not using any other launcher, and I remember this working before when I set it up. Is this something simple, or do I need to use another program to get it to launch into the game? I am using ZSNES.
gigapig Posted June 21, 2016 Posted June 21, 2016 If your not using HyperLaunch or RocketLauncher then you'll have to wait for someone who can tell you correct command line info. If such a person still exists.
gigapig Posted June 22, 2016 Posted June 22, 2016 So I'm sure you would suggest all the zip be extracted and just use the sfc extension?
Dime333 Posted June 22, 2016 Posted June 22, 2016 If they are all zip files, They should load fine if you set the extension to only zip since ZSNES can load zip files, right?
gigapig Posted June 22, 2016 Posted June 22, 2016 If they are all zip files, They should load fine if you set the extension to only zip since ZSNES can load zip files, right? You are correct, just tried 7z and zip, the zip worked, 7z did not.
style214 Posted June 22, 2016 Author Posted June 22, 2016 Thank you all for the help, i had both zip and 7z in there, took out the 7z, fired right up!
