Sega model 1 arcade board
mihaliousa
  • 10 months later...
I know this post is a bit old but, since it already exists, I wanted to add my 2 cents...
If you use MAME64UI, they all work. Each may give you a nag screen that it's not 100% working in some way but you should be able to play them fine, otherwise.
I created a new Emulator in Rocket Launcher called MAMEUI, gave it the path to the EXE, and used the MAME.AHK script.
Hope this helps someone :)
EDIT: I just noticed this was posted in the Android section of the forum. I don't know if it works there but it does work for me now in Windows.
8 hours ago, Pouteur said:
Hi, for cps1 wheel i use fbalpha cores on retroarch and it works great.
Hi Pouteur!
Capcom Play System 1 (CPS1) is not the same as Sega Model 1. :) Sega model 1 wasn't a higely used technology and was quickly replaced by Sega Model 2.
SM1 has the following games associated with it:
swa           Star Wars Arcade
vf               Virtua Fighter
vformula   Virtua Formula
vr               Virtua Racing
wingwar   Wing War (World)
wingwarj  Wing War (Japan)
wingwaru Wing War (US)
Basically, a few Sega 32x games.
Cheers!
Oups  sorry i read cps1 instead of Sega model 1
My mistake !
I have star wars arcade working with mame4droid.
I have testing virtua fighter and virtua racing but unfortunatly they doesn't worked.
