baezl Posted June 30, 2016 Posted June 30, 2016 Just curious if this is limited to shield? Ive installed it on a mojo, but the navigation is not normal, it does work etc but is there a way to remap controls? Thanks Luis
reznnate Posted June 30, 2016 Posted June 30, 2016 The mojo used a tegra4 chip and should have the necessary gpu driver extensions. If you have root, Android has .kl files that might allow you to remap your controller. Otherwise, I'd try a usb XB360 controller (if you have one of those).
rob3d Posted June 30, 2016 Posted June 30, 2016 The mojo used a tegra4 chip and should have the necessary gpu driver extensions. If you have root, Android has .kl files that might allow you to remap your controller. Otherwise, I'd try a usb XB360 controller (if you have one of those). If you use the app gamekeyboard+ it allows you to remap hardware controls without root. I use this in Ducktales remastered to swap jump buttons and it works great. You can save profiles for different games and load them as needed.
spakkiuso Posted November 12, 2016 Posted November 12, 2016 Hellooo, How did you install hyperspin on the mojo? Hyperspin runs on android 4.4 and my mojo has android 4.2 and no update available.
