I need help with ipac
hanzoo
Hi,I need help how to setup my ipac
I have got my second ipac,my first ipac somehow didnt work after I setup winpac program,so ı got it replaced with a new one
I cant figure out ,If there are any videos
Thank you
What exactly are you trying to figure out?
Here's a link to the instructions, FAQ etc...
http://www.ultimarc.com/ipac2.html
You hook it up to all your buttons, then program what keys those buttons correspond to using winipac. That's pretty much it.
It's scary that you have a scream mask and two pandas in that room.
Hi Metalzoic,you have good eyes sir,
I am afraid to use winipac ,last time i used my ipac didnt work,so i got replaced with new one.
I need help with how to configure with the hyperspin wheel .When i watch youtube videos it shows how to setup with hyperlauncher.
Is there a video shows how to do exactly.
And do i have to configure all the emulators also
Thanks
Just go into HyperHQ and select the keyboard tab and then set up what buttons you want to control Hyperspin. Dont mess with the joystick tab. As far as the emulators you will have to set up each one but its pretty easy the only one that will be a pain is Retroarch. When I setup my Ipac4 I had to go in and manually set each up cause the bindings option didnt work.
Hi Mikea213
I tried to do what you had told me ,but somehow my wheel spins so fast ,
what i am doing wrong?it has been 2 years now i still couldnt figure this out sir?
is there any videos on youtube?
thnaks regards
Hi Mikea213
thnaks regards
If it spins to fast then you probably just have Joysticks, Trackball and/or Spinners enabled in HyperHQ and you shouldn't. Make sure they are all disabled.
I wouldn't worry about using Winipac, it's designed specifically to set up the iPac. The iPac should have come with it set to MAME controls, but if you want to use any emulators or PC games besides MAME you'll probably find you need to change the buttons
And your pictures are all upside down.
Thank you for the reply,
I am out of town when i come back home i will give it a try,
Sorry for the pictures,i didnt know what was the problem
