hlsl scan lines. Can't find any solid info on it! frustrating
irthwirm
I've search everywhere, youtube, forurms and there is no how to steps. Just the hlsl code you put in the meme.ini file which i've done with no results. Is there a program that does this for you. I'm using mameplus64 to create the mame.ini file. That's the only way I can seem to find a mame.ini file. It's in the root folder of the mameplus64. That's where mamepUI puts it. I have to be missing a step but again there is no solid walk throughs that I can find which is amazing to me since this a huge factor in improving the quality of a LCD screen emulation. Please help. Also can you apply these same affects to hyperspin or only the png images? Just to be consistent.
this is the code I'm trying to use
# DIRECT3D POST-PROCESSING OPTIONS
hlsl_enable 1
hlslpath hlsl
hlsl_ini_read 0
hlsl_ini_write 0
hlslini %g
hlsl_prescale_x 0
hlsl_prescale_y 0
hlsl_preset -1
hlsl_write
hlsl_snap_width 1366
hlsl_snap_height 768
shadow_mask_alpha 0.15
shadow_mask_x_count 1280
shadow_mask_y_count 720
shadow_mask_usize 0.09375
shadow_mask_vsize 0.09375
curvature 0.0
pincushion 0.0
scanline_alpha 1.00
scanline_size 1.00
scanline_height 0.7
scanline_bright_scale 1.5
scanline_bright_offset 0.60
scanline_jitter 0.05
defocus 0.8,0.8
converge_x 0.0,0.0,0.0
converge_y 0.0,0.0,0.0
radial_converge_x 0.0,0.0,0.0
radial_converge_y 0.0,0.0,0.0
red_ratio 1.0,0.0,0.0
grn_ratio 0.0,1.0,0.0
blu_ratio 0.0,0.0,1.0
saturation 1.3
offset 0.0,0.0,0.0
scale 1.0,1.0,1.0
power 1.0,1.0,1.0
floor 0.03,0.03,0.03
phosphor_life 0.0,0.0,0.0
yiq_enable 0
yiq_cc 3.59754545
yiq_a 0.5
yiq_b 0.5
yiq_o 0.0
yiq_p 1.0
yiq_n 1.0
yiq_y 3.0
yiq_i 1.2
yiq_q 0.6
yiq_scan_time 52.6
yiq_phase_count 2
Some explanation http://gamingnos.blogspot.it/2011/10/quick-start-mame-hlsl-filter-guide-up.html
As far as I can remember mameplus does have a bug with hlsl, try to use mame UI or mame FX. Anyway the only reason to use mameplus is image filtering, not useful when using HLSL
Okay, it looked like I had to have Directx installed and then the hlsl code I put in the mame.ini worked. Super laggy so I'm going to try some other stuff. But the DirextX install is key. Not really mentioned anywhere. I just heard a couple of people vaguely mention it. But seems to be a key step.
I found these new settings online and they look freaking awesome. Except Mame becomes completely unplayable. Anyone have any insight? I have a i5 2500 at 3.3 ghz, 4 gigs of ram. I'm running off the onboard Graphics card. Not sure if that's the problem but from what I heard mame doesn't use the graphics card. Not sure if utilizing hlsl might change that though and I might have to get myself a graphics card or it's just metalling with some other settings.
Here are the settings for you mame.ini
hlsl_enable 1
hlslini hlsl
hlslpath hlsl
hlsl_prescale_x 0
hlsl_prescale_y 0
hlsl_preset -1
hlsl_snap_width 1920
hlsl_snap_height 1200
shadow_mask_alpha 0.100000
shadow_mask_x_count 320
shadow_mask_y_count 240
shadow_mask_usize 0.093750
shadow_mask_vsize 0.093750
curvature 0.050000
curvature 0.050000
pincushion 0.050000
scanline_alpha 0.600000
scanline_size 1.000000
scanline_height 0.700000
scanline_bright_scale 1.500000
scanline_bright_offset 0.600000
scanline_jitter 0.000000
defocus 1.500000,1.500000
converge_x 0.000000,0.000000,0.000000
converge_y 0.000000,0.000000,0.000000
radial_converge_x 0.000000,0.000000,0.000000
radial_converge_y 0.000000,0.000000,0.000000
red_ratio 1.000000,0.000000,0.000000
grn_ratio 0.000000,1.000000,0.000000
blu_ratio 0.000000,0.000000,1.000000
saturation 1.050000
offset 0.000000,0.000000,0.000000
scale 1.000000,1.000000,1.000000
power 2.200000,2.200000,2.200000
floor 0.020000,0.020000,0.020000
phosphor_life 0.200000,0.200000,0.200000
yiq_enable 0
yiq_cc 3.597545
yiq_a 0.500000
yiq_b 0.500000
yiq_o 0.000000
yiq_p 1.000000
yiq_n 1.000000
yiq_y 6.000000
yiq_i 1.200000
yiq_q 0.600000
yiq_scan_time 52.599998
yiq_phase_count 2
HLSL is the only mame feature to use videocard, actually hlsl is a videocard's shader. Intel's IGP can be a problem, it sucks in terms of features support and drivers. With my htpc i could not use HLSL before upgrading videocard from x1550 to 9800gtx
Also consider this:
hlsl_prescale_x 0
hlsl_prescale_y 0
yiq_enable 0
These are really "demanding" settings. Yiq is an overkill, dont' use it. Prescale on Y and X improves graphic but it can kill performance.
If you use "shadow_mask" consider this to avoid "moire" effect.
This must fit your screen resolution
This must fit the original resolution of the game you're running (yes, hlsl setting should be game-dependant).
