Moved hyperspin to a different drive, now won't run
Martin0037
Hi all. I set hyperspin up on an external drive (D). Everything fine. Just has mame on it.
Moved it to the © drive on the same computer as it will fit on (and I didn't think it would at first) so no need for external drive.
I've changed everything as far as I know. All settings in hyper hq, rocket launcher, directories in mame, been through as many files as I can see and changed directories from D to C, All I get now when I try to run a game is -
Fatal error. Required files are missing. Games run fine in mame alone though
I'm stumped.
I dont know if this will help you but check your hyperspin settings.ini......i had almost the same problem and my RL path wasn't correct
I'm lovin my arcade
Sounds like a windows error, very rare to see fatal errors. Are you sure it's a RL or Hyperspin error? Has your computer got the latest netframework on it?
The Hyperspin setting.ini is in \Hyperspin\settings folder.
If your unsure about the error post screen shots and RL/HS logs
Sorted. Never even noticed but in the hyowrspin\settings. In the ini folder is changed everything from D to C but not put the : after the C. Unbelievable.
Thanks guys.
Glad you fixed it, I am about to move my email from c to an external hard drive. I will keep my eyes open for that.
