danwelsh Posted July 20, 2016 Posted July 20, 2016 I'm having trouble getting some TTX games to run in HS....specifically King of fighters 98, kof xii and xiii......the games run fine outside of HS and also run fine in RL when I set them up with the fade and paths....what it looks like is the game starts to load then just goes right back to the main menu. Anybody run into this issue and a fix for it? I'm lovin my arcade
Metalzoic Posted July 20, 2016 Posted July 20, 2016 Is it running in the background or not even launching at all?
danwelsh Posted July 20, 2016 Author Posted July 20, 2016 Is it running in the background or not even launching at all? Well it looks like it starts up because for a split second I can see insert coin on the bottom, totally forgot to check if it's running in the background..... I will when I get home, if it is what do I do to fix that? I'm lovin my arcade
Metalzoic Posted July 20, 2016 Posted July 20, 2016 It could simply mean that it is running, but for some reason HS (or another program) is stealing focus back from it.
danwelsh Posted July 20, 2016 Author Posted July 20, 2016 Yes they are running in the background....not sure how to fix this, when I push alt+tab they work....except for kof98, that doesn't. I'm lovin my arcade
Guest Posted July 20, 2016 Posted July 20, 2016 Yes they are running in the background....not sure how to fix this, when I push alt+tab they work....except for kof98, that doesn't. You need to set the fade title setting for that game in the PC launcher module settings in RL. Sent from my iPhone using Tapatalk
danwelsh Posted July 20, 2016 Author Posted July 20, 2016 I have the fade title set....I followed gigapigs guide and got all the fade titles from his youtube channel I'm lovin my arcade
ninja2bceen Posted July 21, 2016 Posted July 21, 2016 Yes fade is stuck on top in Windows 10. All this worked in Windows 7 but could be a rl update as well Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
ninja2bceen Posted July 21, 2016 Posted July 21, 2016 taito type x no longer launches through hyperspin https://r.tapatalk.com/shareLink?url=http%3A%2F%2Fwww%2Erlauncher%2Ecom%2Fforum%2Fshowthread%2Ephp%3Ft%3D3665&share_tid=3665&share_fid=108523&share_type=t Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
danwelsh Posted July 21, 2016 Author Posted July 21, 2016 Thanks ninja2bceen, I'll try turning fade in off when I get off work and see what happens I'm lovin my arcade
Guest Posted July 21, 2016 Posted July 21, 2016 Most of these games launch fullscreen anyway and change the resolution - for the best experience you really don't want fade on in these instances.
danwelsh Posted July 21, 2016 Author Posted July 21, 2016 Most of these games launch fullscreen anyway and change the resolution - for the best experience you really don't want fade on in these instances. Okay tonesmalone..... So do I turn fade in and fade oout off in the general settings of fade for TTX? I'm lovin my arcade
Guest Posted July 21, 2016 Posted July 21, 2016 Okay tonesmalone..... So do I turn fade in and fade oout off in the general settings of fade for TTX? Exactly - that way it will only turn off for TTX system and not the others. I've managed to get a couple of TTX games working with fade, but honestly - the best experience is to just turn off fade for theses PC arcade based systems like Arcade PC and TTX
danwelsh Posted July 21, 2016 Author Posted July 21, 2016 Exactly - that way it will only turn off for TTX system and not the others. I've managed to get a couple of TTX games working with fade, but honestly - the best experience is to just turn off fade for theses PC arcade based systems like Arcade PC and TTX Okay, awesome. Thank you very much I'm lovin my arcade
Guest Posted July 21, 2016 Posted July 21, 2016 Okay, awesome. Thank you very much Give it a test and let us know. Also, it's really important to remember to test these games outside of HS/RL first.
danwelsh Posted July 21, 2016 Author Posted July 21, 2016 Give it a test and let us know. Also, it's really important to remember to test these games outside of HS/RL first. All the games for TTX I have in my xml are games that run fine outside of HS and RL.....it's the first thing I do before trying to configure them in RL, these even run fine when launching with the rocket in the setup section of RL, it's just when I try to run them in HS that some do not work properly I'm lovin my arcade
Guest Posted July 21, 2016 Posted July 21, 2016 All the games for TTX I have in my xml are games that run fine outside of HS and RL.....it's the first thing I do before trying to configure them in RL, these even run fine when launching with the rocket in the setup section of RL, it's just when I try to run them in HS that some do not work properly Good call.
ninja2bceen Posted July 21, 2016 Posted July 21, 2016 Well what's weird is in Windows 7 all these were fine with fade in and out. Moving to Windows 10 I tested everything and yes I had to remove fade in and out for this wheel for things to work I have four games that still don't run though. If you have Windows 10 and those games running in the link above please pm me Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
danwelsh Posted July 21, 2016 Author Posted July 21, 2016 Well what's weird is in Windows 7 all these were fine with fade in and out. Moving to Windows 10 I tested everything and yes I had to remove fade in and out for this wheel for things to work I have four games that still don't run though. If you have Windows 10 and those games running in the link above please pm me I went to Windows 10 last night just for shits and giggles to see if things would be better than 8.1 and I'll be reverting back after work tonight, I found my HS is slower, more games don't work and the OS in general just seems slower to me.....and it's not the components causing it either, I have 8gb of ddr3 1600 RAM, an r7 260x 2gb ddr5 GPU and an AMD fx6300 CPU on my board I'm lovin my arcade
ninja2bceen Posted July 21, 2016 Posted July 21, 2016 You have to put hyperspin in compatibility mode and it will be fine. I noticed the same thing where the video stuttered in hyperspin but once I moved to compatibility mode it's fine. I tested 96 systems, they all work great. The four games mentioned in the link I'm having trouble with but others say they will work. We will all have to convert to Windows 10 eventually I think with the business model that they are approaching unfortunately but Windows 10 really isn't all that bad Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
danwelsh Posted July 21, 2016 Author Posted July 21, 2016 That's odd. I went from 8.1 to 10 as well and I think everything runs much better on 10, most people I've talked to agree. I know Defender can really slow stuff down, the first thing I did was disable it. Well ya know what I kinda forgot about Windows defender.... I assumed it would port my settings from 8.1 but it must not have. I'll check it out before going back. I'm lovin my arcade
Metalzoic Posted July 21, 2016 Posted July 21, 2016 That's odd. I went from 8.1 to 10 as well and I think everything runs much better on 10, most people I've talked to agree. I know Defender can really slow stuff down, the first thing I did was disable it. Same. Everything runs noticeably better and I leave Defender on as it's my only AV. I also run all the TTX games with Fade on in Win 10 and they work. So maybe it isn't specifically a Win 10 thing, but a windows setting or something else.
ninja2bceen Posted July 21, 2016 Posted July 21, 2016 It doesn't. I had to reinstall a PS3 dedicated blue tooth sub and reconnect my PS3 synced controllers. There are bits were it guts and you have to reinstall that's why I checked all the wheels and turned out really good in general Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
danwelsh Posted July 21, 2016 Author Posted July 21, 2016 You have to put hyperspin in compatibility mode and it will be fine. I noticed the same thing where the video stuttered in hyperspin but once I moved to compatibility mode it's fine. I tested 96 systems, they all work great. The four games mentioned in the link I'm having trouble with but others say they will work. We will all have to convert to Windows 10 eventually I think with the business model that they are approaching unfortunately but Windows 10 really isn't all that bad I really don't mind switching especially since it's free for 8 more days but I do mind when it screws my HS up.....I've put wayyy too many hours into my cab over the last year to go backwards because of an OS that's all as I'm sure many of you guys have put oodles of time in as well I'm lovin my arcade
Metalzoic Posted July 21, 2016 Posted July 21, 2016 Weird that it would give you so many issues when it doesn't to most. Now the RocketLauncher update a while back, that made almost everything on my cab quit working. Sent from my SM-G935V
