Taito type x issue
danwelsh
Weird that it would give you so many issues when it doesn't to most.
Now the RocketLauncher update a while back, that made almost everything on my cab quit working.
Sent from my SM-G935V
Oh well.....I'll just stick with it I guess and add another bunch of hours fixing stuff haha
I'm lovin my arcade
  • Replies 55
That's odd. I went from 8.1 to 10 as well and I think everything runs much better on 10, most people I've talked to agree. I know Defender can really slow stuff down, the first thing I did was disable it.
Agent is spot on here - that isn't right.  With those components Win10 should actually have been better.  It's a much better OS than 8 for many reasons.
and just to confirm - you should not be putting HS in compatibility mode or run as admin on Win10 - this isn't needed at all.  And in fact can cause problems.
Well idk, maybe it is just defender screwing it up, if it didn't port my settings as ninja2bceen says it doesn't then my exceptions aren't there in 10
I'm lovin my arcade
I really don't think it's that either - what do you think you might need to except in Defender?
Well I had exceptions for HS, HM, EDS and RL on the old OS
I'm lovin my arcade
Well I had exceptions for HS, HM and RL on the old OS
Does Defender pick those apps up as viruses for you?  They shouldn't need to be excepted.
My defender is off in general and hyperspin is an exception and my videos stuttered in hyperspin until I moved hyperspin to Windows 7 compatibility. How am I suppose to fix that if I'm not suppose to do that?
Good question!  Compatibility mode shouldn't really be a problem - if that works for you then keep it as that.  'Run as admin' though is a different story and that should never be needed for HS - and will cause major problems.
As for Windows Defender - creating exceptions in there again shouldn't be needed - but it's not a major issue.  I just wanted to post, so that people don't think these things are default requirements for HS.  Somethings though, people will have to do different things based on their system.
Hypermarquee and EDS would not work without those excepted
I'm lovin my arcade
Interesting.  Whatever works I guess!
Yup.....sevenseal and I did a TV session and defender was screwing it up
I'm lovin my arcade
I keep everything in my HS and RL root folders excepted. And yes going to Win 10 I had to make them exceptions all over again.
Okay....so after about 4 hours since i'm stubborn i finally have a solution instead of hitting alt-tab to get in to kof 98, xii and xiii.....I turned off fade in and out...didn't work but I got to thinking why not try a script or a program that hits alt-tab, I tried some scripts, didn't work or at least I couldn't get it to work.....so I found a program called vistaswitcher that does what I need it to do...I run it at postlaunch on the game setup for each one :)....after a shitty day at work that kind of fixed my day too.
I'm lovin my arcade
That update wasn't installed on my windows 10.....or it wasn't showing it as installed anyways
I'm lovin my arcade
the only issues i have is deamon bride and saggio produce this error which tryng to launch the game. Does anyone know how to get around that. it seems that the monitor dll file is failing? This has been tested working in windows 7
also note that Chaos breaker works perfectly outside of RL however within RL it will speed up to like 300%
Maybe you guys just need to re-run your TTX games back through the Arcade PCLoader to "reset" the options the games launch with.
I doubt it could be the bat file you use to launch the games as that's just a couple words, but hell... it would only take a minute to re-do those as well.
Remind me how I would reset it? I asked iggy for his two games that were working in Windows 7 and got the same error as above with mine and his
Also note chaos breaker is super fast only through rl but not outside of it. It's either fast or crazy zoomed in within rl
I would just reset them up like I was doing it from scratch.
-Open Arcade PC Loader
-Pick the game you're setting up
-Select all your options which creates the Title_Launcher.exe with those settings built into it (for example Chaos Breaker would give you CB_Launcher.exe).
-Then either set that as your .exe in the PCLauncher module, or make a bat file that launches that exe.
-Either way for most games you set your AppWaitExe setting in the module to "game.exe" so they don't lose focus and get put in the background. (Some games are different for example Half-Life is HL2.exe)
-Some games work fine with ESC as the exit option, some prefer you set Alt-F4 as the exit option (TW, SSED).
That's it (and remember in Chaos Breaker changing your country in the settings changes your Main Character between the warrior or the barbarian).
I just checked mine again and they're all working solid.
However I also remembered that I reverted my RLauncher to the version prior to 4/19/216 because the RL updates since then had so many issues and caused problems with so many systems.
It's possible it is RocketLauncher itself giving you guys problems.
