Jukebox Module Request
ci2own
I found this great Jukebox Emulator and would like to know if is possible to make a working module or adapt an already done one.
This is the homepage if someone wants to try it (I think it's free.):
http://www.arcademy.fr/retro-jukebox.html
P.D: How can i add images here? It says png, jpg, not supported.
Thanks in advance!
Thanks in advance!
if its a pc program and has a .exe file i assume it could be launched like any other pc program and as for the pics i dont know how to link them not done it in a while I just add my pictures as attachments hopefully that helps mate
I tried to load with PC Launcher module but as it's not on Database i can't point to the exe.
I added from executable in HyperHQ and doesn't work either. I'll keep trying. As soon as i can run it i will explain :D
Finally I did it adding with HyperHQ with no sub-wheels. Searching for executable and no RocketLauncher Launch Support.
Thanks!
Add it without a sub wheel, launch as an application not hyperlaunch and point hyperhq at it. You should be good to go.
If you are using the PC launcher you need to add it to the PC launcher ini file. You can do it manually or ad it via rocketlauncherui
Yes i did it with HyperHQ. Thanks!
