Hyperspin 1.4 exits immediately after starting
dtrigo917
I have a clean install of hyperspin 1.4 - here's what's happening.  I run Hyperspin, the wheel appears (but no graphics to the left) and then it shuts down.  Wheel appears for about 1 second.  If I catch it just right, I can spin the wheel, but as soon as I stop, it exits.  Here's the log ...
08:40:26 AM |  HyperSpin Started
08:40:26 AM |  Going FullScreen
08:40:26 AM |  Checking for updates
08:40:26 AM |  Update Check Complete
08:40:26 AM |  Startup program unavailable
08:40:26 AM |  Playing intro video
08:40:27 AM |  Error intializing joysticks
08:40:27 AM |  Menu Mode is multi
08:40:27 AM |  Loading Main Menu.xml
08:40:27 AM |  Main Menu.xml successfully loaded
08:40:28 AM |  Main Menu wheel loaded successfully
thanks - the exclusion didn't work, and the media is present.
Another thing I should mention, it works fine with HS 1.3.3, but going to 1.4 broke it.  If I go back to HS 1.3, I suffer from the unable-to-use-RocketLauncher bug, so that's not an option for me.
yes on both - I think it has something to do with HS playing the videos.  I just noticed that my default player, "Movies and TV", can't play these, but Windows Media Player can.
Do you know what HS uses to play the .mp4 videos?
yes, they played just fine under 1.3.3, but not under 1.4.  If I revert back to the 1.3 exe, it works fine.  Something changed going to 1.4.
