sevenseal Posted July 30, 2016 Posted July 30, 2016 File Name: Mame 64bit + NoNag 0.176 File Submitter: sevenseal File Submitted: 29 Jul 2016 File Category: Other Credits: sevenseal no nag patch only 0.176------- MAMETesters Bugs Fixed----------------------- 06288: [interface] UI:: Selecting "Category" after listing "Favorites"causes exception (Vas Crabb)- 06291: [interface] (carpolo.c) carpolo: Unable to view recorded video madewith -video bgfx/-window (Jezze)- 06286: [Misc.] (segaorun.c) shangon: Captured AVI video from this game showsonly sound, no image (Angelo Salese)- 06263: [interface] UI: Choosing any filter which has no data makes the UIunrecoverable (Maurizio Petrarota)- 06280: [interface] PLUGINS: The plugin.ini file is created in the current folderwhen it should be created in the "ini" path. (crazyc)- 06279: [interface] PLUGINS: pluginspath does not resolve $HOME (crazyc)- 06285: [Gameplay] (vendetta.c) esckids, esckidsj: Slowdowns in gameplay (Osso)- 06284: [interface] Watchdog dialog is not able to be captured (cuavas)- 06246: [Graphics] (legionna.c) cupsocsb, cupsocsb2: Black screen (Angelo Salese)- 06268: [Crash/Freeze] MAME can crash when switching languages (Vas Crabb)- 06266: [DIP/Input] (seta.c) metafox: Bonus_Life DIPSETTING values and labels are incorrect (Tafoid)- 06262: [Crash/Freeze] All sets using SHARC drc: Crash when running DRC (Linux only?) (Ville Linde)- 06305: [Crash/Freeze] (atpci.c) at586, at586x3, ficvt503: Use of -kbd slot options3270pc or pcat causes crash (crazyc)- 06304: [Crash/Freeze] (mac.c) macse30: Crash when attempting to use any slot option for -pds030 (Osso)- 06309: [Crash/Freeze] (mac.c) macsefd: Crash on Exit using -pds slot (Osso)- 05534: [Crash/Freeze] (pc8001.c) All sets in pc8001.c: Crash after OK (Robbbert)- 06324: [Crash/Freeze] (funkball.c) funkball: Fatal Error at Start (Osso)- 06323: [Debugger] (psikyosh.c) gunbird2, s1945iii: Crash when attempting to use -cheat (AJR)- 06313: [Crash/Freeze] (victor9k.c) Crash when using -fdc:5d:0 and -fdc:5d:1 slot with '525ssqd' option (Pernod)- 06312: [Crash/Freeze] (osborne1.c) Crash when using -mb8877:0 and -mb8877:1 slot with '525sssd' option (Pernod)- 06311: [Crash/Freeze] (myb3k.c) Crash when using -fdc:0 and -fdc:1 slot with '525sssd' option (Pernod)- 06281: [Crash/Freeze] astrocde [280zzap]: 280Zzzap/Dodgem Cartridge Resets (Duke) Source Changes---------------Scorpion4 7segment displays mostly fixed [John Parker] -Fixed coinage in Touchmaster 2000-8000 [MASH] -z80scc: fix dropped character problem for sun4_75, and fix edge caseswhere datasheet recommendations are ignored allowing sun3/sun4 torecognise keyboard and hk68v10 to work with correct SCC clock[Joakim Larsson Edstrom] -pc9801: fixed mouse buttons [rzero9] -coco3 improvements: [milliluk]* improve palettes and support alternate composite mode* GIME fix for scanlines in legacy graphic modes -m6809: Improve debugging support for 6809/6309 cpus [milliluk] -GNU/kFreeBSD support [stevenc99] -Add arch defines for Linux alpha and mips64el. [Jordi Mallach] -Take pkg-config path from env if defined [bernhard Frauendienst] -Name Neo-Geo AES, NeoGeo CD and FM Towns Marty buttons [shideravan] -Updated *nix man pages. [Cesare Falco] -poisk1: unbreak after "Memory fun", add B623 sound card (skeleton) [shattered] -r9751: Add save state support, document progress and clean up, add PROMversion 4.2 [brandon Munger] -ym2151, ym2413: Isolate, objectify, integrate [O. Galibert] -add Net-DIMM 3.03 firmware [letoram, gamerfan, Mark F., Smitdogg, The Dumping Union] -Netlist improvements: [Couriersud]* nltool now accepts -Ddefine=value to pass on to netlists* improved option handling and added "dummy" options to add groupingand examples in help output.* improved --cmd=listdevices output* Fix dynamic timestepping. This will work with breakout using realcapacitor modelling instead of delay devices. Really slow, butvery useful to calibrate timings.* Fix an awful bug in timing for delay devices.* Switched to clang 3.8 and made code compile with aggressive warnings.This exposed serious issues with implicit constructors.* Removed trampolines (OUTLOGIC, INPLOGIC and friends).* Started using doxygen comment and documentation style. Addeddoxygen files to documentation folder.* Refactored code triggered by doxygen output.* Moved internal and support classes into namespace detail.* Use an unordered map in parser.* Added iterators to pstring.* Moved two macros, added more RAII and improved exceptions. Fixedsome bugs in parser code.* Fixed a number of bugs in parser code and exception handling. -Forte Card: Switched the ver 110 (spanish) to parent set since it's anewer version. Also cleaned up the driver. [Roberto Fresca] -Render module improvements: [Giuseppe Gorgoglione]* Direct3D HLSL: use aviwrite to record AVI movies* Cleanup patches for Direct3D renderer* BGFX: fix crash when bgfx effect folder is not present -Fixed priority issues in Legionnaire, Heated Barrel, Denjin Makai andGodzilla [Angelo Salese] -opwolf.cpp: fix all the gameplay problems by improving the c-chipprotection simulation [bryan McPhail] -Miscellaneous modernisation: [Nathan Woods]* File create and format refactoring, better name/path validation(with POSIX implementation from Vas Crabb)* Use string objects in in core_file static functions, menu items,strconv functions, image device extensions and softlist classes* Consolide default implementation of create_option_guide()* Filesel cleanup* Migrate softlist code from simple_list to std::list -Added crt-geom and crt-geom-deluxe shaders for bgfx including severalaperture grille/shadow mask patterns (designed for RGB subpixel order)[cgwg] -Added option hide ROMless machines from the availables list.[Maurizio Petrarota] -sun4 updates:* Added SPARCStation 1+, 4/110, and 4/4x0 ROMs [Al Kossow]* SPARC CPU core fixes [Ryan Holtz, Vas Crabb]* Preliminary counter/timer support [R. Belmont]* Separated sun4 and sun4c, started implementing unique original sun4features. [R. Belmont]* Support both 8 and 16 context variants of sun4c arch [R. Belmont]* Improved original sun4 architecture support [R. Belmont]* Initial FDC hookup [Ryan Holtz]* Improved timers, logging - sun4_40 runs FORTH programs at okprompt [Ryan Holtz] -Add high-level emulation of Sun type 3/4/5/6 keyboards [Vas Crabb]* U.S.A, Great Britain, Sweden and Japan layouts for Type 5* Layout selection settings for Type 4 and Type 5* Identification selection for type 4* Adaptor for connecting to RS-232 port representing level translator* Hook up to sun3, sun4 and sun4c -zeroteam: improve sprite/sprite priorities [AJR] -feversoc.cpp: Hook up EEPROM; remap buttons, hook up lamps and serial RTC [AJR] -denjinmk: hack sound comms to work without ROM patch [AJR] -vt100.cpp: Add the older vt102/vt131 romset to the vt131 driver asanother bios set [Lord Nightmare, Al Kossow] -Corrected many Mahjong dip switches and settings [system11]* Fixes for: Mahjong Focus, Nozokimeguri Mahjong Peep Show,Mahjong Fantasic Love & Ojousan* Various Video System Mahjong dip switches -Final enhancements to HP TACO driver [fulivi] -Further IRQ passthrough cleanup [AJR]* Remove irq_line methods from M6502, M6800, M6809, S2600 and replaceuses with DEVCB_INPUTLINE* Remove a few IRQ passthroughs from spiders.cpp* Add several aliases for M6800_IRQ_LINE -Increase uismall.bdf coverage: [Vas Crabb]* Complete coverage of Latin Extended-A, most of Latin Extended-B* Monotonic Greek* Full ISO-8859-5 Cyrillic, many other Cyrillic characters* Half-width katakana* Some IPA Extensions -UI refactoring: [Vas Crabb]* Move most main launch menu stuff out of the base menu class* Move some common code from selgame and selsoft into selmenu* Eliminate the troublesome static members in ui::menu* Eliminate some function statics* Move palette menu drawing code out of base into palette menu class* Use std::bind, references where nullptr is unacceptable, and constwhere appropriate* Improve encapsulation of class members* Reduce repeated string allocation in audit code* Don't play so fast and loose with integer types* Eliminate some expensive deep copies of vectors/maps* .h -> .ipp for things that aren't really headers* Remove members that have lifecycle associated with operation -DPS1: system boots up, working [Robbbert] -bankdev: pass through the debugger flag from the incoming spaceargument [R. Belmont] -Apollo changes: [Hans Ostermeyer]* Keyboard mapping adjusted to fit current MAME* Fixed screen raw parameters* Fixed disp.dex Test 20 (Video SYNC Gen. Add. Test) for colordisplays -3c505: The Ethernet frame check sequence is now appended to transmitdata [Hans Ostermeyer] -input_common: fixed 0.172 regression for non-US keyboards[Hans Ostermeyer] -fix item hilighting in debugger state view when scrolling [Vas Crabb] -Introduce validity checks for RGB utilities and fix bugs uncovered [Vas Crabb]* Fix rgbvmx on Linux ppc64 and ppc64le targets with GCC 5* Added several missing functions to rgbgen* Fixed logical shift right in rgbgen* Fixed sra that should be sra_imm in rdptpipe* Added some simple SSE4.1 optimisations in rgbsse* Re-organised rgbsse, rgbvmx and rgbgen to be in more logical order* Fixed return type on some modifying operators* Made some more reference parameters const* Removed inline qualifier from a number of methods as it's impliedwhen body is present at declaration* Mark some constructors explicit -null_modem: rtscts flow control + relevant fix to i8251 [shattered] -Updated driver with new information related to ID and gamelist fortourvis.cpp [system11, Tafoid] -Fix archimedes disk format [O. Galibert] -apple2: don't allow debugger to trigger slot switching [Peter Ferrie] -tiamc1: Kot-Rybolov implemented sound, documentation updates [MetalliC] -Tia-MC1 driver: Added support for KR580VV55A parallel peripheralinterface (clone of i8255), added technical notes about some oddbehaviour with some ports, listed the specs of Kot-Rybolov hardware,and added all clocks via #define. [Roberto Fresca] -amstrad: fix undocumented mode 3. [barry Rodewald] -bbc: added monitor configuration (Colour, B&W, Green, Amber) andpreliminary slots for expansion [Nigel Barnes] -Flaming 7's, original custom hardware improvement: [Roberto Fresca]* Reverse-engineer protection to bypass the requested serial number.The iButton device still needs to be hooked. Promoted these games toworking with their correspondent flags.* Added tech notes, comments and instructions to boot the machine forfirst time. -Flaming 7's, Taiwanese hardware: Reverse-engineer protection to bypassthe requested serial number. The iButton device still needs to behooked. Promoted the game to working with its correspondent flags.Added technical notes. [Roberto Fresca] -hiscore.dat: Updates [Leezer] -alto2: Hunting the jiggly cursor bug [Juergen Buchmueller] -chihiro: added 837-13551 jvs input device, completed the communicationwith jvs devices through usb [samuele Zannoli] -chihiro: game crtaxihr "Crazy Taxi High Roller (Rev B)" boots too [samuele Zannoli] Translations added or modified------------------------------Chinese (simplified/traditional) [YuiFAN]Greek [braiNKilleRGR]Japanese [Vas Crabb]Portuguese (Brazil) [Ashura-X] New machines added or promoted from NOT_WORKING status------------------------------------------------------Swing Gal [bET] [system11]Player's Choice (M4C1) [blair Quinney, The Dumping Union]Gorodki [shiru8bit, IgorR76, '15kop' arcade museum]Kot Rybolov [MetalliC, shiru8bit, IgorR76, '15kop' arcade museum]Flaming 7 (Custom Hardware, Main, 50 Bonus) [Roberto Fresca]Flaming 7 (Custom Hardware, Main, 500 Bonus) [Roberto Fresca]Flaming 7 (Custom Hardware, Main, 2000 Bonus) [Roberto Fresca]Flaming 7 (Custom Hardware, Egyptian Gold, 2000 Bonus) [Roberto Fresca]Flaming 7 (Taiwanese Hardware, unknown version) [Roberto Fresca]TeleVideo 990 [R. Belmont, Al Kossow, Carl]TeleVideo 995-65 [R. Belmont, Al Kossow, Carl]Rainbow-100B [bavarese]MBC200 [Robbbert] New clones added or promoted from NOT_WORKING status----------------------------------------------------Beastie Feastie (Epos Tristar 9000 hardware) [The Iron Goat]Raiden Fighters 2 - Operation Hell Dive (Japan set 3) [ironGiant]LTM Portable (B+) [Nigel Barnes]LTM Portable (Master) [Nigel Barnes]Bubble Trouble (World, Rev [Alex Cmaylo, The Dumping Union]Sensory Chess Challenger 9 (set 2) [anonymous]Operation Thunderbolt (World, rev 1) [Muddymusic, The Dumping Union]Digital Equipment Corporation VT240 [Carl]Elektronika MC7105 [shattered]Intergirl [f205v] New machines marked as NOT_WORKING----------------------------------Tomy Prin-C [TeamEurope]Datamax 8000 [Robbbert] New clones marked as NOT_WORKING--------------------------------BT Merlin M2105 [Nigel Barnes] New WORKING software list additions-----------------------------------pc98_cd.xml: Final batch of additions [rzero9]pce_tourvision.xml: Added a number of new dumps (15) [system11, Tafoid]poisk1_flop.xml: Added basic softlist [shattered] New NOT_WORKING software list additions---------------------------------------gamate.xml: Volcano Panic [Juan Felix Mateos and Mr. Postman]gamate.xml: Hot Hero; Baseball [Peter Wilhelmsen]gba_ereader.xml: Starting work doing the GBA e-reader software-list [shideravan] Click here to download this file
