Pinball Fx2 module for Hyperlaunch
majorspawn
Not sure if the module below will work as it's the grid method. With the new direct method the command line I get is. Process.Run - Running: C:\Program Files (x86)\Microsoft Game Studios\Pinball FX2\Pinball FX2.exe EarthDefense -fullscreen -resolution1920x1080
You may also need to get cabinet support to run them direct via command line. https://blog.zenstudios.com/?page_id=5981
Pinball FX2.rar
With a newer version of the application (June 2015 release patch), you can launch the tables directly via command line e.g "pinball fx2.exe" STARWARS_Light_VS_Dark.pxp note the pxp file name is CASE sensitive!!
so "pinball fx2.exe" archer.pxp will NOT work but "pinball fx2.exe" Archer.pxp will, figure that
I have created .lnk files as above and used PCLauncher to run the lnk files with fade title of "Pinball FX2" with Alt+F4 exit method, works fine. I am using HyperLaunch but this will work for any setup as its a generic method.
Thanks MS
