vampirolatino2 Posted February 14, 2014 Posted February 14, 2014 Now that Zebulon will not make anymore boards ... how I can connect my Cherry DMD? Can I use an original DMD High Voltage Driver? Alternatives? I wanted the Zebulon DMD High Voltage Driver board because it was cheap, wanted to support a member AND they are made with good quality components.
Carny_Priest Posted February 14, 2014 Posted February 14, 2014 I think virtuapin.net was going to sell piggy boards. But I don't know when. I don't see it in their product list right now. They do have transformers. You might want to check the compatibility of the Cherry display with the pindmd board. I'm not sure it will work.
vampirolatino2 Posted February 15, 2014 Author Posted February 15, 2014 thanks, I found some replacements but they aren't cheap for example: rottendog http://www.rottendog.us/DMD089.html edit: correct link to product
vampirolatino2 Posted February 15, 2014 Author Posted February 15, 2014 This may work too: http://bayareaamusements.com/Merchant2/merchant.mvc?Store_Code=BAA&Screen=PROD&Product_Code=XP-WPCDMD-CTRL
russdx Posted February 15, 2014 Posted February 15, 2014 the above links are overkill as you only need the high power components which is about 20% of those boards lol the rest is all the graphics drivers. virtuapin im pretty sure will be selling every thing needed for plasma dmd's soonish from what i read in a thread on vp forums. I have a zeb board that i am not using as the plasma dmd i bought did not work so gave up lol. if you like you can have this board for cheap. give me a shout at russdx @ gmail com if interested
vampirolatino2 Posted February 15, 2014 Author Posted February 15, 2014 the above links are overkill as you only need the high power components which is about 20% of those boards lol the rest is all the graphics drivers.virtuapin im pretty sure will be selling every thing needed for plasma dmd's soonish from what i read in a thread on vp forums. I have a zeb board that i am not using as the plasma dmd i bought did not work so gave up lol. if you like you can have this board for cheap. give me a shout at russdx @ gmail com if interested email on the way!
