SNES - Invalid System Name *Frustrating*
Tanveer
Hi guys,
I've been going back and forth with Hyperspin and this error message of "Super Nintendo Entertainment System" Invalid System Name or snes9x.exe is not working".
Everything works outside of Hyperspin so its not the emulator. Could someone direct me in the right direction?! Is there something wrong with my AHK files or the database files????
It's been 3 days and I still can't get around this issue! Any help would be appreciated :)
Does it launch properly from RocketLauncher, outside of HyperSpin?
Post a copy of your HyperSpin log (log.txt in your root HS folder) and I'd be happy to take a look.
10:48:36 PM |  HyperLaunch v2.25c
10:48:36 PM |  System Specs:
HyperSpin Dir: C:\Hyperspin
OS: WIN_7
OS Language: 0409
OS Admin Status: No
Monitor #1 (\\.\DISPLAY1): 900x1440 (900x1400 work)
HyperSpin Res: 900x1440
AHK Version: 1.1.07.03
10:48:36 PM |  HyperLaunch received "MAME" and "wrestwar"
10:48:36 PM |  INI Keys read
10:48:36 PM |  Checking paths
10:48:36 PM |  Finished injecting functions into module
10:48:36 PM |  Module is built
10:48:36 PM |  Running module:
;Built in script
#NoTrayIcon
DetectHiddenWindows, ON
SetTitleMatchMode, 2
SendMode, Event
0 = 2
exitEmulatorKey = Esc
emuPath = C:\Hyperspin\Emulators\Mame\
romPath = C:\HyperSpin\Emulators\MAME\roms\
romPathFromIni = C:\HyperSpin\Emulators\MAME\roms\
romExtension = .zip
romExtensionOrig = .zip
romExtensions = zip
executable = mame.exe
systemName = MAME
romName = wrestwar
daemonToolsPath =
skipchecks = false
fadeIn = false
fadeOut = false
fadeColor = 0x000000
fadeInDuration = 500
fadeOutDuration = 500
fadeInDelay = 0
fadeInInterruptKeys = {LControl}{RControl}{LAlt}{RAlt}{LShift}{RShift}{LWin}{RWin}{AppsKey}{F1}{F2}{F3}{F4}{F5}{F6}{F7}{F8}{F9}{F10}{F11}{F12}{Left}{Right}{Up}{Down}{Home}{End}{PgUp}{PgDn}{Del}{Ins}{BS}{Capslock}{Numlock}{PrintScreen}{Pause}
gameStartImgPath = C:\Hyperspin\Media\MAME\Images\GameStart\
moduleExtensionPath = C:\Hyperspin\Modules\Module Extensions\
7zEnable = false
7zExtractDir = C:\Users\PIRTPA~1\AppData\Local\Temp\Hyperspin\
7zExtractDirOrig =
7zDelTemp = true
7zFormats = .zip,.rar,.7z,.gzip,.tar
7zFormatsNoP = zip,rar,7z,gzip,tar
mgEnabled = false
mgKey = NumpadSub
mgSelectKey = Enter
mgExitKey = Esc
multiGameImgPath = C:\Hyperspin\Media\MAME\Images\MultiGame\
mgBackgroundColor = FF000000
mgSidePadding = 0.2
mgYOffset = 500
mgImageAdjust = 1
mgFont = Arial
mgText1Options = x10p y30p w80p Centre cBBFFFFFF r4 s100 Bold Italic
mgText2Options = w96p cFFFFFFFF r4 s50 Center Bold Italic
mgText2Offset = 70
mgUseSound = true
mgSoundfreq = 300
mgExitEffect = none
mgSelectedEffect = rotate
mgUseGameArt = false
mgArtworkDir = Artwork1
Hotkey, Esc, CloseProcess
;Module script
; MAME
; MAME .140
; by BBB
; 1.0
; Info:
; Since MAME needs to save hi scores and data on exit, then we can\'t force
; MAME closed with a hotkey. So make sure you have your own exit key setup
; in MAME first.  We will leave the CloseProcess section below blank, but
; it is still required.
Runwait, %executable% %romName%, %emuPath%, Hide UseErrorLevel
if(ErrorLevel != 0){
  if (ErrorLevel = 1){
    Error = Failed Validity
  }else if(ErrorLevel = 2){
    Error = Missing Files
  }else if(ErrorLevel = 3){
    Error = Fatal Error
  }else if(ErrorLevel = 4){
    Error = Device Error
  }else if(ErrorLevel = 5){
    Error = Game Does Not Exist
  }else if(ErrorLevel = 6){
    Error = Invalid Config
  }else if(ErrorLevel = 7 || ErrorLevel = 8 || ErrorLevel = 9){
    Error = Identification Error
  }else{
    Error = Mame Error
  MsgBox Mame Error - %Error%
ExitApp
;Required
CloseProcess:
   ;Doesnt have to do anything but make sure to have the line before and after this line.
return
hideDesktop(){
FadeInStart(){
FadeInExit(){
FadeOutStart(){
Suspend, On
FadeOutExit(){
7z(7zP, 7zN, 7zE, 7zExtractDir){
7zCleanUp() {
CheckFile(file,msg="",timeout=6){
IfNotExist, %file%
If msg
ScriptError(msg, timeout)
Else
ScriptError("Cannot find " . file, timeout)
Return %file%
ScriptError(error,timeout=6){
MsgBox,48,Error,%error%,%timeout%
ExitApp
10:48:40 PM |  Module ended, exiting HyperLaunch normally
12:58:38 PM |  HyperSpin Started
12:58:38 PM |  Going FullScreen
12:58:38 PM |  Checking for updates
12:58:38 PM |  Update Check Complete
12:58:38 PM |  Startup program unavailable
12:58:38 PM |  Playing intro video
12:58:39 PM |  Error intializing joysticks
12:58:39 PM |  Menu Mode is multi
12:58:39 PM |  Loading Main Menu.xml
12:58:39 PM |  Main Menu.xml successfully loaded
12:58:39 PM |  Main Menu wheel loaded successfully
12:58:41 PM |  Loading Super Nintendo Entertainment System.xml
12:58:41 PM |  Main Menu.xml successfully loaded
12:58:42 PM |  Super Nintendo Entertainment System wheel loaded successfully
12:58:44 PM |  Launching Game
12:58:44 PM |  Running HyperLaunch.exe
12:58:44 PM |  Command Line is: HyperLaunch.exe "Super Nintendo Entertainment System" "2020 Super Baseball (USA)"
12:59:39 PM |  Launching Game
12:59:39 PM |  Running HyperLaunch.exe
12:59:39 PM |  Command Line is: HyperLaunch.exe "Super Nintendo Entertainment System" "2020 Super Baseball (USA)"
12:59:44 PM |  Launching Game
12:59:44 PM |  Running HyperLaunch.exe
12:59:44 PM |  Command Line is: HyperLaunch.exe "Super Nintendo Entertainment System" "2020 Super Baseball (USA)"
12:59:49 PM |  Quiting Hyperspin
12:59:49 PM |  Bye!
  • 4 months later...
sorry to dig up a old post but this just started after an update and I am using znes
08:29:04 PM |  HyperSpin Started
08:29:04 PM |  Going FullScreen
08:29:04 PM |  Checking for updates
08:29:04 PM |  Update Check Complete
08:29:04 PM |  Startup program unavailable
08:29:04 PM |  Error intializing joysticks
08:29:04 PM |  Menu Mode is multi
08:29:04 PM |  Loading Main Menu.xml
08:29:04 PM |  Main Menu.xml successfully loaded
08:29:05 PM |  Main Menu wheel loaded successfully
08:29:11 PM |  Loading Super Nintendo Entertainment System.xml
08:29:11 PM |  Main Menu.xml successfully loaded
08:29:12 PM |  Super Nintendo Entertainment System wheel loaded successfully
08:29:13 PM |  Launching Game
08:29:13 PM |  Using HyperLaunch
08:29:13 PM |  Getting Launcher path
08:29:13 PM |  Can't find HyperLaunch, defaulting to root HyperLaunch.exe
08:29:13 PM |  Launcher located at C:\HyperSpin\HyperLaunch.exe
08:29:13 PM |  Running Launcher
08:29:13 PM |  Launcher Command Line is: C:\HyperSpin\HyperLaunch.exe "Super Nintendo Entertainment System" "Aladdin (USA)"
08:29:20 PM |  Launching Game
08:29:20 PM |  Using HyperLaunch
08:29:20 PM |  Getting Launcher path
08:29:20 PM |  Can't find HyperLaunch, defaulting to root HyperLaunch.exe
08:29:20 PM |  Launcher located at C:\HyperSpin\HyperLaunch.exe
08:29:20 PM |  Running Launcher
08:29:20 PM |  Launcher Command Line is: C:\HyperSpin\HyperLaunch.exe "Super Nintendo Entertainment System" "Aladdin (USA)"
08:29:23 PM |  Loading Main Menu.xml
08:29:23 PM |  Main Menu.xml successfully loaded
08:29:24 PM |  Main Menu wheel loaded successfully
08:29:26 PM |  Exit program unavailable
08:29:26 PM |  Quiting Hyperspin
08:29:26 PM |  Bye!
update if anyone has this issue change Execution from hyperlaunch to normal , then Use Full Path to Roms: enabled and it should work
