Where does the mame 0.174 No nag save new controls now?
Kwestone
This is totally boggling my mind.
If i go in and change the coin and start. It creates a configuration file in the respective place. However if I change the normal button configurations. The default.cfg isnt updated, yet the settings are saved. Was there a change to how things were saved? I mean, the new mame doesnt have any files whatsoever, so I am completely stumped on where to find this.
Thanks!
Matt
On 0.175 and 0.176 the default.cfg is blank unless you make a change to Input General. When you run a game a new cfg will be created but this will remain blank until you make a change to "This Machine".
Some interesting new additions to 0.176.
The popular crt-geom and crt-geom-deluxe shaders have been ported to BGFX and are now distributed with MAME, thanks to cgwg. The BGFX versions of these shaders allow live adjustment of effect parameters through the slider controls menu.
Thanks for the response! :)
I downloaded your file. And I understand that I have to put this in cfg folder. Do I have to make any changes to the mame.ini file to get it to recognize it?
Also, I understand what you were saying about the it writing to it for general inputs. However, I WAS changing it in general inputs. And I could see the changes for the other inputs start 1 and coin 1. However, when I made changes to the general inputs for player 1. The settings saved, however nothing was in the cfg.
Thanks again for your response.
That file needs to go  in the ctrlr folder and you then need to add the file name to the Mame.ini and any other ini files in the ini folder.
Here's where to add it.
# CORE INPUT OPTIONS
coin_lockout              1
ctrlr                     XARCADE_XBox360x4
mouse                     1
joystick                  1
lightgun                  0
multikeyboard             0
multimouse                0
steadykey                 0
ui_active                 0
offscreen_reload          0
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
natural                   0
joystick_contradictory    0
coin_impulse              0
