Exiting with X-Arcade tankstick
Near76
I am currently using a tankstick in mode 1.  It works well, except I cannot exit games back into the HyperSpin front end.  I have tried to assign this in HyperHQ to multiple buttons, but cannot get it to work and there really isn't any one button I can assign to be the "Escape" key.  Thoughts on what to try next?  Thank you!
I use the player 1 and 2 player buttons together to exit and button 1 and 3 buttons for hyper pause.
You can assign your buttons in rocketlauncher under the settings tab > controls > Exit emulator key
Ditto what he said
Set a hot key inside rocket launcher main settings under exit emulator
I have a tankstick and I have it setup as the 8th button on player 2, works sweet!
Thanks guys...for some reason I get an "AutoHotkey32.dll, error - 2" when I press the Capture Hotkey button. Any thoughts on how to resolve or just manually update a cfg file?
Not to sure why your getting that error. Maybe ask over on the rocketlauncher forums.
You can manually put the exit keys in from the RL settings folder in the Global RocketLauncher.ini where it says exit.
\RocketLauncher\Settings\Global RocketLauncher.ini
If you want 1&2 as your exit you'll want to put is after esc
Exit_Emulator_Key=~Esc|1&2
Is there a way to assign the left or right mouse button to the exit command?
