p0giewan Posted March 4, 2014 Posted March 4, 2014 Ok... after months of browsing, reading forums and trying to soak up as much information as possible I'm going to get the ball rolling on a cabinet build. Suffering a little bit from information overload and maybe 2nd guessing myself a little but I wanted an opinion on the following: Thinking of this TV for my main playfield: http://www.amazon.com/Samsung-UN46F6300-46-Inch-1080p-120Hz/dp/B00BCGRTFK/ref=sr_1_2?ie=UTF8&qid=1393905319&sr=8-2&keywords=samsung+46%22+led and I was going to go with the widebody cab kit from Virtuapin here: http://virtuapin.net/index.php?main_page=product_info&cPath=2&products_id=85 Only thing that makes me nervous is the 23.25 inside dimension on the cab vs the 24.5 width on the TV. I know its cased but that bezel looks pretty thin
p0giewan Posted March 5, 2014 Author Posted March 5, 2014 After yet more research I realize that this is going to be a tall order without slotting the cab AND taking a $900 dollar gamble that I can make the tv fit. As much as 46" sounds good I'm going to go with the more sensible: http://www.amazon.com/LG-Electronics-42LN5700-42-Inch-LED-LCD/dp/B00BB9ORW6/ref=sr_1_5?ie=UTF8&qid=1394003518&sr=8-5&keywords=42%22+led If the measurements are correct on Amazon should fall just shy of the cab edges without de-casing it. I'll start a new case build thread when I get everything ordered. Going to go with a Timeshock themed table with hopefully a nice compliment of toys in the cab
vampirolatino2 Posted March 5, 2014 Posted March 5, 2014 Yes, for that Samsung 46" TV you need slot cuts inside the cab. That LG will fit like a glove. Have fun!
