How to desensitize the HyperSpin wheel a bit
thomas3120
Hello,
Did some searches on this this but no luck or related to something else.  Hoping there's a setting to desensitize the wheel movement in HS (I use my trackball & 8 way Comp joy).
Best way to describe it is (without touch the trackball or joystick) and right after selecting a game to play the wheel jumps fore/aft  a notch or two.  Also sensitive when cycling through the games...not bad but a bit easy to overshoot.
Any help on this appreciated much
t
  On 10/1/2016 at 3:01 PM, thomas3120 said:
Hello,
t
In HyperHQ there is an option to adjust trackball sensitivity.
On the main tabs across the top row...Select the tab labeled "controls".
The select the tab "Trackball".
Hopefully that helps!
Thanks for the quick reply :)
Any settings for the Happs Comp joystick (ipac4)-keyboard?  Maybe a keyboard 'rate' in HS or RL to lower a bit?
thanks again
t
