sydaroa Posted February 13, 2010 Posted February 13, 2010 There is my config for this system working in hyperspin [exe info] path = c:\HyperSpin\Emulators\mednafen\ rompath =c:\HyperSpin\Emulators\PCEngineCD\ userompath = true exe = Mednafen.exe -loadcd pce romextension = cue parameters = searchsubfolders = false pcgame = false winstate = NORMAL hyperlaunch = false First of all you have to put the syscard3.pce bios in your mednafen directory. Then you have to write a command to tell mednafen were the bios is mednafen -pce.cdbios [path to the bios.pce] Now we're able to run cd images of pc engine CD If the cd images aren't in the BIN/CUE format it will be necesary to edit the cue file and set the correct path to the includes files on it. Regards and sorry for my english
Squizza1000 Posted April 25, 2010 Posted April 25, 2010 I am trying to get this to work, and I am lost at the part where you say to write a command to point mednafen to the BIOS. Could you help a dumb guy out and give me a step by step for how to do that? Also for the BIOS files I have 7files with names like: [bIOS] CD-ROM System (Japan) (v1.0).pce, [bIOS] TurboGrafx CD System Card (USA) (v2.0).pce, [bIOS] TurboGrafx CD Super System Card (USA) (v3.0).pce, etc etc. Do these need a specific naming convention to work, or is the current names OK? (Do I need them all?) Thanks in advace to anyone that can help.
sydaroa Posted April 28, 2010 Author Posted April 28, 2010 Open a cmd window Start ----- Run and type cmd Go to mednafen folder an write the code mednafen -pce.cdbios [path to the bios.pce] for example the path to the bios could be c:\hyperspin\emulators\mednafen\[bIOS] TurboGrafx CD System Card (USA) (v2.0).pce The sentence in the cmd window will be mednafen -pce.cdbios [bIOS] TurboGrafx CD System Card (USA) (v2.0).pce I hope this help you Regards and sorry for my english
soapdishbandit Posted September 25, 2014 Posted September 25, 2014 I hope people still check this post! I was able to get it to load in command line, but not from Hyperspin, here are my settings: [exe info] path=D:\Jeremy\Emulation\Mednafen\ rompath=D:\HyperSpin\Roms\TurboGrafx CD\ userompath=true exe=mednafen.exe -loadcd pce romextension=cue parameters= searchsubfolders=false pcgame=false winstate=NORMAL hyperlaunch=false And here is my HS Log: 10:27:04 PM | HyperSpin Started 10:27:04 PM | Going FullScreen 10:27:04 PM | Checking for updates 10:27:04 PM | Update Check Complete 10:27:04 PM | Startup program unavailable 10:27:04 PM | Playing intro video 10:27:05 PM | Error intializing joysticks 10:27:05 PM | Menu Mode is multi 10:27:05 PM | Loading Main Menu.xml 10:27:05 PM | Main Menu.xml successfully loaded 10:27:05 PM | Main Menu wheel loaded successfully 10:27:06 PM | Loading TurboGrafx CD.xml 10:27:06 PM | Main Menu.xml successfully loaded 10:27:06 PM | TurboGrafx CD wheel loaded successfully 10:27:07 PM | Launching Game 10:27:07 PM | Running in normal rom mode 10:27:07 PM | Excecutable is mednafen.exe 10:27:07 PM | Command Line is: "D:\Jeremy\Emulation\Mednafen\mednafen.exe" -loadcd pce "D:\HyperSpin\Roms\TurboGrafx CD\4 in 1 Super CD (USA).cue" 10:27:14 PM | Loading Main Menu.xml 10:27:14 PM | Main Menu.xml successfully loaded 10:27:15 PM | Main Menu wheel loaded successfully 10:27:16 PM | Exit program unavailable 10:27:16 PM | Quiting Hyperspin 10:27:16 PM | Bye!
soapdishbandit Posted September 25, 2014 Posted September 25, 2014 Sorry to bother you about this. Thanks!
maxcade Posted March 21, 2015 Posted March 21, 2015 This is how easy this really is "TURN DAEMON TOOLS OFF",fired mednafen up n the game works,in hyperspin nothing apart from a audio until i turned daemon tools off,i feel a right carrot,lol,you dont need to alter the text any different than normal,tried it...didnt work,ive tried finding threads to help me and i couldnt even find one,just go in hyperlaunchhq turn daemon tools to false,viola
Styphelus Posted March 23, 2015 Posted March 23, 2015 and this is where retroarch comes in Agreed. I don't understand why anyone would even try to use multiple individual emulators anymore.
ninja2bceen Posted February 12, 2016 Posted February 12, 2016 This is how easy this really is "TURN DAEMON TOOLS OFF",fired mednafen up n the game works,in hyperspin nothing apart from a audio until i turned daemon tools off,i feel a right carrot,lol,you dont need to alter the text any different than normal,tried it...didnt work,ive tried finding threads to help me and i couldnt even find one,just go in hyperlaunchhq turn daemon tools to false,viola this worked to get mednefan working for cue/bin files but how do you get ccd/img/sub 7zip files to run? Mednefan I'm reading supports ccd Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
QuinnHQ Posted February 13, 2016 Posted February 13, 2016 Agreed. I don't understand why anyone would even try to use multiple individual emulators anymore. For myself, Retroarch doesn't play nice with my monitor/HDTV dual screen setup. If I set it to Duplicate under screen settings, Retroarch loads to a blank screen. It unsure the game (music and sounds) but a blank screen on both monitors. I've tried numerous things to fix the problem but can't figure it out. So I use individual emulators. The only issue I have now is ePSXe does the same thing. A bit frustrating, but I guess anytime I play on my TV I'll have to go into the PC settings and make the TV my main screen and run it from there. Sure it's only about 15 secs of work... But it bothers me.
