DJQuad Posted October 16, 2016 Posted October 16, 2016 Hey all, is there anywhere that specifies where the box art, wheel logos, and cart art are, or do symbolic links have to be used?
thatman84 Posted October 16, 2016 Posted October 16, 2016 Hey all, is there anywhere that specifies where the box art, wheel logos, and cart art are, or do symbolic links have to be used? Not sure on the question Do you mean what folder they go in? If so... The theme.xml dictates where box and cart art go by way of screen location and layer depth. Closest to screen is art 4. Wheel logos go in wheels folder of each system or your main menu Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
DJQuad Posted October 16, 2016 Author Posted October 16, 2016 You can't specify the paths to those folders like you can with videos if that's what you're asking. You would have to use symbolic links if you wanted to keep media outside of the standard HS directories. That's what I meant. Thanks. I use the EmuMovies Download Service Utility so multiple frontends can use the same media.
