Dolphin Emulator Extra Copies of Text Problem
pjbridger
Hi Guys,
I have a small issue with Dolphin,
Everything looks great, except,
In multiple games I have a strange issue where the text is messed up on screen,
This happens in new super mario, Wii Sports and more,
This issue only happens when using DX11, if I change to DX9 it dissapears, but the performance of DX9 is pretty bad for me,
I have tried setting the resolution lower and texture cache to safe but no joy,
If anyone knows how to fix this t would be great!
Thanks!
P
Hi Guys,
Thanks!
P
Which graphics card do you have and are you using the latest dolphin build?
Does it still happen if u switch to using opengl instead of dx11? I have a few games that show the same type of artifacts, some I've noticed go away depending which graphics back end dolphin is using
@BATTLEDONKEY,
That does work!
The performance hit is pretty huge though, As you are no longer using the GPU so much,
would be awesome if there was an option so I could still use DX11?
Try disabling antialiasing and using native resolution to increase performance. That does it for me on my setup with onboard Intel Graphics.
Thanks for the reply,
i can get the emulator to work on DX9 at 2x resolution with no issues,
I was just looking for an option where i could still maintain the 4x resoloution,
I guess ill just stick with the performance hit from OpenGL,
Thanks for suggestions,
  • 3 months later...
hi guys,
just to add,
Some games such as Super mario galaxy have messed up sprites which can be fixed using,
Texture Scaling Mode - XBRZ - 3X
This fixes the sprite issue in most cases and you can still use DX11 at 4X resolution
