Found my project !
BlueScreenTT
part on the way already ! :-) what i dont get is how he hooked up the two identical regarding to hardware to play of one cassette
have wrote him but he didnt answer yet
hmm have read that page before where did you find it on that page ??
cant find in the manual either ! shit i must be stupid will try google again
Wiring NeoGeo cabs together
That's all I searched for.
And stop worrying about it. When you have the hardware you will have your answer. It is pretty easy from the last time I linked an old Daytona cabs setup together. Crap those things get dusty. From memory it was an old serial cable.
Nope ! that is now how he did it !
wiring 2 or more neo cabs together is done via a cable. You daisy chain the cartridges together
he did not do that !
he says in the end of the video that he is running 2 identical cabs but only one have the cartridge ! also the connection was only done with about 3 or 4 games and the one he is playing is not one of them !
just have to try and get in contact with him again
That makes sense. Like I said Google it. You have the same hardware in each but slave the others sounds accurate. Never used NeoGeo hardware mores the pity. You'd actually be better to find a forum that specialised in NeoGeo hardware as that sort of project won't be running HyperSpin anyway. :D
yea i know but i might be able to run 2 systems in one just need some big switches that switches the jamma harness and then connect a pc with hyperspin to one of them now that would be a cool cab
If you are doing bartops the you won't fit much inside them let alone NeoGeo hardware and a full PC setup. Also switching could be a headache. Worst thing is you would lose the look as you would want more buttons.
