ROM Utility to remove numbers on a lot of Rom Files?
thomas3120
Been Slowly getting all my 'official' databases in HS.
One problem I'm having is that I have a whole set that looks like this:
0771 - Age of Empires - The Age of Kings (E)(Independent)
They all have Numbers at the beginning (and a dash).  Are there any ROM utilities that would allow me to delete these?
Can you explain that delimiter a little more agent?  I was unaware that you could do that sort of stuff with Don's.  If it is listed in the program then I am just one of those guys that does what he knows and does not try anything new but that seems really useful.
Thanks for the quick reply :)
Hehe, I was just reading and trying that out but must have entered something wrong.  If I recall correctly, Don wrote that anything between commas is dismissed...as in you want that part?
  On 11/10/2016 at 3:17 PM, agent47 said:
"%d -" (without quotes) in the "Best match filename strip" box and it should ignore the numbers when matching the files to rename. That way you can avoid doing it in 2 steps.
Expand
 Ahh, So I need to place %d- in front of the ROM name?  ....Or in the box in the ROM renamer only add %d- ?
Thanks again
t
You can use Ant renamer and the characters deletion option to delete all of the numbers at once from the file name and it only takes seconds to do
