Sega 32x menu loading issue (Resolved)
shikimol
Hi all,
I have been setting up my system and everything has been working fine. Thanks to SimplyAustin and his great videos.
However, I have finally started on the Sega 32x and run into an issue. I am not sure if I have done something wrong but I followed all of Austin's steps and the Sega 32x wheel will not load.
Steps:
  1. Load Hyperspin and get to main menu
  2. Goto Sega 32x. This shows with the video and looks great.
  3. Select system
  4. Screen flashes black and then comes back to main menu with Sega 32x selected.
Images attached:
  • System_selected.png is when I have pointed to this system and it does it's video thing.
  • System_entered.png is after I have tried to enter the system and it loads the main wheel again.
I have watched the video over and over and checked every step and I have everything right, but this keeps happening.
Roms and Emulator work fine in RocketlauncherUI. So I feel that it is something else that I have missed or done wrong.
Any help would be great thanks, as I am completely new to this..
Regards,
               Shikimol
Sounds like you need to uncheck filters in hyperhq. It does that when you have roms only selected and you have a wrong extension or no extension setup.
Sent from my SM-G920V using Tapatalk
Hi,
I am using Retroarch, cataclysm67.
Thanks dougan78, this fixed the issue. The Roms only filter caused the issue.
Thanks again for your help. I will remember this for the future.
Regards,
              Shikimol
If your settings are correct on the wheel tab are you ROMs using the same upper and lower case letters? I had an issue with one system this week and it turned Hyperspin is case sensitive and the data base had "the" in the ROM name where as my ROM had it with a capital! I doubt this is true of a whole set though.
Sent from my Nexus 5 using Tapatalk
