ninja2bceen Posted November 18, 2016 Posted November 18, 2016 You have heard of fuzzy matcher where you can match your files to rom. You have heard of files to folders where the folder will be called whatever the file is. The thing we have missing is a folder renamer!The reason I'm requesting this is because I have found a number of my rl media folders are not named the same as the games. Can someone make or have such an app to do a fuzzy match of files and rename folders in a matching way?Thanks Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
Dilated18 Posted April 1, 2017 Posted April 1, 2017 I no its been awhile since this was asked but i hope this helps http://www.scanialabs.com/Products/Miroirs/Miroirs.aspx.
ninja2bceen Posted April 1, 2017 Author Posted April 1, 2017 I'll check it out, thanks. Horsey from rl will be adding it to hyper mint as well Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
ninja2bceen Posted April 1, 2017 Author Posted April 1, 2017 I'm not sure this will work. It needs to look at another folder directories media set and look up all those names. Then check the new media folder and fix any folder names that do not match it. Everyone here has the same problem you just don't know it maybe. If you have rl media from the front, then chances are you have rl media but it's not showing up sometimes because the name doesn't match your database name Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
Dilated18 Posted April 1, 2017 Posted April 1, 2017 so u have a media set that is all named correctly and want to create folders based of the names in that media set?
Dilated18 Posted April 1, 2017 Posted April 1, 2017 If your only trying to make empty directories with the proper names the program i linked should do the trick. If yur trying to rename folders with files in them already then hyperspin rom manager will do that with directory mode. Hope im understanding what u r trying to do correctly
